Compatible devices list
What is the DLNA device you use Serviio with?
Samsung TV
239
30%
Sony TV
100
12%
Panasonic TV
64
8%
Other TV
41
5%
WDTV Live
51
6%
LG BD-xxx
21
3%
XBox 360
51
6%
Playstation 3
82
10%
Other (specify in the forum please)
161
20%
Total votes : 810
kappclark
Post Wed Feb 01, 2012 4:39 pm
Re: Compatible devices list
Sony N200 media player = very good
leeor
Post Sun Feb 05, 2012 1:37 pm
Running on FreeBSD-9.0, serving a Samsung Plasma TV C-series (wired), and occasionally my PS3 (wifi, better and more stable video streaming than PMS, but lack of subtitles integration forces me to stick mostly to PMS).
danp
Post Sat Feb 18, 2012 12:23 am
Works great with Samsung UE40D5000. Serviio beats everything I tested before like Twonky or TVersity.
vbivona
Post Fri Feb 24, 2012 2:56 am
Works great on Samsung portable BluRay player BD-C8000
dencon
Post Fri Mar 02, 2012 9:45 am
no problem at all for a Samsung UExxD5520 :D
Pumahr
Post Wed Mar 07, 2012 8:40 am
Works fine with Panasonic TX-P42GT30E, profile "Panasonic Viera With AVI Support"
Audio: MP3 and FLAC = works
Pictures: Jpeg = works
Video: avi with srt = works
DVD: picture and sound = works
DVD problem: can't select other audio, no subtitle - I know, maybe in future.
Serviio 0.6.2 running under Windows 7 on Dell Dimension E520
Panasonic TX-P42GT30E Viera | Windows 7
dRdoS7
Post Mon Mar 12, 2012 1:04 am
Works well with my wife's Samsung BluRay player BD-D5500.
Better than the memory & CPU hog that is Samsung's "AllShare"!
I did make one small change myself to the profile for "Samsung C/D": I changed 4.1 to 5.2 for AVC. I found it was trancoding mkvs which played OK from a USB stick.
The Samsung manual states it only plays up to L4.1, the files I was playing were L5.1 (according to MediaInfo). Plays them OK now, with subs!!!
I also made the changes I found on the Wiki about removing device description from the profile and "Presentation" settings in Serviio.
I put this info here in case some-one does a search for this player.
Thanks for a great proggie.
dRdoS7.
Serviio 0.6.2 running under Windows 7 64 Ultimate.
repeters
Post Fri Mar 16, 2012 10:55 pm
The current release of serviio works just great with a Panasonic TC-P50ST50.
GastonJ
Post Mon Apr 02, 2012 7:33 pm
Works with my Panasonic SC-BTT362, which had me ripping my hair out for a while. The profiles posted in the Panasonic thread helped greatly , in fact the first one that I copied into my config did the trick :D No problem with my PS3 either. Excellent piece of software.
jimhuyiwei
Post Wed Apr 04, 2012 12:50 pm
Sony CMT-MX700Ni, works perfectly, though it will take a long time for serviio to start on my NAS.
smoce
Post Mon Apr 30, 2012 7:42 pm
LG 42LV570s
OK
Server Serviio - NetBook Asus EEE 1004HA - WIN XP/7
OK
I am from Czech and apologize for any errors in language.
CC5
Post Tue May 01, 2012 6:15 pm
Hello All,
I am runing Serviio v 0.6.2 on a Windows 7 (64 bit) PC, using an ASUS O!Play Air with firmware version 1.29P (http://www.asus.com/Multimedia/Digital_ ... /OPlay_Air) - attached to an 15-year-old TV set via composite video/audio. Via WLAN. And it works... :) Thank you!
Well, it works up to 95%... One or two things should be fixed. My O!Play Air is identified as an "unrecognized device" and the "generic DLNA profile" is used. This causes e.g. that FastForward isn't very fast (1,5x and 2x - that's it...). O!Play Air can do faster - I know it from a test with TVMOBiLi (up to 32x). By the way: TVMOBiLi identifies an ASUS O!Play Air as "POSIX UPnP/1.0 Intel MicroStack/1.0.2718, O!Play_Air, DLNADOC/1.50" - whatever that means...
A little more annoying is that during the last minute of a video (H.264 videos, I think) the ASUS player says "I/O error" and prompts me with an "OK" - no other choice... And of cause, the video does not continue.
For ASUS users: when I started with the ASUS O!Play Air, I had the problem that the player sometimes did not find any DLNA server on my PC. Solution: switching the channel set up of my WLAN from "automatic" to a fixed channel, e.g. channel 5. This works at least with my Speedport W 723V (German telecom).
From my point of view, it would be nice to create a profile for an ASUS O!Play Air (or for ASUS O!Plays in general). If I could be helpful in testing profiles with this ASUS player, do not hesitate to provide me with profiles. Thanks in advance...!
Best regards
CC5
iplem
Post Thu May 03, 2012 3:10 pm
Works very nice on Samsung LA37D550 with 2 minor issues:
. The TV reboot from time to time when requesting for an online streaming that doesn't work
. rtsp links doesn't work yet (working on the profile)
satyaki
Post Sun Jun 03, 2012 5:13 pm
Works out-of-the-box with Sony KDL-46HX823 + MacBook laptop.
Though, so far, I have only used Serviio to view movies stored on my MacBook. I am interested in streaming online video, but I have not tested it yet.
hgs
Post Sun Jun 10, 2012 10:23 am
It works perfect with my Panasonic TX P42GW30 but my T&A MusicPlayer has a problem to talk
to Serviio. In Serviio the MP is recognized and displayed using the Generic DLNA profile , but from the device itself I can't select
the Server as a soure allthough it is listed in its display.
However I can stream music to it using PlugPlayer or 8player.
iuzar
Post Wed Jun 13, 2012 7:20 am
I have a Samsung Smart TV 32ES5500 and a Dell E6410 laptop as server.
In Serviio the TV is recognized and displayed using the Generic DLNA profile , but from the device itself I can't select
the Server as a source (is not listed). I understood that I have to install a plugin but I couldn't find any additional info and/or the plugin.
Post Wed Jun 13, 2012 10:06 am
iuzar wrote:I have a Samsung Smart TV 32ES5500 and a Dell E6410 laptop as server.
No plugin is required. Read FAQ to troubleshoot the problem you have.
iuzar
Post Thu Jun 14, 2012 9:01 am
Thank you zip, it was that damn ESET firewall. Solved it and enjoying now Serviio :)
Regards.
seaman
Post Mon Jun 18, 2012 7:48 pm
Working fine with both Samsung UE46C6000 and LE40C530, server under Linux Ubuntu 12.04.
lavebug
Post Wed Jun 20, 2012 7:25 pm
47LE8500 windows 7
Return to User experiences
