Add XFM to Serviio
Deeps1987
Post Thu Feb 09, 2012 9:06 pm
Add XFM to Serviio
Hi all,
first post and pretty new to the "advance features" of Serviio, so bare with me while I pick it up :)
I have successfully set-up Serviio to transcode and stream music, and videos to my Sony Bravia KDL-32EX403.
But I would like to stream XFM (UK Radio Station) as it currently does not transmit on the Freeview built in to my TV.
I attempted to set it up, but am unable to find it on my TV under "Music>Serviio>Online" (Am I even looking in the right place?)
Here is a screenshot of the Serviio (excuse the poor paint skills lol)
Theses are the lines I added
http://mediasrv-sov.musicradio.com/XFML ... WMExt=.asf
http://81.20.49.50:80/XFMLondon?MSWMExt=.asf
Am I doing something wrong?
Post Thu Feb 09, 2012 11:19 pm
Re: Add XFM to Serviio
those URLs point to a playlist file, but that playlist doesn't include any real links to the stream, only links to itself. Something's fishy there - basically you have to put the content URLs in Serviio console, not a link leading to a playlist (a text file basically).
Deeps1987
Post Thu Feb 09, 2012 11:32 pm
I followed this guide to the letter
http://forum.serviio.org/viewtopic.php?f=42&t=5192
What should I have entered in to Serviio?
Post Thu Feb 09, 2012 11:52 pm
WFM doesnt seem to work, its actual url to the stream is rtmp://cdn-the-2.musicradio.com:80/LiveAudio/XFM"
when you run that through ffmpeg you get this error.
c:\Program Files\Serviio\lib>ffmpeg -i "rtmp://cdn-the-2.musicradio.com:80/LiveA
udio/XFM"
ffmpeg version N-37541-g670229e Copyright (c) 2000-2012 the FFmpeg developers
built on Feb 3 2012 20:14:17 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 37.100 / 51. 37.100
libavcodec 54. 0.102 / 54. 0.102
libavformat 54. 0.100 / 54. 0.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 61.100 / 2. 61.100
libswresample 0. 6.100 / 0. 6.100
[aac @ 0000000001E34B80] channel element 0.9 is not allocated
StreamTitle
[flv @ 000000000038EBD0] Stream discovered after head already parsed
[flv @ 000000000038EBD0] max_analyze_duration 5000000 reached at 5014000
[flv @ 000000000038EBD0] decoding for stream 1 failed
[flv @ 000000000038EBD0] Estimating duration from bitrate, this may be inaccurat
e
Input #0, flv, from 'rtmp://cdn-the-2.musicradio.com:80/LiveAudio/XFM':
Duration: N/A, start: 0.000000, bitrate: N/A
Stream #0:0: Audio: aac, 44100 Hz, stereo, s16
Stream #0:1: Data: none
and as you guessed nothing appear on the renderer.
Deeps1987
Post Thu Feb 09, 2012 11:58 pm
any idea on how or what I should do to get it to work? :?
did I do everything on my part right? is it just that the link I used doesn't actually go anywhere?
Sorry if I sound stupid, still very new to Serviio
Post Fri Feb 10, 2012 12:01 am
Deeps1987 wrote:any idea on how or what I should do to get it to work? :?
dont know i was hoping zip would comment ;)
Deeps1987
Post Fri Feb 10, 2012 12:04 am
lol thanks for the help anyways :) sort of glad its not just me who is slightly confused about this XFM radio link, and there I was thinking adding an online source would be easy.
Post Fri Feb 10, 2012 12:05 am
Deeps1987 wrote:lol thanks for the help anyways :) sort of glad its not just me who is slightly confused about this XFM radio link, and there I was thinking adding an online source would be easy.
trust me i have been here since we first starting testing them and i still dont understand them i tend to leave it to illico, jhb50 and ZIP.
Post Fri Feb 10, 2012 11:15 am
the ffmpeg output seems ok to me.
So this url won't play anything?
Post Fri Feb 10, 2012 11:25 am
nope doesnt appear on my TV, although im not running a sony
Post Fri Feb 10, 2012 11:34 am
zip wrote:the ffmpeg output seems ok to me.
I will have a look this end of week.
Post Fri Feb 10, 2012 6:22 pm
Just try this link on my Bravia EX501 without problem. (But I use audio transcoding to mp3 on Sony Bravia Profile)
Deeps1987
Post Fri Feb 10, 2012 6:51 pm
where would I find it on the Sony interface? I tried
HOME > MUSIC > SERVIIO> ONLINE
but there was nothing there.
Am I looking in the right place?
Do I need to edit the profile for my TV?
Deeps1987
Post Fri Feb 10, 2012 6:54 pm
ignore that, got it to work now, thanks guys :)
patters
Post Fri Feb 10, 2012 11:04 pm
Re: Add XFM to Serviio (Fixed)
Would you mind sharing? That URL doesn't work for me (neither on XBMC, nor on Sony BDP).
Deeps1987
Post Fri Feb 10, 2012 11:33 pm
See screenshot below
This is the line I entered
not sure how Cerberus got this link, but it works
also, I found it on my TV under
hope this helps
Working XFM.JPG (72.7 KiB) Viewed 16656 times
Post Sat Feb 11, 2012 1:08 am
Deeps1987 wrote:See screenshot below
hope this helps
took a page out of illico's book and did a url snoop to get the actualy content url form the link you posted :)
Westside
Post Wed Mar 28, 2012 4:41 pm
Hi There
Have tried to this from a mac but to no avail...have copied that link and no online action seen on Bravia...TV is an HX823
W
Deeps1987
Post Tue Apr 24, 2012 9:34 pm
I can also confirm that Xfm is no longer working via that ulr.
Could someone tell me how to find a working one please?
