Java 1.6.0_23
eclp
Post Sat Feb 04, 2012 8:11 pm
Java 1.6.0_23
Just a quick note:
If Java is not present on the machine.
Serviio does not invite the current Java 1.6.0_30 always at an installation download the old 1-6-0_23 version.
Post Sat Feb 04, 2012 8:23 pm
Re: Java 1.6.0_23
what os ?
eclp
Post Sat Feb 04, 2012 8:37 pm
Re: Java 1.6.0_23
w7 64
Post Sat Feb 04, 2012 8:59 pm
Re: Java 1.6.0_23
then your worng bro it just fetchs the latest availible form java currently that (java 6 update 30)
eclp
Post Sat Feb 04, 2012 9:11 pm
Re: Java 1.6.0_23
Cerberus, which is clear to me. (on my PC is 1.6.0_30)
When installing serviio on a new machine (without pre-installed Java), they even downloaded serviio old version of Java.
Post Sat Feb 04, 2012 9:39 pm
Re: Java 1.6.0_23
eclp i have done this myself many times while testing java 7 and reverting it always downloads latest version as it not even possible to download the older versions, unless u hunt for them.
Post Sat Feb 04, 2012 11:17 pm
Re: Java 1.6.0_23
I assume it points to an old version, I haven't updated the installer for a while.
eclp
Post Sat Feb 04, 2012 11:22 pm
Re: Java 1.6.0_23
edit: Ok zip, you came to me before. :D
I do not understand!
I've tested again with a new PC without Java (several school-PC, all without Java). And again serviio installed the old version of Java.
:idea: Maybe someone else should try.
Return to General discussion
