Re: New Pansonic Blu-ray Profile Requiring Testers.
PMI wrote:Cerberus wrote:ffmpeg have a big thing on the homepage about missing patches, so hopefully they will sort it out very soon.
OK, and btw, I did try the 06/02/12 version, result was the same.
(I really do not consider myself qualified to test ffmpeg issues tho.)
ffmpeg testing is easy you just change it throw the same file at it and see if it works or fails.
