Canal+ (France)
Post Thu Feb 02, 2012 7:16 pm
Canal+ (France)
Source Type: Web Resource
Source Url : see Note, or click on Image icon to add serviio link
Media Type : Video
Canal+ plugin supports 3 quality levels : LOW, MEDIUM, HIGH. you can select on serviio console.
CanalPlus.groovy
Version 1.2 (22-02-2013) : Add version, Add search request.
(9.77 KiB) Downloaded 2796 times
Note:*
Select by program:
TOUT LE FOOTBALL : Source Url = http://player.canalplus.fr/#/sport/tout-le-football Image
LES DENIERES BANDES ANNONCES : Source Url = http://player.canalplus.fr/#/cinema/der ... s-annonces Image
LE GRAND JOURNAL : Source Url = http://player.canalplus.fr/#/emissions/le-grand-journal
LES GUIGNOLS : Source Url = http://player.canalplus.fr/#/divertisse ... s-guignols
Select by search request :
http://player.canalplus.fr/#/search/<search word> (set "%20" for space)
le petit journal : Source Url =http://player.canalplus.fr/#/search/le%20petit%20journal
groland.con : Source Url =http://player.canalplus.fr/#/search/groland.con
Zapping : Source Url =http://player.canalplus.fr/#/search/zapping Image
_
esquimooo
Post Sun Feb 05, 2012 9:07 pm
Re: Canal+ (France)
Thanks for this plugin. Works perfectly! :D
If it is not too much to ask, could it be possible to extend it to collect also the videos under URLs like:
http://player.canalplus.fr/#/emissions/bref
This would allow to see also the latest videos available without changing the online sources in the Serviio console.
Thanks!
Post Wed Feb 08, 2012 5:00 pm
Re: Canal+ (France)
esquimooo wrote:This would allow to see also the latest videos available without changing the online sources in the Serviio console.
You're right, should be better, I will have a look!
Post Thu Feb 09, 2012 10:11 pm
Re: Canal+ (France)
Plugin Updated
nicoqc
Post Fri Feb 10, 2012 5:21 pm
Re: Canal+ (France)
I don't see the associated sources on my PS3 after adding any "Source Url" field on Serviio console. Server restart and reboot did not fix this either.
Canal+ Player is working well in my pc browser though, so it does not seem to be related to any location issue (I am not in France).
Any idea?
Post Fri Feb 10, 2012 5:47 pm
Re: Canal+ (France)
Could you post serviio detailed log ?
nicoqc
Post Fri Feb 10, 2012 6:04 pm
Re: Canal+ (France)
I am seeing the following error traces:
2012-02-10 13:01:32,087 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://player.canalplus.fr/#/divertissement/les-emissions. Message: Error during feed parsing, provided URL probably doesn't point to a valid RSS/Atom feed. Message: Invalid XML
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:177)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:184)
   at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:158)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:95)
nicoqc
Post Fri Feb 10, 2012 6:19 pm
Re: Canal+ (France)
Found my problem: bad configuration of Source Type!
Changed to Web Resource and it is now working flawlessly. :D
goyon2000
Post Tue Feb 21, 2012 9:57 am
Re: Canal+ (France)
Hello
I am using servioo on my synology and with my Samsung TV. This plugins seems not to be working. What do I have to check ? send the server log file ?
Thank you
Post Tue Feb 21, 2012 10:18 am
Re: Canal+ (France)
goyon2000 wrote:I am using servioo on my synology and with my Samsung TV. This plugins seems not to be working. What do I have to check ? send the server log file ?
Yes, stop serviio service, clean the log file, enable detailed logging, restart serviio service, and post log file after few minutes.
Do you set "Web Resource" on Source Type on serviio console ?
What is your region ?
goyon2000
Post Tue Feb 21, 2012 10:34 am
Re: Canal+ (France)
Ok I will try to send log file tonight or tomorrow.
Yes I am using web resources and I am located in Switzerland (I speak french .... (;=)
goyon2000
Post Tue Feb 21, 2012 1:30 pm
Re: Canal+ (France)
One more question: what permission/owner must have the groovy file ?
Post Tue Feb 21, 2012 2:24 pm
Re: Canal+ (France)
goyon2000 wrote:One more question: what permission/owner must have the groovy file ?
Don't really know... I would say same than "serviio.jar". (btw, I'm not a Java dev)
Why this question...is it for security issue ?
goyon2000
Post Tue Feb 21, 2012 3:18 pm
Re: Canal+ (France)
No only to be sure that serviio can access it.
goyon2000
Post Thu Feb 23, 2012 10:29 am
Re: Canal+ (France)
Hello
Sorry, In fact it is working very well. I have only one problem ... in fact I think that for online content video are transcoded ? correct ?
I think the CPU of my synology is not enough powerful . I am going to try with another PC
Thank you
Post Thu Feb 23, 2012 10:41 am
Re: Canal+ (France)
goyon2000 wrote:Hello
Thank you
Yes online content are always transcoded.
You can try to change on serviio console the preferred Quality to MEDIUM or LOW.
goyon2000
Post Thu Feb 23, 2012 11:22 am
Re: Canal+ (France)
Thank you
Ok I will try. As it seems that you have done also the plugins for M6replay and NBA. can I use also LOW for them too ?
Thank you for all your answers and your work
Post Thu Feb 23, 2012 11:37 am
Re: Canal+ (France)
goyon2000 wrote:Ok I will try. As it seems that you have done also the plugins for M6replay and NBA. can I use also LOW for them too ?
No, M6replay Catalogue and NBA Rss feed only provide one resolution, so Preferred Quality value on console will be ignored by these plugins.
samcro49
Post Mon Mar 05, 2012 8:24 am
Re: Canal+ (France)
Bonjour
comment faire pour le sav des emissions
j'ai reussi pour bref et les guignols mais le sav ne marche pas
Post Fri Mar 09, 2012 2:02 pm
Re: Canal+ (France)
Le "SAV des emissions" n'a pas de rubrique spécifique dans le catalogue Canal Plus Player.
Le seul moyen de les retrouver est de sélectionner l'une des rubriques suivantes:
http://player.canalplus.fr/#/divertisse ... tournables
http://player.canalplus.fr/#/divertisse ... nd-journal
http://player.canalplus.fr/#/divertisse ... -emissions
http://player.canalplus.fr/#/emissions/ ... -emissions
Return to Available plugins
