Activate local folders
IvanleFou
Post Wed Feb 08, 2012 9:29 am
Serviio has a feature to activate or not an online resource. Would it be possible to add the same checkbox for local folders? This would allow unchecking the folder instead of removing it when not wanted and re-adding it later.
thx for the excellent work.
Post Wed Feb 08, 2012 10:02 am
Re: Activate local folders
that would be a lot of work to implement, all the Genres, Actors, Titles categories would have to be updated. Cannot see it happening tbh. Sorry.
IvanleFou
Post Wed Feb 08, 2012 10:12 am
Okay I see, no problem :)
Post Wed Feb 08, 2012 5:20 pm
id like this feature too, then i can disable the ADULT folders when im not around ;)
Post Wed Feb 08, 2012 5:36 pm
this will be a part of user profiles -- it'll come with one built in (Cerberus) which will only enable porn :-D
On a serious note, I'll actually have to do the same for profiles as the OP is asking, so it might be possible then. Will see.
Post Wed Feb 08, 2012 5:51 pm
zip wrote:this will be a part of user profiles -- it'll come with one built in (Cerberus) which will only enable porn :-D
sweet ;)
Return to Feature requests
