WARN [IndexedDiskCache]
eclp
Post Thu Feb 02, 2012 11:24 pm
Can someone tell me why again is this warning? How can I prevent this?
Sony BDP-S780, serviio 0.6.2, Sony BD Player / SMP
Both options are disabled: "Generate thumbnails for local videos" and "Descriptive metadata" (No descriptive metadata)
2012-02-01 13:26:06,994 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-02-01 13:26:06,994 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
WildRushSykes
Post Thu Feb 02, 2012 11:27 pm
Re: WARN [IndexedDiskCache]
Sounds like your pc is writing a huge amount of data to its hard disk at the time and hangs serviio
eclp
Post Thu Feb 02, 2012 11:32 pm
This may not be.
There are about 15 video files in the folder. No images or music files.
Post Thu Feb 02, 2012 11:34 pm
eclp wrote:2012-02-01 13:26:06,994 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
I think that serviio was not properly shutdown and that messed up the disk cache.
eclp
Post Thu Feb 02, 2012 11:42 pm
Ok, that sounds plausible. But how can I prevent it now? I stop serviio and turn off the PC. :?
Post Thu Feb 02, 2012 11:44 pm
how are you stopping serviio?
eclp
Post Thu Feb 02, 2012 11:49 pm
Windows task bar --> Exit serviio
Post Thu Feb 02, 2012 11:54 pm
you exiting just serviio or the serviio server also?
eclp
Post Fri Feb 03, 2012 12:00 am
After "Exit serviio" serviio is completely finished. The service "Serviio DLNA Media Server" is also finished.
eclp
Post Fri Feb 03, 2012 12:05 am
Why must I serviio stop at all? So stop your antivirus tool?
Post Fri Feb 03, 2012 12:13 am
The Antivirus tool is not keeping a database updated. It is just good practice to stop programs with databases.
eclp
Post Fri Feb 03, 2012 12:16 am
Thanks Moltra for the answers. Unfortunately, my problem (question) is still not solved.
Post Sun Feb 05, 2012 12:35 pm
I think it's normal. You can check the cache files under library folder. If you add new online feeds and close Serviio the file sizes should change.
