play back issues
AndrewW
Post Sun Feb 05, 2012 4:32 pm
play back issues
I've been trying to play .3gp files on my samsung le46c750 TV with no luck so i tried to convert them to mp4 files.
details of the file is shown below.
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --e
nable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=
mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (180000/1) -> 0.08 (1/12)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'video0224.mp4':
major_brand : mp42
minor_version : 0
creation_time : 2012-01-02 00:00:02
encoder : HandBrake 0.9.5 2011010300
Duration: 00:02:41.51, start: 0.000000, bitrate: 5462 kb/s
Stream #0:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 640x480 [SAR 1:1 DAR 4:3], 5393 kb/s, 14.93 fps, 0.08 tbr, 90
k tbn, 180k tbc
handler_name :
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 22050 Hz, mono, s16, 66 kb/s
handler_name :
however every time i try to play them on the tv it fails, and the below can be found in the debug log. I think its down to the file format, any idea ?
Many thanks
Andrew
2012-02-05 11:34:36,068 DEBUG [WebServer] Incoming connection from /192.168.0.50:33875
2012-02-05 11:34:36,068 DEBUG [ResourceTransportRequestHandler] HEAD /resource/53064/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.0.4:8895]]
2012-02-05 11:34:36,069 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2012-02-05 11:34:36,069 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,069 DEBUG [ResourceTransportRequestHandler] Request for resource 53064 and type 'MEDIA_ITEM' received
2012-02-05 11:34:36,069 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 53064 (local)
2012-02-05 11:34:36,069 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 53064)
2012-02-05 11:34:36,070 DEBUG [VideoDAOImpl] Reading a Video (id = 53064)
2012-02-05 11:34:36,071 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 53064, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (C/D-series)
2012-02-05 11:34:36,071 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-02-05 11:34:36,071 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 110280309,Date: Sun, 05 Feb 2012 11:34:36 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-05 11:34:36,077 DEBUG [WebServer] Incoming connection from /192.168.0.50:51936
2012-02-05 11:34:36,077 DEBUG [ResourceTransportRequestHandler] GET /resource/53064/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5*0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.0.4:8895]]
2012-02-05 11:34:36,077 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2012-02-05 11:34:36,078 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,078 DEBUG [ResourceTransportRequestHandler] Request for resource 53064 and type 'MEDIA_ITEM' received
2012-02-05 11:34:36,078 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 53064 (local)
2012-02-05 11:34:36,078 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 53064)
2012-02-05 11:34:36,078 DEBUG [VideoDAOImpl] Reading a Video (id = 53064)
2012-02-05 11:34:36,079 DEBUG [VideoDeliveryEngine] Delivering item '53064' for client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,079 DEBUG [VideoDeliveryEngine] Delivering file 'Video0224.mp4' in native format
2012-02-05 11:34:36,079 DEBUG [MediaItemDAOImpl] Getting file of media item 53064
2012-02-05 11:34:36,096 DEBUG [MediaItemDAOImpl] Getting file of media item 113622
2012-02-05 11:34:36,097 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 113622) and extractor EMBEDDED
2012-02-05 11:34:36,117 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 53064) as read
2012-02-05 11:34:36,125 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-02-05 11:34:36,125 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 110280309
2012-02-05 11:34:36,125 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-05 11:34:36,126 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 0-110280308/110280309,Content-Length: 110280309,Date: Sun, 05 Feb 2012 11:34:36 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=161000;]]
2012-02-05 11:34:36,137 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-02-05 11:34:36,140 DEBUG [WebServer] Incoming connection from /192.168.0.50:49382
2012-02-05 11:34:36,140 DEBUG [ResourceTransportRequestHandler] GET /resource/53064/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5*0 HTTP/1.0, headers = [Range: bytes=110210657-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.4:8895]]
2012-02-05 11:34:36,140 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2012-02-05 11:34:36,141 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,141 DEBUG [ResourceTransportRequestHandler] Request for resource 53064 and type 'MEDIA_ITEM' received
2012-02-05 11:34:36,141 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 53064 (local)
2012-02-05 11:34:36,141 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 53064)
2012-02-05 11:34:36,142 DEBUG [VideoDAOImpl] Reading a Video (id = 53064)
2012-02-05 11:34:36,142 DEBUG [VideoDeliveryEngine] Delivering item '53064' for client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,142 DEBUG [VideoDeliveryEngine] Delivering file 'Video0224.mp4' in native format
2012-02-05 11:34:36,142 DEBUG [MediaItemDAOImpl] Getting file of media item 53064
2012-02-05 11:34:36,147 DEBUG [MediaItemDAOImpl] Getting file of media item 113623
2012-02-05 11:34:36,147 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 113623) and extractor EMBEDDED
2012-02-05 11:34:36,167 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 69652
2012-02-05 11:34:36,167 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-05 11:34:36,167 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 110210657-110280308/110280309,Content-Length: 69652,Date: Sun, 05 Feb 2012 11:34:36 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-05 11:34:36,189 DEBUG [WebServer] Incoming connection from /192.168.0.50:40462
2012-02-05 11:34:36,189 DEBUG [ResourceTransportRequestHandler] GET /resource/53064/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5*0 HTTP/1.0, headers = [Range: bytes=110280307-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.4:8895]]
2012-02-05 11:34:36,189 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2012-02-05 11:34:36,190 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,190 DEBUG [ResourceTransportRequestHandler] Request for resource 53064 and type 'MEDIA_ITEM' received
2012-02-05 11:34:36,190 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 53064 (local)
2012-02-05 11:34:36,190 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 53064)
2012-02-05 11:34:36,191 DEBUG [VideoDAOImpl] Reading a Video (id = 53064)
2012-02-05 11:34:36,191 DEBUG [VideoDeliveryEngine] Delivering item '53064' for client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,191 DEBUG [VideoDeliveryEngine] Delivering file 'Video0224.mp4' in native format
2012-02-05 11:34:36,191 DEBUG [MediaItemDAOImpl] Getting file of media item 53064
2012-02-05 11:34:36,192 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 2
2012-02-05 11:34:36,192 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-05 11:34:36,192 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 110280307-110280308/110280309,Content-Length: 2,Date: Sun, 05 Feb 2012 11:34:36 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-05 11:34:36,198 DEBUG [MediaItemDAOImpl] Getting file of media item 113624
2012-02-05 11:34:36,199 DEBUG [WebServer] I/O error: Connection reset
2012-02-05 11:34:36,199 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 113624) and extractor EMBEDDED
2012-02-05 11:34:36,200 DEBUG [WebServer] Incoming connection from /192.168.0.50:53716
2012-02-05 11:34:36,201 DEBUG [ResourceTransportRequestHandler] GET /resource/53064/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5*0 HTTP/1.0, headers = [Range: bytes=168-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.4:8895]]
2012-02-05 11:34:36,201 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2012-02-05 11:34:36,201 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,201 DEBUG [ResourceTransportRequestHandler] Request for resource 53064 and type 'MEDIA_ITEM' received
2012-02-05 11:34:36,201 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 53064 (local)
2012-02-05 11:34:36,201 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 53064)
2012-02-05 11:34:36,202 DEBUG [VideoDAOImpl] Reading a Video (id = 53064)
2012-02-05 11:34:36,202 DEBUG [VideoDeliveryEngine] Delivering item '53064' for client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,202 DEBUG [VideoDeliveryEngine] Delivering file 'Video0224.mp4' in native format
2012-02-05 11:34:36,202 DEBUG [MediaItemDAOImpl] Getting file of media item 53064
2012-02-05 11:34:36,203 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 110280141
2012-02-05 11:34:36,203 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-05 11:34:36,203 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 168-110280308/110280309,Content-Length: 110280141,Date: Sun, 05 Feb 2012 11:34:36 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-05 11:34:36,250 DEBUG [MediaItemDAOImpl] Getting file of media item 113625
2012-02-05 11:34:36,251 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 113625) and extractor EMBEDDED
2012-02-05 11:34:36,284 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-02-05 11:34:36,290 DEBUG [WebServer] Incoming connection from /192.168.0.50:45377
2012-02-05 11:34:36,290 DEBUG [ResourceTransportRequestHandler] GET /resource/53064/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5*0 HTTP/1.0, headers = [Range: bytes=198601-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.4:8895]]
2012-02-05 11:34:36,290 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2012-02-05 11:34:36,291 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,291 DEBUG [ResourceTransportRequestHandler] Request for resource 53064 and type 'MEDIA_ITEM' received
2012-02-05 11:34:36,291 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 53064 (local)
2012-02-05 11:34:36,291 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 53064)
2012-02-05 11:34:36,291 DEBUG [VideoDAOImpl] Reading a Video (id = 53064)
2012-02-05 11:34:36,292 DEBUG [VideoDeliveryEngine] Delivering item '53064' for client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,292 DEBUG [VideoDeliveryEngine] Delivering file 'Video0224.mp4' in native format
2012-02-05 11:34:36,292 DEBUG [MediaItemDAOImpl] Getting file of media item 53064
2012-02-05 11:34:36,293 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 110081708
2012-02-05 11:34:36,293 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-05 11:34:36,293 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 198601-110280308/110280309,Content-Length: 110081708,Date: Sun, 05 Feb 2012 11:34:36 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-05 11:34:36,300 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-02-05 11:34:36,301 DEBUG [MediaItemDAOImpl] Getting file of media item 113626
2012-02-05 11:34:36,302 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 113626) and extractor EMBEDDED
2012-02-05 11:34:36,304 DEBUG [WebServer] Incoming connection from /192.168.0.50:37716
2012-02-05 11:34:36,305 DEBUG [ResourceTransportRequestHandler] GET /resource/53064/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5*0 HTTP/1.0, headers = [Range: bytes=243078-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.4:8895]]
2012-02-05 11:34:36,305 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2012-02-05 11:34:36,306 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,306 DEBUG [ResourceTransportRequestHandler] Request for resource 53064 and type 'MEDIA_ITEM' received
2012-02-05 11:34:36,306 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 53064 (local)
2012-02-05 11:34:36,306 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 53064)
2012-02-05 11:34:36,306 DEBUG [VideoDAOImpl] Reading a Video (id = 53064)
2012-02-05 11:34:36,307 DEBUG [VideoDeliveryEngine] Delivering item '53064' for client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-05 11:34:36,307 DEBUG [VideoDeliveryEngine] Delivering file 'Video0224.mp4' in native format
2012-02-05 11:34:36,307 DEBUG [MediaItemDAOImpl] Getting file of media item 53064
2012-02-05 11:34:36,308 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 110037231
2012-02-05 11:34:36,308 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-05 11:34:36,308 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 243078-110280308/110280309,Content-Length: 110037231,Date: Sun, 05 Feb 2012 11:34:36 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-05 11:34:36,315 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-02-05 11:34:36,321 DEBUG [WebServer] Incoming connection from /192.168.0.50:52174
2012-02-05 11:34:36,322 DEBUG [ResourceTransportRequestHandler] GET /resource/53064/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5*0 HTTP/1.0, headers = [Range: bytes=287782-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.4:8895]]
2012-02-05 11:34:36,322 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2012-02-05 11:34:36,322 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
AndrewW
Post Mon Feb 06, 2012 6:42 pm
Re: play back issues
Been looking around the internet some more and the closest i can find is
https://bitbucket.org/xnejp03/serviio/i ... transcoded
next gen TV to mine, and also for transcoded not native format, but coudl there be a link?
Andrew
Post Mon Feb 06, 2012 8:47 pm
if i remember rightly 3gp files are transcoded in teh samsung profile. but i have looked at so many profiles lately im loosing track can you post your serviio profile.xml file so i can take a look please and then i can better advise you :)
AndrewW
Post Tue Feb 07, 2012 6:23 am
Heres the profile, .3gp is in the profile , how ever i could not play 3gp. So i converted the files to mp4. These files do play correctly in vlc, but not on the samsung tv
ANy ideas
Andrew
<Profile id="7" name="Samsung TV / player (C/D-series)" extendsProfileId="1">
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SamsungDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.SamsungWiseLinkProtocolHandler</ResourceTransportProtocolHandler>
<Detection>
<UPnPSearch>
<FriendlyName>(^TV-\d{2}C\d{3}.*)|(^\[TV\][A-Z]{2}\d{2}D\d{3}.*)</FriendlyName>
<ModelNumber>(1\.0)|(AllShare1\.0)</ModelNumber>
</UPnPSearch>
<HttpHeaders>
<!-- for BD players -->
<User-Agent>(.*SEC_HHP_BD-[CD].*)|(.*SEC_HHP_\[(HT|BD)\][CD].*)</User-Agent>
</HttpHeaders>
</Detection>
<DeviceDescription>
<ExtraElements>
&lt;sec:ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:ProductCap&gt;
&lt;sec:X_ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:X_ProductCap&gt;
</ExtraElements>
</DeviceDescription>
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-msvideo" name="">AVI</MediaFormatProfile>
</MediaFormatProfiles>
<ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SamsungContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
<!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" maxVBitrate="20000">
<Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.2" />
<Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.2" />
<Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
<Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
<Matches container="mpegts" vCodec="h264" profile="high" levelGreaterThan="4.2" />
<Matches container="mpegts" vCodec="h264" profile="main" levelGreaterThan="4.2" />
<!-- transcode H264 MP4 files with LPCM audio -->
<Matches container="mpegts" aCodec="mp2" />
<Matches container="mp4" aCodec="lpcm" />
<Matches container="flv" vCodec="h264" /> <!-- looks like some (D?) devices play FLV@H264 natively so this could be removed -->
<Matches container="matroska" vCodec="vc1" />
<Matches container="ogg" vCodec="mpeg4" />
<Matches container="3gp" aCodec="amrnb" />
<!-- transcode MKV with MPEG2 video, remux into mpeg2ts -->
<!-- transcode AVI with AVC video -->
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" maxVBitrate="20000">
<Matches container="flv" />
<Matches container="ogg" />
<!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
<Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true" maxVBitrate="20000">
<Matches container="asf" vCodec="mpeg2video" />
<Matches container="wtv" />
<!-- transcode audio only for wmv with wmapro -->
<Video targetContainer="asf" targetACodec="ac3" aBitrate="256">
<Matches container="asf" aCodec="wmapro" />
<Matches container="mp4" />
<Matches container="flac" />
<Matches container="adts" />
</Audio>
<OnlineTranscoding>
<Matches container="applehttp" vCodec="h264"/>
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" maxVBitrate="20000">
<Matches container="asf" /> <!-- mms -->
</OnlineTranscoding>
<SubtitlesMimeType>smi/caption</SubtitlesMimeType>
Post Tue Feb 07, 2012 6:36 am
change the profile to match this remove the 3gp line above and mod the lower section with wtv in it to match this.
<Matches container="3gp" />
the MP4 file fail because of another issue, that once you have done this change wont be required.
AndrewW
Post Tue Feb 07, 2012 3:46 pm
Tried as requested, but no luck see below, also took about 9 seconds to fail,
also whats the mp4 issue ?
Many Thanks
Andrew
2012-02-07 15:39:42,045 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2012-02-07 15:39:42,046 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-07 15:39:42,046 DEBUG [ResourceTransportRequestHandler] Request for resource 131644 and type 'MEDIA_ITEM' received
2012-02-07 15:39:42,046 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 131644 (local)
2012-02-07 15:39:42,046 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 131644)
2012-02-07 15:39:42,046 DEBUG [VideoDAOImpl] Reading a Video (id = 131644)
2012-02-07 15:39:42,046 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 131644, format MPEG4_P2_TS_ASP_AC3_ISO and profile Samsung TV / player (C/D-series)
2012-02-07 15:39:42,046 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Video0226.3gp
2012-02-07 15:39:42,046 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Video0226.3gp: MPEG4_P2_TS_ASP_AC3_ISO
2012-02-07 15:39:42,047 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-02-07 15:39:42,047 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Tue, 07 Feb 2012 15:39:42 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-07 15:39:42,048 DEBUG [WebServer] Incoming connection from /192.168.0.2:56511
2012-02-07 15:39:42,049 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 90775982-25b4-38fa-940e-be80e85deb5a from 192.168.0.2 (headers = [HOST: 192.168.0.4:8895,DATE: Tue, 07 Feb 2012 15:39:39 GMT,CONNECTION: close,USER-AGENT: 6.1.7601 2/Service Pack 1, UPnP/1.0, Portable SDK for UPnP devices/1.6.14])
2012-02-07 15:39:42,049 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-02-07 15:39:42,049 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.4:8895,DATE: Tue, 07 Feb 2012 15:39:39 GMT,CONNECTION: close,USER-AGENT: 6.1.7601 2/Service Pack 1, UPnP/1.0, Portable SDK for UPnP devices/1.6.14]
2012-02-07 15:39:42,050 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-02-07 15:39:42,056 DEBUG [WebServer] Incoming connection from /192.168.0.50:33227
2012-02-07 15:39:42,056 DEBUG [ResourceTransportRequestHandler] GET /resource/131644/MEDIA_ITEM/MPEG4_P2_TS_ASP_AC3_ISO*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.0.4:8895]]
2012-02-07 15:39:42,056 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2012-02-07 15:39:42,057 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-07 15:39:42,057 DEBUG [ResourceTransportRequestHandler] Request for resource 131644 and type 'MEDIA_ITEM' received
2012-02-07 15:39:42,057 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 131644 (local)
2012-02-07 15:39:42,057 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 131644)
2012-02-07 15:39:42,058 DEBUG [VideoDAOImpl] Reading a Video (id = 131644)
2012-02-07 15:39:42,058 DEBUG [VideoDeliveryEngine] Delivering item '131644' for client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-07 15:39:42,058 DEBUG [VideoDeliveryEngine] Delivering file 'Video0226.3gp' using transcoding
2012-02-07 15:39:42,058 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-07 15:39:42,060 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-131644-MPEG2TS.stf' is complete, sending simple stream
2012-02-07 15:39:42,060 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Video0226.3gp: MPEG4_P2_TS_ASP_AC3_ISO
2012-02-07 15:39:42,060 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 131644) as read
2012-02-07 15:39:42,062 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-02-07 15:39:42,062 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 18329624
2012-02-07 15:39:42,062 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-07 15:39:42,062 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-65.0/65,Content-Length: 18329624,Date: Tue, 07 Feb 2012 15:39:42 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=65000;]]
2012-02-07 15:39:42,179 DEBUG [WebServer] Incoming connection from /192.168.0.2:56512
2012-02-07 15:39:42,179 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 90775982-25b4-38fa-940e-be80e85deb5a from 192.168.0.2 (headers = [HOST: 192.168.0.4:8895,DATE: Tue, 07 Feb 2012 15:39:39 GMT,CONNECTION: close,USER-AGENT: 6.1.7601 2/Service Pack 1, UPnP/1.0, Portable SDK for UPnP devices/1.6.14])
2012-02-07 15:39:42,179 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-02-07 15:39:42,179 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.4:8895,DATE: Tue, 07 Feb 2012 15:39:39 GMT,CONNECTION: close,USER-AGENT: 6.1.7601 2/Service Pack 1, UPnP/1.0, Portable SDK for UPnP devices/1.6.14]
2012-02-07 15:39:42,180 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-02-07 15:39:42,239 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:02
2012-02-07 15:39:42,351 DEBUG [WebServer] Incoming connection from /192.168.0.50:35075
2012-02-07 15:39:42,352 DEBUG [ResourceTransportRequestHandler] HEAD /resource/131644/MEDIA_ITEM/MPEG4_P2_TS_ASP_AC3_ISO*0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-02-07 15:39:42,352 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2012-02-07 15:39:42,352 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-02-07 15:39:42,352 DEBUG [ResourceTransportRequestHandler] Request for resource 131644 and type 'MEDIA_ITEM' received
2012-02-07 15:39:42,352 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 131644 (local)
2012-02-07 15:39:42,352 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 131644)
2012-02-07 15:39:42,352 DEBUG [VideoDAOImpl] Reading a Video (id = 131644)
2012-02-07 15:39:42,353 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 131644, format MPEG4_P2_TS_ASP_AC3_ISO and profile Samsung TV / player (C/D-series)
2012-02-07 15:39:42,353 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Video0226.3gp
2012-02-07 15:39:42,353 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Video0226.3gp: MPEG4_P2_TS_ASP_AC3_ISO
2012-02-07 15:39:42,353 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 131644)
2012-02-07 15:39:42,353 DEBUG [MediaItemDAOImpl] Getting file of media item 131644
2012-02-07 15:39:42,353 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
AndrewW
Post Tue Feb 07, 2012 4:56 pm
before i forget , this is what the modified part of the profile looks like
<!-- transcode MKV with DST/FLAC audio to AC3, remux into mpeg2ts -->
<Matches container="matroska" vCodec="h264" aCodec="dca" />
<Matches container="mp4" vCodec="h264" aCodec="lpcm" />
<!-- added to get 3gp support -->
Post Tue Feb 07, 2012 8:40 pm
ok thats a shame. try moving the 3gp line up into this section.
<Matches container="3gp" /> <!-- 3gp added here -->
and try again remember ing to restart serviio completely after altering the profiles.xml file.
AndrewW
Post Wed Feb 08, 2012 9:38 am
thansk works, not quite whatyou reccomened but very close
i changed
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
to
Does this need to be fed back to zip so it can be part of the next release ?
If so how is this done ?
Many Thanks
Post Wed Feb 08, 2012 8:28 pm
nope that fine i will do that. :)
