W9 Replay (France) [BROKEN]
Post Wed Feb 01, 2012 2:40 pm
BROKEN : W9 replay catalog used by this groovy plugin (in xml format) is no longer updated. We need to update plugin to use the new catalog in json format.
SEE new plugin : viewtopic.php?f=20&t=8837
Source Type: Web Resource
Source Url (see Note*): See *Note*
Media Type : Video
*Note*
First level : All media are presented in one folder
Source Url = http://www.w9replay.fr
Second level : Select media by Genre
When you enter the W9REPLAY website you can select a "programme" (check the URL path in your browser)
Series & fictions : Source Url = http://www.w9replay.fr/#/choisir-par-ge ... s-fictions
Emissions : Source Url = http://www.m6replay.fr/#/choisir-par-genre/emissions
Musique : Source Url = http://www.w9replay.fr/#/choisir-par-genre/musique
Third level : Select media by Products
When you browse the W9REPLAY website you can select a specific "Product" (check the URL path in your browser)
For example:
NUMB3RS : Source Url = http://www.w9replay.fr/#/series-fictions/numb3rs/40996
ENQUETES CRIMINELLES : Source Url = http://www.w9replay.fr/#/emissions/enqu ... vers/40666
W9 HITS : Source Url = http://www.w9replay.fr/#/musique/w9-hits/40918
_
samcro49
Post Thu Mar 01, 2012 10:38 pm
Re: W9 Replay (France)
hi,
i have a problem i use this plugin and i create online source :
ressource web
url: www.w9replay.fr
name w9
video
on my tv samsung i have folder w9 but without video
why?
Post Fri Mar 09, 2012 8:32 pm
Plugin updated with new rtmp parameters.
samcro49
Post Sat Mar 10, 2012 4:34 pm
merci mec sa marche nikel
samcro49
Post Fri Jun 15, 2012 6:07 am
don't work to 11/06/2012
Post Tue Jun 19, 2012 7:27 am
Le site W9replay semble avoir modifié le protocole, le plugin ne fonctionne plus.
Je regarde ça lorsque j'ai un peu de temps, mais si il y a des volontaires pour analyser cela, je suis biensur preneur. (XBMC a le même problème)
Merci.
Post Mon Jul 02, 2012 7:07 am
Plugin updated :
___Warning___
W9 Replay servers changed the rtmp protocol and use "HandShake Type 10 answer".
But the librtmp library used by serviio does not support this latest protocol.
You can use this following specific ffmpeg windows version (thanks insane822): https://c388930.ssl.cf1.rackcdn.com/ffm ... mp-2.5.zip
This is not an official ffmpeg version
insane822
Post Tue Jul 10, 2012 2:07 am
Custom ffmpeg build moved here:
http://www.mediafire.com/?s65x9pnsqsi5hap
Post Wed Aug 01, 2012 6:53 pm
Plugin updated
samcro49
Post Fri Aug 03, 2012 10:42 pm
cela ne marche pas pour moiu je vois les dossiers mais rien dedans
don't work for me
i can see folder but nothing video
Post Thu Aug 23, 2012 7:59 pm
Plugin updated with rtmp server compatible with librtmp 2.4 library.
See first post.
samcro49
Post Sun Aug 26, 2012 9:20 am
thanks
Post Fri Sep 21, 2012 7:47 am
Emissions M6 and W9 are not currently accessible.
I will check that.
Same problem with excelent french catchup tv software : http://captvty.fr/
Post Tue Sep 25, 2012 8:47 pm
W9Replay plugin updated...
w00tie
Post Tue Nov 13, 2012 7:39 pm
bjr,
Est-ce que le plugin est tjs fonctionel car je n'arrive pas à le faire fonctionner. :-(
merçi,
w00tie
Post Wed Nov 14, 2012 8:12 pm
Avec MediaBrowser, cela ne fonctionne PAS !!
http://localhost:23424/mediabrowser/
Mais cela fonctionne BIEN sur ma Sony Bravia.
Zip, its strange, this is the ffmpeg command line used when MediaBrowser is used (FAILED):
ffmpeg.exe -i "rtmpe://groupemsix.fcod.llnwd.net/a2883/e1 app=a2883/e1 playpath=mp4:production/w9replay/w9_soda_460783_031120121830.mp4?s=1352923373&e=1353009773&h=ec131056d331329f823640a4b3c6aa1b swfUrl=http://l3.player.m6.fr/swf/ReplayPlayerV2Hds.swf swfVfy=1 buffer=100000000" -y -copyts -c:v h264 -sameq -vf scale=720:405,setsar=1 -r 25 -g 15 -c:a libmp3lame -b:a 192k -ar 44100 -ac 2 -map 0:0 -map 0:1 -sn -f flv C:\Windows\TEMP\Serviio\transcoding-temp-1000000000020004-flv_player-ORIGINAL.stf
The option "-c:v h264 -sameq" are not supported
Post Sun Jan 06, 2013 2:38 pm
Re: W9 Replay (France) [BROKEN]
Post Sat Jan 12, 2013 2:37 pm
Return to Available plugins
