Movie folder (Metadata) doesn't show subtitles.
MaKTaiL
Post Sun Feb 05, 2012 10:19 pm
Hi, I recently started using Serviio. Great media server, one of the best!
However I'm having a little problem on my LG TV.
The Movie folder created by Serviio (the one that is generated by Metadata) does not show subtitles when played.
But if I go to the actual folder of the movie, subtitles work normally.
The Series folder created by metadata works with subtitles so I guess the problem is only with the Movie folder.
Is anyone having the same problem? Sorry, I don't have the model of my TV right now with me. It supports DLNA and has Netcast ability. 55''.
MaKTaiL
Post Sat Feb 11, 2012 12:42 pm
Re: Movie folder (Metadata) doesn't show subtitles.
20 views and not one single comment about this?
Post Sat Feb 11, 2012 12:59 pm
Can you enable detailed logging (see signature) and then restart serviio and play the file from both locations and then attach the serviio.log file here.
This will allow us to see what is going on.
MaKTaiL
Post Sat Feb 11, 2012 3:37 pm
moltra wrote:Can you enable detailed logging (see signature) and then restart serviio and play the file from both locations and then attach the serviio.log file here.
Alright, I will do that.
Post Tue Feb 14, 2012 8:53 pm
I thought it only works in Folders view, because the file name there includes the file extension. That it works in Series as well is surprising. There is no difference between how files in Movies and Series are served.
Return to LG
