Pbr reading mkv since update 0.6.2
IvanleFou
Post Sat Feb 04, 2012 5:49 pm
Since I updated Serviio from linux version 0.6.1 to 0.6.2 and I encounter two problems:
- Lots of MKV files that used to be working with the 0.6.1 version give an error with 0.6.2 and are not playable anymore
- Youtube videos are not playing anymore as well. Is there a new version of the plugins?
My setup is D8000 TV and a HT-D5550.
Thx for any help.
Post Sun Feb 05, 2012 12:30 pm
Re: Pbr reading mkv since update 0.6.2
there is a new youtube plugin.
Post Sun Feb 05, 2012 8:30 pm
mkv issue seem to be down to a bug in ffmpeg if you are running under windows try on of teh later daily builds of ffmpeg asthis may fix your problem.
http://wiki.serviio.org/doku.php?id=win_ffmpeg
also make sure you are selecting the correct profile for you device. :)
IvanleFou
Post Wed Feb 08, 2012 9:15 am
zip wrote:there is a new youtube plugin.
I updated but no luck, till the same problem. I saw that another user posted in the youtube plugin thread a problem similar to mine, I will follow that.
Cerberus wrote:mkv issue seem to be down to a bug in ffmpeg if you are running under windows try on of teh later daily builds of ffmpeg asthis may fix your problem.
I am using Linux. Is ffmpeg actually included in serviio package? i could not find it, maybe reverting to the one included in 0.6.1 could solve the issue, unless it creates incompatibility because 0.6.2 version is using features that are not included in the ffmpeg from version 0.6.1 :?:
edit: serviio uses the same profile (Samsung C/D series) for both the TV and the Home Theater.
Post Wed Feb 08, 2012 8:26 pm
ah ok your on linux that makes things alot harder for you, you will need to compile ffmpeg form the latest source files provided on that site i linked.
