New Panasonic Profiles Requiring Testers.
Post Tue Jan 31, 2012 9:29 pm
UPDTAED - 03/02/2012 @ 21:11 gmt
Please can users of following devices please test the profile related to there model and report if they are able to play all of their files and if not post information on files that wont play so that default profiles can be updated in serviio.( howto in my signature)
Profile for ST30 and VT30 both these TVs do not have AVI support so it requires transcoding.
    <Profile id="24" name="Panasonic Viera With AVI Support" extendsProfileId="1">
      <!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="20000">
         <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
         <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
           <!-- remux VORBIS/FLAC/LPCM in MKV/MP4 to AC3 -->
           <Video targetContainer="mpegts" targetACodec="ac3" >
              <Matches container="mp4" vCodec="h264" aCodec="lpcm"/>
              <Matches container="mp4" vCodec="h264" aCodec="aac"/>
           <!-- Remux MPEG-TS with no transcoding -->
              <Matches container="matroska" vCodec="mpeg2video"/>
           <!-- Remux WTV files to MPEG-PS with no transcoding-->
              <Matches container="wtv" />
           <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
              <Matches container="avi" />
              <Matches container="mp4" vCodec="mpeg4" />
         <Matches container="mpeg" vCodec="mpeg1video" />
         <Matches container="matroska" vCodec="mpeg4" />
              <Matches container="asf" />
              <Matches container="flv" />
              <Matches container="ogg" />
              <Matches container="3gp" />
           <!-- unsupported audio will be transcoded into lpcm audio -->
              <Matches container="flac" />
              <Matches container="adts" />
           </Audio>
Profile for E30, GT30 and UT30 these TVs have AVI support so it doesnt need transcoding
        <MediaFormatProfiles>
        </MediaFormatProfiles>
         <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.2" />
         <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.2" />
           </Audio>
Profile for S30 and X30 - i cant confirm for sure what specs these TVs have as they dont give out that information so you will need to test both profiles above
Thanks to Huyz for starting this i have made a few changes though to improve quality and reduce transcoding on certain models
voodooo
Post Tue Jan 31, 2012 9:47 pm
Re: New Panasonic Profiles Requiring Testers.
There are other things we need to understand in order to get a better E30 profile.
1 - Some mkv files stutter and we're getting close to know why, little more testing is needed. Once we got it we can set to transcode them.
2 - DTS audio can natively play on E30.
Post Tue Jan 31, 2012 9:58 pm
voodooo wrote:There are other things we need to understand in order to get a better E30 profile.
not alot i can do about stuttering but have removed the DTS remux line for that device can you test that exact profile and let me know of your findings.
PMI
Post Wed Feb 01, 2012 3:39 pm
I have been testing transcoding with help from voodooo for a few days. A lot of the good results are due to help from voodooo...
This is a summary of what we have found out so far:
The 2011 Viera E-series (and probably G-series) support AAC in MKV and MP4 files. MKV and MP4 files with h264 video and AC-3 or AAC audio play without transcoding, and so do MPEG-TS files.
For example, an AVI file with H.264 video and AAC audio has to be remuxed into an MPEG-TS container, but neither the video, not the audio needs to be transcoded.
In general, transcoding MKV files with H.264 video is not required, and in my tests caused problems with some files.
MKV files and MP4 files with H.264 and AC-3 or AAC audio play best with no transcoding, and no remuxing.
MKV files and MP4 files with mpeg2video seem to play best when they are simply remuxed to MPEG-TS.
According to Panasonic tech support, some files may play better when transcoded or remuxed into MPEG-TS container. I found this to be the case with a few WTV files recorded in HD from on air broadcast in WMC (windows Media Center). So, WTV files should probably be remuxed into either MPEG-PS or MPEG-TS. So far I have better luck with remuxing WTV to MPEG-PS with no transcoding. All files I have tried play this way, and not all play in the other cases.
WTV files seem to play best remuxed into MPEG-PS with no transcoding.
Some videos seem to "stutter" when encoded with h264 and a high number of reference frames. In general, this results in a higher "Level", but not always, so I am not considering this problem solved. The problems seems to start at or around the memory limit for Level 4 and 4.1, but some files start to stutter just below this limit, and some files play fine above this limit. I have at least one level 5 file which will play fine.
Some help is needed with this problem. My have to do with how the Viera TV allocates memory for reference frames when decoding H.264.
The last profile I have been testing with is attached below, but still needs improvement, with some help:
Viera_E_G Profile3.txt
Edited, to revise bad container type for wtv files
(2.91 KiB) Downloaded 1196 times
Peter
Post Wed Feb 01, 2012 8:07 pm
great bit of info PMI but that was not exactly what i ask and this is why i abandoned pansonic device last time, i need people to test the profiles i provide and give info on file that dont play not give me full profiles that i have to spend hours going over, when i dont even own the device. Also remeber we are building for the Range and not a specific model, so some thing i have set are because of a ceratin model that may work for your device but add more transcoding than it really needed, so then once complete i will add comments to teh profile for users to then tweak the profile to there exact device.
please test the profile profiled and tell me what will play and what will not.
voodooo
Post Wed Feb 01, 2012 8:18 pm
Cerberus, I'm testing PMI's profile for two weeks now, and we're trying to make it count.. The profile you provided is almost the same, except we are transcoding when video profile level is higher then 4.1. This is not the solution and we need to understand what are the videos that stutter cause right now, we transcode a lot of unnecessary files.
The thing is, with the profile you create there will be videos that will stutter and we need to make sure why and solve it or the general users will came here again and open a bunch of topics saying their videos are stuttering or this format cant be played. We have Panas and we're trying to improve Serviio for them.
Thanks for your effort.
Post Wed Feb 01, 2012 8:20 pm
ok
and remux wtv files into mpeg TS.
added to the profile, as per PMIs profile but its extreme hard to work out if any of the rest is actualy needed or not, so please test the profile from first post.
voodooo wrote:Cerberus, I'm testing PMI's profile for two weeks now, and we're trying to make it count.. The profile you provided is almost the same, except we are transcoding when video profile level is higher then 4.1. This is not the solution and we need to understand what are the videos that stutter cause right now, we transcode a lot of unnecessary files.
stutter i cant deal with yet as i said above, and im not doing this just for your specific model, please do as i requested and test the profile i provide and give feed back on it then once i have handle on it i can then advise on your stutter issue, help me to help you or there will never be a good working profile for panasonic like there is for samsung, sony and pure devices.
Post Wed Feb 01, 2012 8:32 pm
question is WTV files required in a TS or PS container as your comment say PS yet you rule changes it to TS????
PMI
Post Wed Feb 01, 2012 9:23 pm
Cerberus wrote:question is WTV files required in a TS or PS container as your comment say PS yet you rule changes it to TS????
Thank for catching that! I tested both ways, several times, and must have posted an incorrect version...
Not required, but PS container works better with wtv files. that section should have been:
When I use the MPEG-TS container, some wtv files I have recorded from broadcast will not play (most do, but not all).
Btw, I only posted what voodooo and I had been testing with so you could use whatever you wanted.
Peter
PMI
Post Wed Feb 01, 2012 9:27 pm
Cerberus wrote:please test the profile profiled and tell me what will play and what will not.
will do.
Peter
Post Wed Feb 01, 2012 9:56 pm
ok profile updated with that info, please copy it from first post again as it has been edited.
Tarrasque
Post Thu Feb 02, 2012 8:33 am
Panasonic U30 series (same supported formats as E and G)
The new profile still does not play MKV's
mediainfo
Format                           : Matroska
File size                        : 173 MiB
Duration                         : 21mn 28s
Overall bit rate                 : 1 129 Kbps
Encoded date                     : UTC 2012-02-01 08:27:51
Writing application              : mkvmerge v5.2.1 ('A Far Off Place') built on Jan  2 2012 23:21:10
Writing library                  : libebml v1.2.3 + libmatroska v1.3.0
Format                           : MPEG-4 Visual
Format profile                   : Advanced Simple@L5
Format settings, BVOP            : Yes
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : XVID
Codec ID/Hint                    : XviD
Duration                         : 21mn 28s
Width                            : 624 pixels
Height                           : 352 pixels
Frame rate                       : 29.970 fps
Writing library                  : XviD 1.2.1 (UTC 2008-12-04)
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 3
Mode                             : Joint stereo
Mode extension                   : MS Stereo
Codec ID                         : A_MPEG/L3
Codec ID/Hint                    : MP3
Duration                         : 21mn 28s
Bit rate mode                    : Variable
Channel(s)                       : 2 channels
I tried PMI's profile which notes the 4.1, and those files play fine (also play fine if I use the phillips profile)
If you have some 'test' files I can run, and will tried running on all profiles. More than glad to help out
Post Thu Feb 02, 2012 8:38 am
Cerberus,
On first profile (first post), for Panasonic devices without AVI support, why did you keep these unnecessary lines?
In fact with this following lines:
            <Matches container="avi"/>
All avi files will be transcoded
voodooo
Post Thu Feb 02, 2012 12:16 pm
Tarrasque wrote:The new profile still does not play MKV's
You have xvid inside mkv not an usual foramt I think. Try change the profile level to 4.1 with level editor: http://wiki.serviio.org/doku.php?id=avceditor
Post Thu Feb 02, 2012 1:42 pm
Illico wrote:Cerberus,
cause i missed it, ah well removed it now :)
do we know what the highest profile level the device support is ? high 4.1 ?
voodooo
Post Thu Feb 02, 2012 2:15 pm
Cerberus wrote:do we know what the highest profile level the device support is ? high 4.1 ?
I believe PMI have tested with profile level 5 but with a lower resolution and reframe rate, something like, profile is set to 5 but fitting on profile 4.1 based on (width * height * ref_frames) / 256 http://wiki.serviio.org/doku.php?id=get_h264_level
pdneri
Post Thu Feb 02, 2012 2:20 pm
Is there a suggested profile for the G20 series?
Thanks!
voodooo
Post Thu Feb 02, 2012 2:24 pm
pdneri wrote:Is there a suggested profile for the G20 series?
Thanks!
Please post supported formats of you device (see sign).
Post Thu Feb 02, 2012 2:25 pm
ok so video bitrate is an issue then id guess, try adding this to the profile, its almost what PMI had in his profile with slight edit, real shame we have to transcode these files though.
         <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.1" />
         <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.1" />
         <Matches container="mp4" vCodec="h264" profile="high" levelGreaterThan="4.1" />
         <Matches container="mp4" vCodec="h264" profile="main" levelGreaterThan="4.1" />
         <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.1" />
         <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.1" />
add it as first video section, then test it hard and see if we still have stuttering, if we do then we can try limiteding the audio bitrate too.
Post Thu Feb 02, 2012 2:26 pm
Thanks!
please start a new topic for G20 with its support information, so not to push this topic in different direction :)
http://wiki.serviio.org/doku.php?id=device_sf
Return to Panasonic
Users browsing this forum: Google [Bot] and 5 guests
