M6 Replay (France) [BROKEN]
Post Tue Jan 31, 2012 9:13 pm
BROKEN : M6 replay catalog used by this groovy plugin (in xml format) is no longer updated. We need to update plugin to use the new catalog in json format.
SEE new plugin : viewtopic.php?f=20&t=8837
Source Type: Web Resource
Source Url : See Note*
Media Type : Video
M6replay.groovy
Note*
First level : All media are presented in one folder (its big!!)
Source Url = http://www.m6replay.fr
Second level : Select media by Genre, for each "genre" you want, you have to create an online source.
When you enter the M6REPLAY website you can select a "programme" (check the URL path in your browser)
Series & fictions : Source Url = http://www.m6replay.fr/#/choisir-par-ge ... s-fictions
Emissions : Source Url = http://www.m6replay.fr/#/choisir-par-genre/emissions
Info : Source Url = http://www.m6replay.fr/#/choisir-par-genre/info
Jeunesse : Source Url = http://www.m6replay.fr/#/choisir-par-genre/jeunesse
Third level : Select media by Products, for each "Products" you want, you have to create an online source.
When you browse the M6REPLAY website you can select a specific "Product" (check the URL path in your browser)
For example:
ESPRIT CRIMINEL : Source Url = http://www.m6replay.fr/#/series-fiction ... vior/40500
UN DINER PRESQUE PARFAIT : Source Url = http://www.m6replay.fr/#/emissions/un-d ... fait/41040
ZONE-INTERDITE : Source Url = http://www.m6replay.fr/#/info/zone-interdite/40966
BARBAPAPA : Source Url = http://www.m6replay.fr/#/jeunesse/barbapapa/41030
_
samcro49
Post Thu Mar 01, 2012 10:38 pm
Re: M6 Replay (France)
hi,
i have a problem i use this plugin and i create online source :
ressource web
url: www.m6replay.fr
name m6
video
on my tv samsung i don't have folder
why
samcro49
Post Sat Mar 03, 2012 3:39 pm
Personne pour mon problème je suis aussi nul que ça en anglais
Post Sun Mar 04, 2012 12:31 pm
Ajoute "http://" aux Urls
url:http://www.m6replay.fr
piHaLOrkx
Post Sun Mar 04, 2012 5:47 pm
Bonjour,
Je suis dans le même cas que samcro49, j'ai ajouté l'url "http://www.m6replay.fr" mais aucun dossier n'apparait dans sources en ligne sur mon téléviseur Samsung LE40C630 !
Et pourtant j'ai le dernier pack de plugin à jour et je l'ai bien ajoutée en tant que ressources web.
Quelqu'un pourrait-il nous éclairer ?
I can translate my request if it's necessary ;)
Post Sun Mar 04, 2012 7:43 pm
Il semble y avoir une mise à jours à prévoir.
voici l'erreur:
java.io.IOException: Unexpected error while invoking plugin (M6replay): http://www.m6replay.fr/files/configurationm6_lv3.xml
Je regarde ça!!
samcro49
Post Mon Mar 05, 2012 8:17 am
Ok merci je penseais que ça venai de moi comme d'hab quoi
par contre j'ai pas de video avec le plugin w9 jai les dossier mais rein dedans
piHaLOrkx
Post Mon Mar 05, 2012 11:03 pm
Merci c'est super sympa !
Post Fri Mar 09, 2012 8:52 pm
Plugin updated with new rtmp parameters
samcro49
Post Sat Mar 10, 2012 4:34 pm
merci mec sa marche nikel
ehrepli
Post Sat Mar 31, 2012 10:50 am
Je reçois des erreurs comme ça a chaque refresh. C'est moi? Ou il y a bien qq chose qui ne marche pas?
2012-03-31 12:48:00,820 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://groupemsix.fcod.llnwd.net/a2883/d1 app=a2883/d1 swfUrl=http://l3.player.m6.fr/swf/StatPlaylibrary_20100401.swf playpath=mp4:production/regienum/m6_merci-les-enfants-vont-bien_287418_280320121640.mp4 swfVfy=1. It might not play.
        at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:273)
        at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
        at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
        at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
        at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
        at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:255)
Merci!!
Post Sat Mar 31, 2012 7:03 pm
No problem for me when I try :
ffmpeg -i "rtmpe://groupemsix.fcod.llnwd.net/a2883/d1 app=a2883/d1 swfUrl=http://l3.player.m6.fr/swf/StatPlaylibrary_20100401.swf playpath=mp4:production/regienum/m6_merci-les-enfants-vont-bien_287418_280320121640.mp4 swfVfy=1"
ehrepli
Post Sat Mar 31, 2012 8:23 pm
I must have some other proble, because this is what i get:
ffmpeg version git-2012-03-31-f9143d2 Copyright (c) 2000-2012 the FFmpeg developers
built on Mar 31 2012 21:09:33 with gcc 4.4.3
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree --enable-version3 --enable-x11grab
libavutil 51. 44.100 / 51. 44.100
libavcodec 54. 12.100 / 54. 12.100
libavformat 54. 3.100 / 54. 3.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 66.101 / 2. 66.101
libswresample 0. 10.100 / 0. 10.100
rtmpe://groupemsix.fcod.llnwd.net/a2883/d1 app=a2883/d1 swfUrl=http://l3.player.m6.fr/swf/StatPlaylibrary_20100401.swf playpath=mp4:production/regienum/m6_merci-les-enfants-vont-bien_287418_280320121640.mp4 swfVfy=1: No such file or directory
I'll try to figure this one out. Thanks for your answer.
Post Sun Apr 01, 2012 3:02 pm
This is my result :
ffmpeg.exe -i "rtmpe://groupemsix.fcod.llnwd.net/a2883/d1 app=a2883/d1 swfUrl=http://l3.player.m6.fr/swf/StatPlaylibrary_20100401.swf playpath=mp4:production/regienum/m6_merci-les-enfants-vont-bien_287418_280320121640.mp4 swfVfy=1"
ffmpeg version N-38622-g1eabd71 Copyright (c) 2000-2012 the FFmpeg developers
  built on Mar  7 2012 00:18:03 with gcc 4.6.2
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --en
able-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil      51. 42.100 / 51. 42.100
  libavcodec     54. 10.100 / 54. 10.100
  libavformat    54.  2.100 / 54.  2.100
  libavfilter     2. 63.100 /  2. 63.100
  libswresample   0.  7.100 /  0.  7.100
RTMP_HashSWF: swfurl http://l3.player.m6.fr/swf/StatPlaylibrary_20100401.swf not found
HandShake: Type mismatch: client sent 6, server answered 9
HandleCtrl: Ignoring SWFVerification request, use --swfVfy!
  duration              2930.73
  moovPosition          32.00
  audiocodecid          mp4a
  width                 720.00
  height                404.00
  videocodecid          avc1
  avcprofile            77.00
  avclevel              32.00
  aacaot                2.00
  audiosamplerate       24000.00
  audiochannels         2.00
  videoframerate        25.00
trackinfo:
  length                70337536.00
  timescale             24000.00
sampledescription:
  sampletype            mp4a
  length                73266000.00
  timescale             25000.00
sampledescription:
  sampletype            avc1
Input #0, flv, from 'rtmpe://groupemsix.fcod.llnwd.net/a2883/d1 app=a2883/d1 swfUrl=http://l3.player.m6.fr/swf/StatPlayl
ibrary_20100401.swf playpath=mp4:production/regienum/m6_merci-les-enfants-vont-bien_287418_280320121640.mp4 swfVfy=1':
    moovPosition    : 32
    avcprofile      : 77
    avclevel        : 32
    aacaot          : 2
    audiochannels   : 2
    videoframerate  : 25
  Duration: 00:48:50.73, start: 0.000000, bitrate: N/A
    Stream #0:0: Video: h264 (Main), yuv420p, 720x404 [SAR 404:405 DAR 16:9], 25 tbr, 1k tbn, 50 tbc
    Stream #0:1: Audio: aac, 48000 Hz, stereo, s16
This is the ffmpeg windows version include in Serviio install.
If your are on Linux or other ffmpeg version, you need librtmp library with ffmpeg "--enable-librtmp".
Look at this : http://www.serviio.org/download
ehrepli
Post Tue Apr 03, 2012 11:21 pm
I was in linux, yes, and after reinstalling ffmpeg from sources everything seems to work fine.
Thank you Illico!
samcro49
Post Fri Jun 15, 2012 6:07 am
Don't work to 11/06/2012
Post Tue Jun 19, 2012 7:28 am
Le site M6replay semble avoir modifié le protocole, le plugin ne fonctionne plus.
Je regarde ça lorsque j'ai un peu de temps, mais si il y a des volontaires pour analyser cela, je suis biensur preneur. (XBMC a le même problème)
Merci.
Post Sun Jun 24, 2012 7:44 pm
Re: M6 Replay (France) [BROKEN]
I found the rtmp server and parameters with latest unofficial 2.5 rtmpdump.
But with ffmpeg its broken.
Zip, do you compile the latest librtmp library ?
insane822
Post Sun Jun 24, 2012 8:45 pm
Illico wrote:I found the rtmp server and parameters with latest unofficial 2.5 rtmpdump.
If it is only working with 2.5, they probably upgraded the server to use handshake-10, which means it's not going to work until the rtmpdump team comes up with a proper fix. The unofficial rtmpdump-2.5 only works on handshake-10 streams when compiled as an executable, so if you try to compile with librtmp, ffmpeg will crash. :(
Post Mon Jun 25, 2012 8:55 am
insane822 wrote:If it is only working with 2.5, they probably upgraded the server to use handshake-10
I will try with 2.4 to confirm.
insane822 wrote: which means it's not going to work until the rtmpdump team comes up with a proper fix. The unofficial rtmpdump-2.5 only works on handshake-10 streams when compiled as an executable, so if you try to compile with librtmp, ffmpeg will crash. :(
So, we have to wait for a new rtmp library update.
bw, the plugin is ready.
Return to Available plugins
