Re: MKV files stutter.
zip wrote:can someone capture packets...
What would be the easiest way to do such a capture? Using Wireshark?
sunnyday wrote:zip wrote:can someone capture packets...
sunnyday wrote:serviio.log reports default is 65535 bytes (that is 2^16-1)
Have tried:
-Dserviio.socketBuffer=32267 (2^15-1)
-Dserviio.socketBuffer=131071 (2^17-1)
-Dserviio.socketBuffer=262143 (2^18-1)
Change of buffer size is reflected in serviio.log upon start, but mkv stuttering problem remains for all buffer sizes above.
Does this setting solve it for anybody else?
zip wrote:can someone capture packets of browsing to the file and few seconds of playing in tvmobili? it's possible they're using other mime-type that stream the file differently.
GET /__contentStream/c652f920c25b0640c27dc48f640f44c5/TVMOBiLi/s0-72223y25z1319667054 HTTP/1.0
Range: bytes=6769-
getcontentFeatures.dlna.org: 1
transferMode.dlna.org: Streaming
Host: 192.168.1.12:30888
HTTP/1.0 206 Partial Content
Content-Type: video/x-mkv
Content-Range: bytes 6769-21756464700/21756464701
contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000
TransferMode.DLNA.ORG: Streaming
Server: Microsoft Windows/6.1.7601 UPnP/1.0 TVMOBiLi UPnP Server/2.1.3437
Content-length: 21756457932
%.!....D.........gd.)..`............<`.h....h.{<....,.....(.E....H..,. .#..x264 - core 118 r2085 8a62835 - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=5 deblock=1:-3:-2 analyse=0x3:0x113 me=umh subme=9 psy=1 psy_rd=1.00:0.15 mixed_ref=1 me_range=24 chroma_me=1 trellis=2 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-3 threads=6 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=8 b_pyramid=2 b_adapt=2 b_bias=0 direct=3 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=2pass mbtree=0 bitrate=17283 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 cplxblur=20.0 qblur=0.5 vbv_maxrate=40000 vbv_bufsize=40000 nal_hrd=none ip_ratio=1.40 pb_ratio=1.30 aq=1:0.85 zones=212283,221521,q=32,deblock=1:2.....Ae..........[O...;..~t.j.GET /resource/9728/MEDIA_ITEM/MATROSKA*0 HTTP/1.0
Range: bytes=6769-
Host: 192.168.1.12:8895
HTTP/1.1 206 Partial Content
Content-Length: 21756457932
Date: Mon, 13 Feb 2012 14:53:00 GMT
Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2
Cache-control: no-cache
contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000
%.!....D.........gd.)..`............<`.h....h.{<....,.....(.E....H..,. .#..x264 - core 118 r2085 8a62835 - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=5 deblock=1:-3:-2 analyse=0x3:0x113 me=umh subme=9 psy=1 psy_rd=1.00:0.15 mixed_ref=1 me_range=24 chroma_me=1 trellis=2 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-3 threads=6 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=8 b_pyramid=2 b_adapt=2 b_bias=0 direct=3 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=2pass mbtree=0 bitrate=17283 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 cplxblur=20.0 qblur=0.5 vbv_maxrate=40000 vbv_bufsize=40000 nal_hrd=none ip_ratio=1.40 pb_ratio=1.30 aq=1:0.85 zones=212283,221521,q=32,deblock=1:2.....Ae..........[O...;..~t.j.zip wrote:ok, so it's exactly the same. It might be down to the network IO performance in terms of buffering or whatnot. You could try to 'download' the mkv file from the 2 servers using the above GET URLs and compare the download speed if there is any significant difference.
boggie wrote:Did anybody manage to find a fix for this?
You can add me to the list, since I'm having the same issues. D550 tv that stutters on wired connection with mkv files, as well as on other media servers (PS3 media share, Wild media server, Samsung Allshare), but works perfectly with TVmobili with no transcoding.
ripple wrote:As a new owner of a PN51D550 I have been following this thread since ditching the Allshare junk for Serviio after a day of messing with it.
I also have stuttering with mkv's and I am using a wired connection.
One thing I am wondering is what is the spec of the LAN port of the TV? I cannot find it anywhere and my gigabit switch does not differentiate 100 or 1000 by LED link color, only 10 shows orange.
Interestingly, I finally plugged in my BD-D5500 that I bought with the TV, and when I play the same mkv files via the same wired connection on that, they play flawlessly. Not sure of the LAN port speed on that either.
Just wondering if the LAN port has anything to do with it.
jabrown0604 wrote: I normally use MakeMKV and then remux and shrink it with handbrake.
jabrown0604 wrote: The file I created that stutters came directly from an ISO through handbrake rather than a larger MKV...
zip wrote:I've replicated the wikipedia article with an example here: http://wiki.serviio.org/doku.php?id=get_h264_level
