Resume play
NoNameAtAll
Post Sun Jan 29, 2012 7:42 pm
Resume play
Would be wonderfull to have resume play - so that when returning to at movie it will start from whereever you left.
Post Sun Jan 29, 2012 7:53 pm
Re: Resume play
Which device? For my sony bdp, if I pause or stop a video and then start it again it will resume. If I turn off the player, then turn it on again and press play then it won't resume. However I think its more down to the device requesting the resume. Serviio will happily server up the video from any place. (Although you obviously run into delays if the video has to be transcoded)
I imagine a device would get confused (display the wrong position) if it asked for the start of a video and serviio tried to resume the video by sending it from where it last was. Therefor, I think the answer is serviio supports resume, its up to the device to support/request it.
Post Sun Jan 29, 2012 8:32 pm
Re: Resume play
will wrote:Which device? For my sony bdp, if I pause or stop a video and then start it again it will resume. If I turn off the player, then turn it on again and press play then it won't resume. However I think its more down to the device requesting the resume. Serviio will happily server up the video from any place. (Although you obviously run into delays if the video has to be transcoded)
yep i can confirm that, if the device supports it then it is offered by serviio the samsung devices do this lovely :)
nachotheix
Post Wed Feb 01, 2012 7:58 pm
Re: Resume play
In my Samsung UE37C6000 resume function stops working since Serviio 0.6. is this situation correct? Have been disable this feature?
Post Wed Feb 01, 2012 7:59 pm
Re: Resume play
nachotheix wrote:In my Samsung UE37C6000 resume function stops working since Serviio 0.6. is this situation correct? Have been disable this feature?
yes there are many posts about this, it stops because we broke the samsung intergration slightly and this has been fixed for 0.6.2 due very soon ( no eta ).
Post Wed Feb 01, 2012 8:13 pm
Re: Resume play
0.6.2 is now out :-)
Post Wed Feb 01, 2012 8:45 pm
Re: Resume play
zip wrote:0.6.2 is now out :-)
trust you to sneak that out when i wasnt looking :(
Citronel
Post Tue Feb 07, 2012 9:17 am
Re: Resume play
In Serviio 0.6.2 & Samsung D32D5000 resume is not working.
Yes Pause it is working at play but if I press Stop and then Play, the clip this is not resumed and it start from begging.
Do you want me to test some specific file formats ? I can do this if will help.
Post Tue Feb 07, 2012 5:16 pm
Re: Resume play
Citronel wrote:In Serviio 0.6.2 & Samsung D32D5000 resume is not working.
no i will ahve some of the beta team who have the D series device look into this, but i know it wont work for MKV files.
Return to Feature requests
Users browsing this forum: Google [Bot] and 10 guests
