Help wanted for SMP-N100 and live streaming
Larzendk
Post Thu Feb 09, 2012 10:01 am
Hi there
I have just startet to use Serviio to play movies from my NAS harddisk and it works fine.
But when i try to stream live feeds/RSS the unit very offent makes a pink screen om my TV and after a while its restarts.
Sometime, if i am very very lucky, a can get a channel to play, but if i stop and try another channel or try the same channel again if goes pink.
it does not matter if it is HD channel or regular channels it goes pink no matter what.
I have tryed both with WIFI and cabel and it does not make a driffrent
I have tryed to run Servioo on diffrent computers, but it does not help.
I have updatet it with the latest plugin and groovey files, no luck.
I have tryed to turn off the firewall, but with no luck.
I am useing the Sony BD/SMP profile, but i have tryed them all.
Can anyone, please, tell me what is wrong , or what i am doing wrong.
Here is a part of my log if thats helps
Best regards Morten
2012-02-09 10:20:15,999 INFO  [MediaServer] ------------------------------------------------------------------------
2012-02-09 10:20:16,389 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-02-09 10:20:16,389 INFO  [MediaServer] Petr Nejedly 2009-2011
2012-02-09 10:20:16,389 INFO  [MediaServer] http://www.serviio.org
2012-02-09 10:20:16,389 INFO  [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-02-09 10:20:16,389 INFO  [MediaServer] OS Windows 7 x86 6.1
2012-02-09 10:20:16,389 INFO  [MediaServer] File encoding: windows-1252
2012-02-09 10:20:16,405 INFO  [MediaServer] Headless mode enabled: true
2012-02-09 10:20:16,405 INFO  [MediaServer] User home dir: C:\
2012-02-09 10:20:16,405 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2012-02-09 10:20:16,405 INFO  [MediaServer] ------------------------------------------------------------------------
2012-02-09 10:20:17,169 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2012-02-09 10:20:17,232 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-02-09 10:20:22,255 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-02-09 10:20:22,723 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-02-09 10:20:22,988 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-02-09 10:20:23,175 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-02-09 10:20:23,394 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-02-09 10:20:23,518 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-02-09 10:20:23,612 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-02-09 10:20:24,033 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-02-09 10:20:24,064 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-02-09 10:20:24,501 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-02-09 10:20:25,078 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-02-09 10:20:25,344 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-02-09 10:20:25,593 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-02-09 10:20:25,718 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-02-09 10:20:25,749 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-02-09 10:20:25,858 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-02-09 10:20:25,921 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-02-09 10:20:26,092 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-02-09 10:20:26,186 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-02-09 10:20:26,420 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-02-09 10:20:26,607 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-02-09 10:20:27,352 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-02-09 10:20:27,352 INFO  [Device] Created UPnP Device with UUID: 12486d15-079e-3f2f-932c-6be88964d93a, bound address: 127.0.0.1
2012-02-09 10:20:27,739 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-02-09 10:20:27,739 INFO  [PluginCompilerThread] Started looking for plugins
2012-02-09 10:20:32,668 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-02-09 10:20:33,870 INFO  [WebServer] WebServer starting on port 8895
2012-02-09 10:20:33,870 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-09 10:20:33,885 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-09 10:20:33,885 INFO  [EventDispatcher] Starting EventDispatcher
2012-02-09 10:20:33,885 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface lo (Software Loopback Interface 1) and address 127.0.0.1, timeout = 0
2012-02-09 10:20:33,965 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2012-02-09 10:20:33,965 INFO  [RendererSearchSender] Searching for Renderer devices
2012-02-09 10:20:34,215 INFO  [PluginCompilerThread] Added Feed plugin AnOriantUrlExtractor (AnOriant.groovy)
2012-02-09 10:20:34,340 INFO  [PluginCompilerThread] Added Feed plugin ARD Mediathek RSS Extractor (ARDMediathek.groovy)
2012-02-09 10:20:34,464 INFO  [PluginCompilerThread] Added Feed plugin Arte (Arte.groovy)
2012-02-09 10:20:34,527 INFO  [PluginCompilerThread] Added Feed plugin BlipTVUrlExtractor (BlipTVUrlExtractor.groovy)
2012-02-09 10:20:34,636 INFO  [PluginCompilerThread] Added Web Resouce plugin CanalPlus (CanalPlus.groovy)
2012-02-09 10:20:34,886 INFO  [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy)
2012-02-09 10:20:35,042 INFO  [PluginCompilerThread] Added Feed plugin CNN (CNN.groovy)
2012-02-09 10:20:35,073 INFO  [PluginCompilerThread] Added Feed plugin Crackle (Crackle.groovy)
2012-02-09 10:20:35,120 INFO  [PluginCompilerThread] Added Feed plugin DailyMotion (DailyMotion.groovy)
2012-02-09 10:20:35,229 INFO  [PluginCompilerThread] Added Web Resouce plugin Escapist (Escapist.groovy)
2012-02-09 10:20:35,276 INFO  [PluginCompilerThread] Added Feed plugin Gamespot (Gamespot.groovy)
2012-02-09 10:20:35,291 INFO  [PluginCompilerThread] Added Feed plugin GameTrailers (GameTrailers.groovy)
2012-02-09 10:20:35,354 INFO  [PluginCompilerThread] Added Feed plugin Gulli (Gulli.groovy)
2012-02-09 10:20:35,432 INFO  [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy)
2012-02-09 10:20:35,463 INFO  [PluginCompilerThread] Added Feed plugin Hypem (Hypem.groovy)
2012-02-09 10:20:35,822 INFO  [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy)
2012-02-09 10:20:35,853 INFO  [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy)
2012-02-09 10:20:36,243 INFO  [PluginCompilerThread] Added Web Resouce plugin M6replay (M6replay.groovy)
2012-02-09 10:20:36,383 INFO  [PluginCompilerThread] Added Feed plugin MegavideoPlugin (MegavideoPlugin.groovy)
2012-02-09 10:20:36,508 INFO  [PluginCompilerThread] Added Feed plugin Orf (Orf.groovy)
2012-02-09 10:20:36,539 INFO  [PluginCompilerThread] Added Feed plugin Packers (Packers.groovy)
2012-02-09 10:20:36,898 INFO  [PluginCompilerThread] Added Feed plugin PennyArcade (PennyArcade.groovy)
2012-02-09 10:20:36,976 INFO  [PluginCompilerThread] Added Feed plugin Pluzz (Pluzz.groovy)
2012-02-09 10:20:37,007 INFO  [PluginCompilerThread] Added Feed plugin ReutersCom (ReutersCom.groovy)
2012-02-09 10:20:37,148 INFO  [PluginCompilerThread] Added Feed plugin RTVE (RTVE.groovy)
2012-02-09 10:20:37,226 INFO  [PluginCompilerThread] Added Feed plugin SC2CastUrlExctractor (SC2Casts.groovy)
2012-02-09 10:20:37,678 INFO  [PluginCompilerThread] Added Web Resouce plugin Shoutcast (Shoutcast.groovy)
2012-02-09 10:20:37,709 INFO  [PluginCompilerThread] Added Feed plugin SnotrUrlExtractor (Snotr.groovy)
2012-02-09 10:20:37,740 INFO  [PluginCompilerThread] Added Feed plugin SvtPlay (SvtPlay.groovy)
2012-02-09 10:20:37,865 INFO  [PluginCompilerThread] Added Feed plugin TF1 (TF1.groovy)
2012-02-09 10:20:37,896 INFO  [PluginCompilerThread] Added Feed plugin TrailerAddictRss (TrailerAddictRss.groovy)
2012-02-09 10:20:37,943 INFO  [PluginCompilerThread] Added Web Resouce plugin Tune In (TuneIn.groovy)
2012-02-09 10:20:37,990 INFO  [PluginCompilerThread] Added Feed plugin Tv3Play (Tv3Play.groovy)
2012-02-09 10:20:38,037 INFO  [PluginCompilerThread] Added Feed plugin Tv4Play (Tv4Play.groovy)
2012-02-09 10:20:38,115 INFO  [PluginCompilerThread] Added Feed plugin Tv6Play (Tv6Play.groovy)
2012-02-09 10:20:38,162 INFO  [ServiioConsole] Starting Serviio Console
2012-02-09 10:20:38,177 INFO  [PluginCompilerThread] Added Feed plugin Tv8Play (Tv8Play.groovy)
2012-02-09 10:20:38,193 INFO  [PluginCompilerThread] Added Feed plugin Vimeo (Vimeo.groovy)
2012-02-09 10:20:38,271 INFO  [PluginCompilerThread] Added Web Resouce plugin W9replay (W9replay.groovy)
2012-02-09 10:20:39,690 INFO  [PluginCompilerThread] Added Feed plugin WAT (WAT.groovy)
2012-02-09 10:20:39,706 INFO  [PluginCompilerThread] Added Feed plugin WimpCom (WimpCom.groovy)
2012-02-09 10:20:39,768 INFO  [PluginCompilerThread] Added Feed plugin Yahoo Movies (YahooMovies.groovy)
2012-02-09 10:20:39,846 INFO  [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy)
2012-02-09 10:20:42,015 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-02-09 10:20:42,842 INFO  [Messages] Loaded console message bundle for locale: da
2012-02-09 10:20:42,857 INFO  [UpdateChecker] Checking if a new version is available
2012-02-09 10:20:53,886 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-02-09 10:20:54,354 INFO  [FeedUpdaterThread] Started looking for information about online resources
2012-02-09 10:20:54,370 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-02-09 10:20:54,370 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-02-09 10:20:54,432 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: da
2012-02-09 10:20:56,211 INFO  [LibraryUpdatesCheckerThread] Removing 'Rise of the planet of the apes' (\\LS-CHL061\share\Film\Rise of the planet of the apes.mkv) from Library
2012-02-09 10:20:59,268 INFO  [LibraryUpdatesCheckerThread] Removing 'Spaceballs' (\\LS-CHL061\share\Film\Spaceballs.mkv) from Library
2012-02-09 10:20:59,346 INFO  [LibraryUpdatesCheckerThread] Removing '2012 HD 1080' (\\LS-CHL061\share\Film\2012 HD 1080.mkv) from Library
2012-02-09 10:20:59,424 INFO  [LibraryUpdatesCheckerThread] Removing 'Flammen og Citron HD 1080' (\\LS-CHL061\share\Film\Flammen og Citron HD 1080.mkv) from Library
2012-02-09 10:20:59,783 INFO  [LibraryUpdatesCheckerThread] Removing 'GIjoe' (\\LS-CHL061\share\Film\GIjoe.mkv) from Library
2012-02-09 10:20:59,846 INFO  [LibraryUpdatesCheckerThread] Removing 'smokey-superclasico' (\\LS-CHL061\share\Film\smokey-superclasico.mkv) from Library
2012-02-09 10:20:59,924 INFO  [LibraryUpdatesCheckerThread] Removing 'Super 8' (\\LS-CHL061\share\Film\Super 8.mkv) from Library
2012-02-09 10:21:00,033 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.net.UnknownHostException: sites.google.com
   at java.net.PlainSocketImpl.connect(Unknown Source)
   at java.net.SocksSocketImpl.connect(Unknown Source)
   at java.net.Socket.connect(Unknown Source)
   at com.sun.net.ssl.internal.ssl.SSLSocketImpl.connect(Unknown Source)
   at sun.net.NetworkClient.doConnect(Unknown Source)
   at sun.net.www.http.HttpClient.openServer(Unknown Source)
   at sun.net.www.protocol.https.HttpsClient.<init>(Unknown Source)
   at sun.net.www.protocol.https.HttpsClient.New(Unknown Source)
   at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(Unknown Source)
   at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
   at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
   at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown Source)
   at org.serviio.util.HttpClient.retrieveBinaryFileFromURL(HttpClient.java:73)
   at org.serviio.library.online.feed.FeedParser.parseFeedStream(FeedParser.java:115)
   at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:90)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:167)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:184)
   at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:158)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:95)
2012-02-09 10:21:00,048 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
2012-02-09 10:21:00,064 INFO  [LibraryUpdatesCheckerThread] Removing 'Saturday Night Fever HD 1080' (\\LS-CHL061\share\Film\Saturday Night Fever HD 1080.mkv) from Library
2012-02-09 10:21:00,142 INFO  [LibraryUpdatesCheckerThread] Removing 'Johnny English 2' (\\LS-CHL061\share\Film\Johnny English 2.mkv) from Library
2012-02-09 10:22:14,125 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmp://46.105.109.122/edge swfUrl=http://static.ilive.to/jwplayer/player.swf pageURL=http://www.ilive.to/ playpath=7f14kif8m902om7 swfVfy=0 live=1. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:273)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:255)
   ... 2 more
2012-02-09 10:22:51,005 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmp://live.dmasti.pk/ent2 swfUrl=http://www.f4funda.com/player.swf pageURL=http://www.f4funda.com/ playpath=livestream swfVfy=0 live=1. It might not play.
   ... 2 more
2012-02-09 10:22:55,033 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmp://s6.webport.tv/live/z050002.stream app=live swfUrl=http://blah.com/player.swf tcUrl=rtmp://s6.webport.tv/live/ pageUrl=http://www.tvsector.com/ swfVfy=0 live=1. It might not play.
   ... 2 more
2012-02-09 10:23:27,877 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmp://ustreamvip.fc.llnwd.net/ustreamvip playpath=ustreamvip_llnw_live_1_90331614 swfUrl=http://static-cdn1.ustream.tv/swf/live/viewer.rsl:96.swf swfVfy=1 live=1. It might not play.
   ... 2 more
Post Thu Feb 09, 2012 11:21 am
Re: Help wanted for SMP-N100 and live streaming
I did not have such problem with my SMP-N100 (90% used with local files - Online stream were with my Bravia TV).
Could you give us a specific Rss feed Url and plugin you used to reproduce it ?
Post Thu Feb 09, 2012 11:38 am
https is not supported, you have to use http.
Larzendk
Post Thu Feb 09, 2012 12:38 pm
Hi
@ZIP: Ok i was avare of this, i have just copy the link direct from the livestrream library RSS folder.
@Illico: All rss feed url and plugins is taken direct from this forum from the livestream library rss folder and the all plugins pack.
it is not just one fedd that dont work it is all, but when i am extrem lucky i can get one to work, when i try another another one or i went back to the one that works its pink screen.
I will try to change https to http and see if thats helps.
Thanks for your respont.
Larzendk
Post Thu Feb 09, 2012 12:49 pm
One of the feeds that is killing me is NASA HD and it has not Https but http in the adress and again it is taken direct from the forum "http://liveips.nasa.gov.edgesuite.net/mfsc/Wifi.m3u8" and, yes serviio is set to livestream on this one, again on rare occations it is working, but mostly not.
Post Thu Feb 09, 2012 12:58 pm
Larzendk wrote:it is taken direct from the forum "http://liveips.nasa.gov.edgesuite.net/mfsc/Wifi.m3u8" and, yes serviio is set to livestream on this one, again on rare occations it is working, but mostly not.
Ok thanks, I will look after work...
Larzendk
Post Thu Feb 09, 2012 1:15 pm
i have just tryed to change all the https to http, and in the start it helps, i got 3 channels in row to run (animal HD, commedy central HD and disney xd HD) but then the unit starts to make pink screen again, also on the 3 channels that worked before, what the f... is wrong with that thing?
Larzendk
Post Thu Feb 09, 2012 1:47 pm
I dont know if these errors has any thing to say?
2012-02-09 14:40:28,678 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://ustreamvip.fc.llnwd.net/ustreamvip playpath=ustreamvip_llnw_live_1_90331614 swfUrl=http://static-cdn1.ustream.tv/swf/live/viewer.rsl:96.swf swfVfy=1 live=1. It might not play.
... 2 more
2012-02-09 14:42:23,600 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2012-02-09 14:43:32,071 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2012-02-09 14:44:37,460 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2012-02-09 14:44:55,229 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-02-09 14:44:55,231 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-02-09 14:44:55,238 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-02-09 14:44:55,337 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-02-09 14:44:55,437 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-02-09 14:44:55,537 INFO [PluginCompilerThread] Finished looking for plugins
2012-02-09 14:44:55,637 INFO [WebServer] WebServer shutting down
2012-02-09 14:44:55,637 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-09 14:44:55,638 INFO [EventDispatcher] Leaving EventDispatcher
2012-02-09 14:44:55,638 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-09 14:44:55,842 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-09 14:44:55,982 INFO [DatabaseManager] Shutting down database
2012-02-09 14:44:56,185 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
Post Thu Feb 09, 2012 2:39 pm
Could you try locally in windows terminal this command line :
ffmpeg.exe -i "rtmp://ustreamvip.fc.llnwd.net/ustreamvip playpath=ustreamvip_llnw_live_1_90331614 swfUrl=http://static-cdn1.ustream.tv/swf/live/viewer.rsl:96.swf swfVfy=1 live=1"
Larzendk
Post Thu Feb 09, 2012 2:52 pm
Now every stream makes pink screen AARRRGGGHHH
Larzendk
Post Thu Feb 09, 2012 3:05 pm
Hi Illico
Is it the CMD you mean??
because if it is then it returns a message that ffmpeg.exe is not reconize.
Larzendk
Post Thu Feb 09, 2012 3:24 pm
In the "run" window i get the same message, windows can not find ffmpeg.exe
Larzendk
Post Thu Feb 09, 2012 3:42 pm
I think i got it now, i have to run it from the lib dir
here is what it returns:
fail to read RTMP packet header
and
invalid data found when processing input
By the way, i just updatet to the latest ffmpeg from 6/2
Larzendk
Post Fri Feb 10, 2012 3:11 pm
Is this why i cant play any rtmp feeds?
Post Fri Feb 10, 2012 3:16 pm
Can you post the full output and the full command you ran as it will include extra information like versions and build configuration.
Larzendk
Post Fri Feb 10, 2012 3:31 pm
Microsoft Windows [version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Alle rettigheder forbeholdes.
C:\Users\Morten>cd..
C:\Users>cd..
C:\>cd programmer
C:\Programmer>cd serviio
C:\Programmer\Serviio>cd lib
C:\Programmer\Serviio\lib>ffmpeg.exe -i "rtmp://ustreamvip.fc.llnwd.net/ustreamv
ffmpeg version N-37586-g6833fe4 Copyright (c) 2000-2012 the FFmpeg developers
built on Feb 6 2012 16:02:04 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 38.100 / 51. 38.100
libavcodec 54. 1.100 / 54. 1.100
libavformat 54. 0.100 / 54. 0.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 62.100 / 2. 62.100
libswresample 0. 6.100 / 0. 6.100
RTMP_ReadPacket, failed to read RTMP packet header
=1: Invalid data found when processing input
Post Fri Feb 10, 2012 3:39 pm
OK. I get the same error on my linux box. Do other people get the same error or does it work for you?
Larzendk
Post Fri Feb 10, 2012 3:46 pm
Is this what make my SMP-N100 makes pink screen and restarts?
Post Fri Feb 10, 2012 3:50 pm
Larzendk wrote:Is this what make my SMP-N100 makes pink screen and restarts?
no with that error stream wont work at all, your pink screen issue is something else and even now i cant think of what could be causing that.
Larzendk
Post Fri Feb 10, 2012 4:01 pm
No, i am lost too.
I think it maby is the unit itself that is the problem, and i am thinking of getting another, do someone know what to go for?
I am thinking abouth WDTV Live or Sony SMP-N200 what is best?
Best regards
Morten
Denmark
Users browsing this forum: Baidu [Spider] and 19 guests
