Genres Listings
Hooded
Post Sun Feb 05, 2012 4:09 pm
Genres Listings
It seems to me the Genres listings, are using only the first genre listed on the TMDB.
As the TMDB doesn't maintain they're Genre list in an alphabetical order I find the current Genres Menu Listing uses less.
Each movie is only listed once so you end up with things like
Godfather and Godfather II under Action
Godfather III under Drama
Rather than finding them all under the Crime Genre which shows none.
Another example Would be the Shrek movies
Shrek under Animation
Shrek 2, Shrek the Third, Shrek Forever After under Adventure
I would like to see the Genres list the same movie multiple times. Once for each Genre it belongs to.
Right now the movies are only being listed once under the Genre of the first genre listed for the movie at TMDB
Sorry if I dragged this out. Just trying to make sure my point was clear.
Keep Up the great work!
ServiiO Rocks.
Post Sun Feb 05, 2012 8:05 pm
Re: Genres Listings
this would be a mess IMHO and should be correct on the online DB rather than with serviio.
Post Sun Feb 05, 2012 9:12 pm
Re: Genres Listings
there is already open ticket for this
Hooded
Post Mon Feb 06, 2012 12:21 am
Re: Genres Listings
Cerberus wrote:this would be a mess IMHO and should be correct on the online DB rather than with serviio.
Not Really. The Actors Directors and Producers menus are already like this.
Sorry zip
I did search for a ticket/topic for this but didn't find it. :mrgreen:
gmann001
Post Sat Feb 11, 2012 2:40 pm
Re: Genres Listings
Hooded wrote:Sorry zip
Here is the ticket I think Zip was speaking of
https://bitbucket.org/xnejp03/serviio/issue/268/add-multiple-genre-support
martianw
Post Sat Dec 28, 2013 10:58 am
Re: Genres Listings
This feature request (multiple genre support per item) has been open for years now. Is it fair to conclude that it will never be implemented? Is there any way in which another developer (like myself) could implement this or for that matter, other extensions to serviio functionality?
Post Mon Jan 06, 2014 8:00 am
Re: Genres Listings
Currently there are more pressing issues, it will be implemented once I give it a higher priority or it gets a lot of votes on bitbucket.
Return to Feature requests
