Synology DS211j: Serviio does not start
Vladizlav
Post Thu Feb 02, 2012 1:42 am
Hi! I have Synology DS211j. I had been trying to run Serviio 0.6.0 with no significant success (it worked for sometime, but then started saying that serviio server did not seem to be running), so I hoped to get my problems fixed with the latest update.
I noticed that Java 7 for Embedded 7 may have been updated too, removed it and installed it again. The same has been done for Serviio. Now Serviio does not even show that it works. It apparently starts when I click Run, but after a minute or so it is stopped again. Java for Embedded 7 seems always stopped, and I do not see a link to run it. Any advice?
Post Thu Feb 02, 2012 2:58 am
Re: Synology DS211j: Serviio does not start
Can you post your serviio.log file.
ntangle
Post Thu Feb 02, 2012 10:58 pm
Had the same problem DSM 4.0 Beta, DS110j and new Serviio package 6.1
Ran /volume1/@appstore/Serviio/bin/serviio-wrapper.sh from the shell
Following error:
/volume1/@appstore/Serviio/bin/serviio-wrapper.sh: line 56: syntax error: Mem: 118848 85996 32852 0 2672 47252/1024
Line 56:
RAM=$((`free | grep Mem: | sed -e "s/^ Mem: *\([0-9]*\).*$/\1/"`/1024))
if [ $RAM -le 128 ]; then
JAVA_MAX_HEAP=80M
elif [ $RAM -le 256 ]; then
JAVA_MAX_HEAP=192M
elif [ $RAM -gt 256 ]; then
JAVA_MAX_HEAP=384M
fi
So I removed all the above apart from the JAVA_MAX_HEAP=80M (being a 110j less than or equal to 128)
Running fine now. Not using grep from the box, have the ipkg grep package.
patters
Post Thu Feb 02, 2012 11:10 pm
Interesting. I'd say that your version of sed is more likely to be the problem. Can you try running that bit again, but using the sed from DSM:
RAM=$((`free | grep Mem: | /bin/sed -e "s/^ Mem: *\([0-9]*\).*$/\1/"`/1024))
echo $RAM
The thing is, I introduced this RAM checking routine with my Minecraft package, and my NAS was bootstrapped on 3.2 at the time (and therefore would have had the ipkg version of sed). Now it's non-bootstrapped on 4.0beta. I haven't run into that, and I've not had that issue reported on my blog yet either.
patters
Post Thu Feb 02, 2012 11:17 pm
Hang on. I'm not sure what you've done, but you're missing a space in that code line just before the 'Mem', hence the problem. You have:
It should be:
Did you perhaps open the script in nano to read it and saved a change by accident?
ntangle
Post Thu Feb 02, 2012 11:18 pm
DiskStation> RAM=$((`free | grep Mem: | /bin/sed -e "s/^ Mem: *\([0-9]*\).*$/\1/"`/1024))
-ash: syntax error: Mem: 118848 110576 8272 0 584 16232/1024
DiskStation> echo $RAM
DiskStation>
ntangle
Post Thu Feb 02, 2012 11:21 pm
and with the extra space, syntax error too :/
patters
Post Thu Feb 02, 2012 11:22 pm
Can you post the output from running the 'free' command (in a [code] block so I can see the spacing?). Thanks.
ntangle
Post Thu Feb 02, 2012 11:25 pm
Removed the spaces as Mem: is against the left margin, works fine now
DiskStation> free -V
Unknown HZ value! (93) Assume 100.
procps version 3.2.8
DiskStation> which sed
/opt/bin/sed
DiskStation> sed --version
GNU sed version 4.2.1
DiskStation> free
             total       used       free     shared    buffers     cached
Mem:        118848     103524      15324          0        944      15684
-/+ buffers/cache:      86896      31952
Swap:      2097144      81832    2015312
patters
Post Thu Feb 02, 2012 11:29 pm
Hmm, maybe you've somehow got a different version of free. I'm on DSM 4.0beta and mine isn't like yours.
Can you do the same but using /bin/free
ntangle
Post Thu Feb 02, 2012 11:34 pm
/usr/bin/free: (/bin/free not found)
DiskStation> /usr/bin/free
  Mem:       118848       106908        11940            0         3100
 Swap:      2097144        47392      2049752
Total:      2215992       154300      2061692
Using absolute paths, your code now works ;)
patters
Post Thu Feb 02, 2012 11:37 pm
Thanks, I'll either make that explicit, or make the matching a little less rigid in the next version of the package (0.6.2).
Vladizlav
Post Fri Feb 03, 2012 2:22 am
I got serviio log file, but it is empty.
