SMP-N100 and pikk screen
Larzendk
Post Sun Feb 05, 2012 10:12 am
Hi there
I just started to play with Serviio and it is a great pices of program.
But i have a problem when i try to stream NASA HD from this link "http://liveips.nasa.gov.edgesuite.net/msfc/Wifi.m3u8" my media player (Sony SMP-N100) is loading for some time and then the screen goes pink (yes pink) and and i can not do anything than pull out the power to reset it.
Any Ideas?
Best regards
Morten
Denmark
NX3
Post Sun Feb 05, 2012 11:20 am
Re: SMP-N100 and pikk screen
Is it only Nasa that makes it go pink or any stream ? If any then I'd suggest you make sure the hdmi is firmly connected at both end and maybe try a different hdmi cable.
Larzendk
Post Sun Feb 05, 2012 11:23 am
No i can see other stream fine, it seems that the box just freezz.
Larzendk
Post Sun Feb 05, 2012 12:37 pm
Well i have tryed a little and here is the result
In the HD channel folder i can see:
Animal HD
Disney xd HD
HBO HD
History HD
These channels makes the box freezz and the screen goes pink, when i wait long enough the box restarts itself:
NASA HD
Commedy central HD
Biography channel HD
HBO 2 HD
Home and garden HD
MGM HD
National geo HD
On these channels i was not able to get a server connection
MTV HD
National geo wild HD
Larzendk
Post Wed Feb 08, 2012 11:38 am
I can not get this to work and now i am desperat.
I have tried both with cable and WIFI with same result
Yesterday i have NASA HD if i change to the genic profile, today pink screen
It is both live stream and RSS feeds that makes my SMP-N100 goes pink and restarts.
I have a idea that the problem is the box because sometime, if i am lucky, i can see some stream and feeds, next time i try i can not, and the box goes pink
Any ideas??
Best regards
Morten
Larzendk
Post Wed Feb 08, 2012 2:42 pm
Can anyone tell me if this has anything to do eith my problems?
Wed Feb 08 08:23:59 CET 2012:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.8.2.2 - (1181258): instance a816c00e-0135-5bd8-f34e-ffff8366333d
on database directory C:\Program Files\Serviio\library\db with class loader sun.misc.Launcher$AppClassLoader@1a16869
Loaded from file:/C:/Program%20Files/Serviio/lib/derby.jar
java.vendor=Sun Microsystems Inc.
java.runtime.version=1.6.0_30-b12
user.dir=C:\Program Files\Serviio\bin
derby.system.home=C:\Program Files\Serviio\bin\\..\library
derby.stream.error.file=../log/derby.log
Database Class Loader started - derby.database.classpath=''
Wed Feb 08 12:23:10 CET 2012: Shutting down Derby engine
Shutting down instance a816c00e-0135-5bd8-f34e-ffff8366333d on database directory C:\Program Files\Serviio\library\db with class loader sun.misc.Launcher$AppClassLoader@1a16869
Larzendk
Post Wed Feb 08, 2012 6:14 pm
Here is a part of my log, what is wrong??
2012-02-08 08:23:57,996 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-02-08 08:23:57,996 INFO [MediaServer] Petr Nejedly 2009-2011
2012-02-08 08:23:57,996 INFO [MediaServer] http://www.serviio.org
2012-02-08 08:23:57,996 INFO [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-02-08 08:23:58,012 INFO [MediaServer] OS Windows 7 x86 6.1
2012-02-08 08:23:58,012 INFO [MediaServer] File encoding: windows-1252
2012-02-08 08:23:58,012 INFO [MediaServer] Headless mode enabled: true
2012-02-08 08:23:58,012 INFO [MediaServer] User home dir: C:\
2012-02-08 08:23:58,012 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-02-08 08:23:58,012 INFO [MediaServer] ------------------------------------------------------------------------
2012-02-08 08:23:58,121 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-02-08 08:23:58,183 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-02-08 08:24:00,898 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-02-08 08:24:01,490 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-02-08 08:24:01,834 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-02-08 08:24:02,036 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-02-08 08:24:02,270 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-02-08 08:24:02,411 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-02-08 08:24:02,504 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-02-08 08:24:02,957 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-02-08 08:24:03,004 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-02-08 08:24:03,394 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-02-08 08:24:04,064 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-02-08 08:24:04,330 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-02-08 08:24:04,564 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-02-08 08:24:04,704 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-02-08 08:24:04,735 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-02-08 08:24:04,844 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-02-08 08:24:04,891 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-02-08 08:24:05,063 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-02-08 08:24:05,141 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-02-08 08:24:05,359 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-02-08 08:24:05,500 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-02-08 08:24:06,046 INFO [WebServer] Socket buffer set to 65535 bytes
2012-02-08 08:24:06,046 INFO [Device] Created UPnP Device with UUID: bf8a35a2-992f-3c96-ba4d-f82c014fc982, bound address: 192.168.15.100
2012-02-08 08:24:06,061 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-02-08 08:24:06,061 INFO [PluginCompilerThread] Started looking for plugins
2012-02-08 08:24:06,514 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-02-08 08:24:07,496 INFO [WebServer] WebServer starting on port 8895
2012-02-08 08:24:07,512 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-08 08:24:07,512 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-08 08:24:07,512 INFO [EventDispatcher] Starting EventDispatcher
2012-02-08 08:24:07,512 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-02-08 08:24:07,512 INFO [RendererSearchSender] Searching for Renderer devices
2012-02-08 08:24:07,580 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.15.100, timeout = 0
2012-02-08 08:24:11,886 INFO [PluginCompilerThread] Added Feed plugin AnOriantUrlExtractor (AnOriant.groovy)
2012-02-08 08:24:11,948 INFO [PluginCompilerThread] Added Feed plugin ARD Mediathek RSS Extractor (ARDMediathek.groovy)
2012-02-08 08:24:12,026 INFO [PluginCompilerThread] Added Feed plugin Arte (Arte.groovy)
2012-02-08 08:24:12,089 INFO [PluginCompilerThread] Added Feed plugin BlipTVUrlExtractor (BlipTVUrlExtractor.groovy)
2012-02-08 08:24:12,214 INFO [PluginCompilerThread] Added Web Resouce plugin CanalPlus (CanalPlus.groovy)
2012-02-08 08:24:12,448 INFO [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy)
2012-02-08 08:24:12,635 INFO [PluginCompilerThread] Added Feed plugin CNN (CNN.groovy)
2012-02-08 08:24:13,930 INFO [PluginCompilerThread] Added Feed plugin Crackle (Crackle.groovy)
2012-02-08 08:24:13,961 INFO [PluginCompilerThread] Added Feed plugin DailyMotion (DailyMotion.groovy)
2012-02-08 08:24:13,992 INFO [PluginCompilerThread] Added Web Resouce plugin Escapist (Escapist.groovy)
2012-02-08 08:24:14,023 INFO [PluginCompilerThread] Added Feed plugin Gamespot (Gamespot.groovy)
2012-02-08 08:24:14,054 INFO [PluginCompilerThread] Added Feed plugin GameTrailers (GameTrailers.groovy)
2012-02-08 08:24:14,086 INFO [PluginCompilerThread] Added Feed plugin Gulli (Gulli.groovy)
2012-02-08 08:24:14,164 INFO [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy)
2012-02-08 08:24:14,195 INFO [PluginCompilerThread] Added Feed plugin Hypem (Hypem.groovy)
2012-02-08 08:24:14,413 INFO [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy)
2012-02-08 08:24:14,429 INFO [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy)
2012-02-08 08:24:14,491 INFO [PluginCompilerThread] Added Web Resouce plugin M6replay (M6replay.groovy)
2012-02-08 08:24:14,710 INFO [PluginCompilerThread] Added Feed plugin MegavideoPlugin (MegavideoPlugin.groovy)
2012-02-08 08:24:14,741 INFO [PluginCompilerThread] Added Feed plugin Orf (Orf.groovy)
2012-02-08 08:24:14,756 INFO [PluginCompilerThread] Added Feed plugin Packers (Packers.groovy)
2012-02-08 08:24:14,990 INFO [PluginCompilerThread] Added Feed plugin PennyArcade (PennyArcade.groovy)
2012-02-08 08:24:15,037 INFO [PluginCompilerThread] Added Feed plugin Pluzz (Pluzz.groovy)
2012-02-08 08:24:15,100 INFO [PluginCompilerThread] Added Feed plugin ReutersCom (ReutersCom.groovy)
2012-02-08 08:24:15,146 INFO [PluginCompilerThread] Added Feed plugin RTVE (RTVE.groovy)
2012-02-08 08:24:15,209 INFO [PluginCompilerThread] Added Feed plugin SC2CastUrlExctractor (SC2Casts.groovy)
2012-02-08 08:24:15,240 INFO [PluginCompilerThread] Added Web Resouce plugin Shoutcast (Shoutcast.groovy)
2012-02-08 08:24:15,256 INFO [PluginCompilerThread] Added Feed plugin SnotrUrlExtractor (Snotr.groovy)
2012-02-08 08:24:15,287 INFO [PluginCompilerThread] Added Feed plugin SvtPlay (SvtPlay.groovy)
2012-02-08 08:24:15,334 INFO [PluginCompilerThread] Added Feed plugin TF1 (TF1.groovy)
2012-02-08 08:24:15,412 INFO [PluginCompilerThread] Added Feed plugin TrailerAddictRss (TrailerAddictRss.groovy)
2012-02-08 08:24:15,443 INFO [PluginCompilerThread] Added Web Resouce plugin Tune In (TuneIn.groovy)
2012-02-08 08:24:15,599 INFO [PluginCompilerThread] Added Feed plugin Tv3Play (Tv3Play.groovy)
2012-02-08 08:24:15,646 INFO [PluginCompilerThread] Added Feed plugin Tv4Play (Tv4Play.groovy)
2012-02-08 08:24:16,940 INFO [PluginCompilerThread] Added Feed plugin Tv6Play (Tv6Play.groovy)
2012-02-08 08:24:16,972 INFO [PluginCompilerThread] Added Feed plugin Tv8Play (Tv8Play.groovy)
2012-02-08 08:24:17,003 INFO [PluginCompilerThread] Added Feed plugin Vimeo (Vimeo.groovy)
2012-02-08 08:24:17,034 INFO [PluginCompilerThread] Added Web Resouce plugin W9replay (W9replay.groovy)
2012-02-08 08:24:17,065 INFO [PluginCompilerThread] Added Feed plugin WAT (WAT.groovy)
2012-02-08 08:24:17,096 INFO [PluginCompilerThread] Added Feed plugin WimpCom (WimpCom.groovy)
2012-02-08 08:24:17,159 INFO [PluginCompilerThread] Added Feed plugin Yahoo Movies (YahooMovies.groovy)
2012-02-08 08:24:17,206 INFO [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy)
2012-02-08 08:24:33,818 INFO [ServiioConsole] Starting Serviio Console
2012-02-08 08:24:34,083 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-02-08 08:24:35,207 INFO [Messages] Loaded console message bundle for locale: da
2012-02-08 08:24:35,285 INFO [UpdateChecker] Checking if a new version is available
2012-02-08 08:24:37,414 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-02-08 08:24:37,435 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-02-08 08:24:37,459 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-02-08 08:24:38,605 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-02-08 08:24:39,071 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: da
2012-02-08 08:24:57,241 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://46.105.109.122/edge swfUrl=http://static.ilive.to/jwplayer/player.swf pageURL=http://www.ilive.to/ playpath=7f14kif8m902om7 swfVfy=0 live=1. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:273)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:255)
... 2 more
2012-02-08 08:25:31,124 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://live.dmasti.pk/ent2 swfUrl=http://www.f4funda.com/player.swf pageURL=http://www.f4funda.com/ playpath=livestream swfVfy=0 live=1. It might not play.
... 2 more
2012-02-08 08:26:03,036 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://s6.webport.tv/live/z050002.stream app=live swfUrl=http://blah.com/player.swf tcUrl=rtmp://s6.webport.tv/live/ pageUrl=http://www.tvsector.com/ swfVfy=0 live=1. It might not play.
... 2 more
2012-02-08 08:26:35,950 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://ustreamvip.fc.llnwd.net/ustreamvip playpath=ustreamvip_llnw_live_1_90331614 swfUrl=http://static-cdn1.ustream.tv/swf/live/viewer.rsl:96.swf swfVfy=1 live=1. It might not play.
... 2 more
2012-02-08 12:06:51,840 WARN [ProcessExecutor] Process cmd has a return code of -1! This is a possible error.
2012-02-08 12:13:47,442 INFO [UpdateChecker] Checking if a new version is available
2012-02-08 12:14:36,686 INFO [WebServer] WebServer shutting down
2012-02-08 12:14:36,686 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-08 12:14:36,686 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-08 12:14:36,687 INFO [EventDispatcher] Leaving EventDispatcher
2012-02-08 12:14:36,984 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-08 12:14:36,984 INFO [WebServer] WebServer starting on port 8895
2012-02-08 12:14:37,000 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-08 12:14:37,000 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-08 12:14:36,984 INFO [EventDispatcher] Starting EventDispatcher
2012-02-08 12:14:36,984 INFO [RendererSearchSender] Searching for Renderer devices
2012-02-08 12:14:37,015 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.15.100, timeout = 0
2012-02-08 12:14:37,032 INFO [UpdateChecker] Checking if a new version is available
2012-02-08 12:14:40,355 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-02-08 12:14:53,942 WARN [ContentDirectory] Object with id 2 doesn't exist
2012-02-08 12:14:59,668 WARN [ContentDirectory] Object with id 2 doesn't exist
2012-02-08 12:15:32,364 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-08 12:15:32,365 INFO [WebServer] WebServer shutting down
2012-02-08 12:15:32,365 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-08 12:15:32,365 INFO [EventDispatcher] Leaving EventDispatcher
2012-02-08 12:15:32,678 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-08 12:15:35,752 INFO [WebServer] WebServer starting on port 8895
2012-02-08 12:15:35,752 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-08 12:15:35,752 INFO [EventDispatcher] Starting EventDispatcher
2012-02-08 12:15:35,783 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-08 12:15:35,752 INFO [RendererSearchSender] Searching for Renderer devices
2012-02-08 12:15:35,798 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.15.100, timeout = 0
2012-02-08 12:15:55,616 WARN [ContentDirectory] Object with id 2 doesn't exist
2012-02-08 12:16:09,307 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-02-08 12:16:09,407 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-02-08 12:16:09,507 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-02-08 12:16:09,511 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-02-08 12:16:13,815 WARN [ContentDirectory] Object with id 2 doesn't exist
2012-02-08 12:16:59,781 WARN [ContentDirectory] Object with id 2 doesn't exist
2012-02-08 12:17:27,615 INFO [WebServer] WebServer shutting down
2012-02-08 12:17:27,615 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-08 12:17:27,615 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-08 12:17:27,615 INFO [EventDispatcher] Leaving EventDispatcher
2012-02-08 12:17:27,927 INFO [UpdateChecker] Checking if a new version is available
2012-02-08 12:17:27,927 INFO [WebServer] WebServer starting on port 8895
2012-02-08 12:17:27,927 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-08 12:17:27,958 INFO [RendererSearchSender] Searching for Renderer devices
2012-02-08 12:17:27,958 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-08 12:17:27,958 INFO [EventDispatcher] Starting EventDispatcher
2012-02-08 12:17:27,958 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.15.100, timeout = 0
2012-02-08 12:17:41,917 INFO [UpdateChecker] Checking if a new version is available
2012-02-08 12:18:09,114 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-08 12:18:09,114 INFO [EventDispatcher] Leaving EventDispatcher
2012-02-08 12:18:09,115 INFO [WebServer] WebServer shutting down
2012-02-08 12:18:09,116 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-08 12:18:09,419 INFO [UpdateChecker] Checking if a new version is available
2012-02-08 12:18:09,456 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-08 12:18:09,457 INFO [WebServer] WebServer starting on port 8895
2012-02-08 12:18:09,458 INFO [EventDispatcher] Starting EventDispatcher
2012-02-08 12:18:09,458 INFO [RendererSearchSender] Searching for Renderer devices
2012-02-08 12:18:09,459 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-08 12:18:09,459 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-08 12:18:09,493 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.15.100, timeout = 0
2012-02-08 12:18:20,514 WARN [ContentDirectory] Object with id 2 doesn't exist
2012-02-08 12:18:31,087 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-08 12:18:40,697 INFO [UpdateChecker] Checking if a new version is available
2012-02-08 12:18:45,791 WARN [ContentDirectory] Object with id 2 doesn't exist
2012-02-08 12:19:15,154 INFO [WebServer] WebServer shutting down
2012-02-08 12:19:15,156 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-08 12:19:15,156 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-08 12:19:15,157 INFO [EventDispatcher] Leaving EventDispatcher
2012-02-08 12:19:15,469 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-08 12:19:15,469 INFO [WebServer] WebServer starting on port 8895
2012-02-08 12:19:15,469 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-08 12:19:15,469 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-08 12:19:15,469 INFO [RendererSearchSender] Searching for Renderer devices
2012-02-08 12:19:15,469 INFO [EventDispatcher] Starting EventDispatcher
2012-02-08 12:19:15,502 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.15.100, timeout = 0
2012-02-08 12:19:15,518 INFO [UpdateChecker] Checking if a new version is available
2012-02-08 12:23:09,691 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-02-08 12:23:09,691 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-02-08 12:23:09,693 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-02-08 12:23:09,791 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-02-08 12:23:09,891 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-02-08 12:23:09,991 INFO [PluginCompilerThread] Finished looking for plugins
2012-02-08 12:23:10,091 INFO [EventDispatcher] Leaving EventDispatcher
2012-02-08 12:23:10,092 INFO [WebServer] WebServer shutting down
2012-02-08 12:23:10,092 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-08 12:23:10,093 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-08 12:23:10,391 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-08 12:23:10,391 INFO [DatabaseManager] Shutting down database
2012-02-08 12:23:10,625 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-02-08 12:23:24,369 INFO [ServiioConsole] Leaving Serviio Console
2012-02-08 18:38:55,932 INFO [MediaServer]
