Install issue privilegs
pur_berger
Post Sat Feb 04, 2012 9:51 am
Good Morning!
I have an issue (it's NOT a bug) - after every update the privilegs I run the service with are set back to default which leads serviio after restarting the service loosing the databse completely. Is there a way to leave the privilegs as they are during the update?
I need to set them manually as my files are on a NAS witch I can't access with the default user.
Best Regards
Markus
Post Sat Feb 04, 2012 10:12 am
Re: Install issue privilegs
Can you attach your serviio.log file.
What update are you talking about? The serviio updates?
pur_berger
Post Sat Feb 04, 2012 10:22 am
Yep - the serviio updates - happend from 0.6.0 to 0.6.1 and now again. Here is the Log. BUt I don't see much there - only removing the files from the lib until 00:15 when I changed the User the service was startet with from Default to my networkuser and then it adds them again.
serviio.rar
(447.82 KiB) Downloaded 562 times
Post Sat Feb 04, 2012 12:04 pm
You will have to do it manually every time I'm afraid - at least for now.
pur_berger
Post Sat Feb 04, 2012 1:40 pm
No Prob - Just wanted to confirm. Maybee in the future it will be possible to give the service a user during installation ...
Post Sat Feb 04, 2012 5:45 pm
It used to be there in 0.6.0.0 but it confused the hell out of users ;-/
Return to General discussion
Users browsing this forum: Google [Bot] and 21 guests
