REstart SErviio Service at TV Device
It would be great if the there was a "Restart" Button on the TV device, for Serviio Server / Service, and not have to use WEb UI or Remote access the the Computer which Serviio SErver is running.
will wrote:As for your actual question, I guess it is technically possiable to have a Tools browsing category with refresh library, refresh online sources, restart DLNA service, but no idea if it would be implemented.
will wrote:Online sources can be refreshed manaually via the console and are done automaitcally after the exiry interval, you shouldn't have to restart Serviio. If the only way you can refresh online sources is by restarting serviio then something isn't working.
You could lower your expiry interval for online sources. Or if you have an android phone, use the app I wrote to refresh sources.
