Samsung b-series MP4 h264/aac
Elvis71
Post Sun Oct 03, 2010 10:35 am
Someone has a profile update for this on Samsung B-series? TV says unrecognized file format.
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (66893/
1395) -> 23.98 (66893/2790)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'bb.mp4':
major_brand : isom
minor_version : 1
compatible_brands: isom
encoder : Yamb 2.1.0.0 [http://yamb.unite-video.com]
Duration: 01:13:14.10, start: 0.000000, bitrate: 2442 kb/s
Stream #0.0(und): Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 2133 kb
/s, 23.98 fps, 23.98 tbr, 66893 tbn, 47.95 tbc
Stream #0.1(und): Audio: aac, 48000 Hz, 5.1, s16, 304 kb/s
Post Sun Oct 03, 2010 10:14 pm
Re: Samsung b-series MP4 h264/aac
The TV is picky and plays some files like this and some it does not. Not sure what is the problem - but generally transcode it not needed for h264/aac.
Elvis71
Post Sat Oct 09, 2010 11:19 am
For anyone experiencing the same problem: I used DivX Plus Converter (free) to convert these MP4 files to HD MKV and they work fine now on my TV. It works very easy. It even supports fast forward now. Personally, I don't see any loss of quality, only thing is your CPU's will be smoking for a couple of hours while converting...
djm16
Post Fri Nov 05, 2010 10:51 pm
See the thread about Samsung C LED series. It is in the small print of the Samsung users manual. "if there are problems with the contents of a codec, the codec will not be supported" which translated seems to mean if there is an error in the data stream then you are SOL. This would explain why some files play and others do not, and is the reason why I am hoping to get transcoding working on playing my DVDs from my PC.
