Blocky video
cwlaualex
Post Sat Jan 28, 2012 2:36 am
Blocky video
I have successfully playing mkv on my Panasonic L42E30H without transcoding and subtitle is working fine. However, I got some other video that is not the same result. The video playback has some distorted view in some scenes. The scenes that got problem are always in similar position. As I don't know a single word to name it, the video that I saw seems like a previous frame is not completely remove and the new frame overlapped partially in the old frame. Only the moving part in the new frame is shown while part of the old frame is still here. How should I describe it in English? Pardon for my poor vocabulary.
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 48.00 (48/1)
Input #0, matroska,webm, from 'Toy.Story.3.mkv':
  Duration: 01:42:35.90, start: 0.000000, bitrate: 11972 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080, SAR 1:1 DAR 16:9,
23.98 fps, 48 tbr, 1k tbn, 47.95 tbc
      title           : Toy.Story.3.2010
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s
      title           : DTS-ES5.1 1536K
    Stream #0:2(chi): Audio: ac3, 48000 Hz, 5.1(side), s16, 640 kb/s
      title           : DDEX 5.1 640K 蝎方祗
The above result is generated from ffmpeg -i. I wonder whether it's the problem with the bitrate. It's around 11Mb/s. Another video that I have completed without any problem has a lower bitrate. My network connection is like the below.
PC <-- LAN --> router <-- LAN --> TV
All are connected by cable.
Post Sat Jan 28, 2012 5:50 pm
Re: Blocky video
that will be a corrupt file rather than a serviio issue.
cwlaualex
Post Sun Jan 29, 2012 3:46 am
Re: Blocky video
However, it plays nicely on my PC. Better error correction in PC??
Post Sun Jan 29, 2012 3:57 am
Re: Blocky video
cwlaualex wrote:However, it plays nicely on my PC. Better error correction in PC??
yer more tollerant.
voodooo
Post Mon Jan 30, 2012 1:28 pm
Re: Blocky video
Could you post a mediainfo of that file ?
cwlaualex
Post Tue Jan 31, 2012 3:06 pm
Re: Blocky video
Unique ID                                : 199473196993062965995983977073665753833 (0x961123EBF4D8951191B1012317C5C2E9)
Complete name                            : E:\DVD\Toy Story\Toy.Story.3.mkv
File size                                : 8.58 GiB
Duration                                 : 1h 42mn
Overall bit rate                         : 12.0 Mbps
Encoded date                             : UTC 2012-01-23 08:59:47
Writing application                      : mkvmerge v5.2.1 ('A Far Off Place') built on Jan  2 2012 23:21:10
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Duration                                 : 1h 42mn
Bit rate                                 : 9 824 Kbps
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.198
Stream size                              : 6.87 GiB (80%)
Title                                    : Toy.Story.3.2010
Writing library                          : x264 core 102 r1666 d058f37
Encoding settings                        : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.05:0.10 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=9824 / ratetol=2.0 / qcomp=0.70 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=1:0.90 / nal_hrd=none
Audio #1
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : ES
Codec ID                                 : A_DTS
Duration                                 : 1h 42mn
Bit rate                                 : 1 510 Kbps
Bit depth                                : 24 bits
Stream size                              : 1.08 GiB (13%)
Title                                    : DTS-ES5.1 1536K
Audio #2
Duration                                 : 1h 42mn
Bit rate                                 : 640 Kbps
Stream size                              : 470 MiB (5%)
Title                                    : DDEX 5.1 640K 粤语
Language                                 : Chinese
I got a few video that have this problem. This is one of the example.
voodooo
Post Tue Jan 31, 2012 3:54 pm
Re: Blocky video
Thanks for your input it will help troubleshooting. I have similar problems and we're trying to work this out.
Post Tue Jan 31, 2012 4:03 pm
Re: Blocky video
I suppose Panasonic devices does not support DTS audio, so
Could remove the DTS track by remuxing the file with mkvmerge tool (AVC+AC3)?
voodooo
Post Tue Jan 31, 2012 4:24 pm
Re: Blocky video
I believe E-series do support DTS Illico.
EDIT: Just tested and yes, E-30 Series at least do support DTS.
Return to Panasonic
