Why this will not play mkv?
eclp
Post Sat Jan 28, 2012 1:14 pm
Who can say why have these problems with mkv:
Error: 'File corrupted or format not recognised'
this mkv is not played:
 Unique ID                        : 170355575155812997242566865860743103667 (0x80294A53A138BCF09CE74A2E5E8B84B3)
Complete name                    : E:\Downloads\movie.mkv
 Format                           : Matroska
Format version                   : Version 2
File size                        : 32.6 GiB
Duration                         : 2h 28mn
Overall bit rate mode            : Variable
 Overall bit rate                 : 31.5 Mbps
Encoded date                     : UTC 2011-09-24 18:15:21
Writing application              : mkvmerge v4.9.1 ('Ich will') gebaut am Jul 11 2011 23:53:15
Writing library                  : libebml v1.2.1 + libmatroska v1.1.1
Format                           : VC-1
Format profile                   : AP@L3
Codec ID                         : WVC1
Codec ID/Hint                    : Microsoft
 Duration                         : 2h 28mn
Bit rate                         : 27.8 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
 Frame rate                       : 23.976 fps
 Bits/(Pixel*Frame)               : 0.559
Stream size                      : 28.7 GiB (88%)
Language                         : English
Default                          : Yes
Forced                           : No
Audio #1
Format                           : DTS
Format/Info                      : Digital Theater Systems
Format profile                   : MA / Core
Codec ID                         : A_DTS
 Duration                         : 2h 28mn
Bit rate mode                    : Variable
Bit rate                         : 1 561 Kbps / 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 24 bits
Compression mode                 : Lossless / Lossy
Title                            : Mix by SF
Language                         : German
 Default                          : Yes
Forced                           : No
Audio #2
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 2h 28mn
Bit depth                        : 24 bits
 Language                         : English
Default                          : No
Forced                           : No
Text #1
Format                           : PGS
 Codec ID                         : S_HDMV/PGS
Codec ID/Info                    : The same subtitle format used on BDs/HD-DVDs
Language                         : English
Default                          : No
Forced                           : No
Text #2
Format                           : PGS
 Language                         : French
Default                          : No
Forced                           : No
Text #3
Format                           : PGS
Language                         : German
Default                          : No
Forced                           : No
Text #4
Format                           : PGS
 Language                         : Italian
Default                          : No
Forced                           : No
Text #5
Format                           : PGS
Language                         : Dutch
Default                          : No
Forced                           : No
Text #6
Format                           : PGS
Language                         : French
Default                          : No
Forced                           : No
Text #7
Format                           : PGS
Language                         : German
Default                          : Yes
Forced                           : No
Text #8
Format                           : PGS
Language                         : Italian
Default                          : No
Forced                           : No
Menu
00:00:00.000                     : :00:00:00.000
00:11:41.742                     : :00:11:41.742
00:21:37.337                     : :00:21:37.337
00:31:20.336                     : :00:31:20.336
00:41:22.229                     : :00:41:22.229
00:51:13.737                     : :00:51:13.737
01:01:21.552                     : :01:01:21.552
01:10:29.683                     : :01:10:29.683
01:22:15.597                     : :01:22:15.597
01:31:52.590                     : :01:31:52.590
01:40:38.532                     : :01:40:38.532
01:51:22.175                     : :01:51:22.175
 02:00:54.413                     : :02:00:54.413
02:10:09.051                     : :02:10:09.051
02:20:55.446                     : :02:20:55.446
eclp
Post Sat Feb 11, 2012 3:25 pm
Re: Why this will not play mkv?
Please help!
The renderer crashes sometimes even starting.
Unique ID                                : 210849275582242516455241450641257972244 (0x9EA017E66A818176B2A5073DD634C214)
 Complete name                            : E:\Media\Eigene Videos\Filme\movie2.2010.mkv
File size                                : 27.1 GiB
Duration                                 : 2h 28mn
 Overall bit rate                         : 26.2 Mbps
 Encoded date                             : UTC 2011-02-08 17:27:59
Writing application                      : mkvmerge v4.0.0 ('The Stars were mine') gebaut am Jun  6 2010 16:18:42
Writing library                          : libebml v1.0.0 + libmatroska v1.0.0
Format                                   : VC-1
Codec ID                                 : WVC1
Duration                                 : 2h 28mn
Bit rate                                 : 23.5 Mbps
Bits/(Pixel*Frame)                       : 0.473
Stream size                              : 24.3 GiB (90%)
Language                                 : German
Audio #1
Duration                                 : 2h 28mn
Bit rate                                 : 640 Kbps
 Stream size                              : 678 MiB (2%)
Title                                    : Deutsch AC3 5.1 640Kbps
Language                                 : German
Audio #2
Format                                   : DTS
 Codec ID                                 : A_DTS
Duration                                 : 2h 28mn
Bit rate                                 : 1 510 Kbps
Bit depth                                : 24 bits
 Stream size                              : 1.56 GiB (6%)
Title                                    : Englisch DTS 5.1 1.5Mbps
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
 Codec ID/Info                            : UTF-8 Plain Text
Title                                    : Deutsch forced (srt)
Language                                 : German
 Forced                                   : Yes
Text #2
Format                                   : VobSub
Muxing mode                              : zlib
 Codec ID                                 : S_VOBSUB
 Codec ID/Info                            : The same subtitle format used on DVDs
Title                                    : Deutsch forced (sub/idx)
Language                                 : German
Text #3
Format                                   : VobSub
Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
Title                                    : Deutsch [SHD] (sub/idx)
Language                                 : German
Text #4
Format                                   : VobSub
Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
Title                                    : Englisch [SHD] (sub/idx)
Menu
00:00:00.000                             : en:00:00:00.000
00:11:41.743                             : en:00:11:41.743
00:21:37.338                             : en:00:21:37.338
 00:31:20.337                             : en:00:31:20.337
00:41:22.230                             : en:00:41:22.230
00:51:13.737                             : en:00:51:13.737
01:01:21.553                             : en:01:01:21.553
 01:10:29.684                             : en:01:10:29.684
01:22:15.597                             : en:01:22:15.597
01:31:52.590                             : en:01:31:52.590
01:40:38.532                             : en:01:40:38.532
 01:51:22.175                             : en:01:51:22.175
02:00:54.414                             : en:02:00:54.414
02:10:09.051                             : en:02:10:09.051
02:20:55.447                             : en:02:20:55.447
Unique ID                        : 180937869564329366865557727100806978453 (0x881F5DB92C25C9D19E4AC65D07D95B95)
Complete name                    : E:\Media\Eigene Videos\Filme\movie3.rmx.mkv
 Format                           : Matroska
File size                        : 17.8 GiB
Duration                         : 1h 52mn
Overall bit rate                 : 22.6 Mbps
Encoded date                     : UTC 2011-01-01 23:20:49
 Writing application              : mkvmerge v4.3.0 ('Escape from the Island') gebaut am Sep  5 2010 10:30:51
 Format                           : VC-1
Codec ID                         : WVC1
 Duration                         : 1h 52mn
 Bit rate                         : 19.9 Mbps
Bits/(Pixel*Frame)               : 0.399
 Stream size                      : 15.6 GiB (88%)
Default                          : Yes
Forced                           : No
Audio #1
Format                           : DTS
Muxing mode                      : Header stripping
Codec ID                         : A_DTS
Duration                         : 1h 52mn
Bit depth                        : 24 bits
Stream size                      : 1.19 GiB (7%)
Title                            : Englisch
Language                         : English
Default                          : No
 Forced                           : No
Audio #2
Format                           : DTS
 Codec ID                         : A_DTS
Duration                         : 1h 52mn
Bit rate                         : 755 Kbps
Bit depth                        : 24 bits
Stream size                      : 608 MiB (3%)
 Title                            : Deutsch
Language                         : German
Default                          : Yes
Forced                           : No
Unique ID                                : 215062737194517296478791740072308994841 (0xA1CB9398AE63A037945F7FEECF237319)
Complete name                            : E:\Media\Eigene Videos\Filme\movie4.2010-rmx.mkv
File size                                : 27.9 GiB
Duration                                 : 1h 56mn
 Overall bit rate                         : 34.3 Mbps
Encoded date                             : UTC 2011-03-13 16:20:48
Writing application                      : mkvmerge v4.6.0 ('Still Crazy After All These Years') gebaut am Mar 10 2011 02:50:32
 Writing library                          : libebml v1.2.0 + libmatroska v1.1.0
Muxing mode                              : Container profile=Unknown@0.0
Duration                                 : 1h 56mn
Bit rate                                 : 30.4 Mbps
 Maximum bit rate                         : 33.0 Mbps
 Frame rate                               : 24.000 fps
 Bits/(Pixel*Frame)                       : 0.612
Stream size                              : 24.7 GiB (89%)
Color primaries                          : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
 Transfer characteristics                 : BT.709-5, BT.1361
Matrix coefficients                      : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
 Format                                   : DTS
Codec ID                                 : A_DTS
 Duration                                 : 1h 56mn
Bit rate                                 : 1 576 Kbps / 1 510 Kbps
 Language                                 : German
Forced                                   : Yes
Audio #2
 Format                                   : DTS
Codec ID                                 : A_DTS
Duration                                 : 1h 56mn
Text #1
Format                                   : VobSub
Muxing mode                              : zlib
 Codec ID                                 : S_VOBSUB
Language                                 : German
Text #2
Format                                   : VobSub
Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
Menu
00:00:00.000                             : de:00:00:00.000
00:04:54.667                             : de:00:04:54.667
00:11:14.583                             : de:00:11:14.583
00:19:04.625                             : de:00:19:04.625
 00:25:06.292                             : de:00:25:06.292
00:32:50.375                             : de:00:32:50.375
00:41:42.625                             : de:00:41:42.625
00:50:11.167                             : de:00:50:11.167
 00:54:42.833                             : de:00:54:42.833
01:00:59.792                             : de:01:00:59.792
01:08:07.625                             : de:01:08:07.625
01:16:30.000                             : de:01:16:30.000
 01:23:10.875                             : de:01:23:10.875
01:32:14.458                             : de:01:32:14.458
01:38:56.833                             : de:01:38:56.833
01:48:53.417                             : de:01:48:53.417
and this works perfectly:
Unique ID                                : 210194786817763437988798658587034354076 (0x9E220B1CD42AA098BEF4246BB10F819C)
Complete name                            : E:\Media\Eigene Videos\Filme\movie5-rmx.mkv
File size                                : 29.9 GiB
Duration                                 : 2h 6mn
 Overall bit rate                         : 33.7 Mbps
Encoded date                             : UTC 2010-12-13 23:39:58
Writing application                      : mkvmerge v3.1.0 ('Happy up here') gebaut am Jan 19 2010 12:09:24
 Writing library                          : libebml v0.7.9 + libmatroska v0.8.1
 Duration                                 : 2h 6mn
Bit rate                                 : 31.8 Mbps
Maximum bit rate                         : 34.5 Mbps
Bits/(Pixel*Frame)                       : 0.639
Stream size                              : 28.2 GiB (94%)
Audio #1
Duration                                 : 2h 6mn
 Bit rate                                 : 640 Kbps
Stream size                              : 581 MiB (2%)
Language                                 : German
Audio #2
Duration                                 : 2h 6mn
 Bit rate                                 : 640 Kbps
Text #1
Format                                   : UTF-8
Title                                    : german forced srt
Text #2
Format                                   : VobSub
Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
Title                                    : idx
Language                                 : German
Menu
00:11:57.216                             : en:00:11:57.216
00:19:45.101                             : en:00:19:45.101
 00:28:09.104                             : en:00:28:09.104
00:35:33.506                             : en:00:35:33.506
00:44:10.398                             : en:00:44:10.398
00:52:21.722                             : en:00:52:21.722
 01:01:33.607                             : en:01:01:33.607
01:11:40.087                             : en:01:11:40.087
01:20:39.501                             : en:01:20:39.501
01:27:35.292                             : en:01:27:35.292
 01:36:29.575                             : en:01:36:29.575
01:44:34.268                             : en:01:44:34.268
01:53:13.412                             : en:01:53:13.412
01:58:20.552                             : en:01:58:20.552
Unique ID                                : 247377315018643185228872472342628720339 (0xBA1B234A820C900DA0A8F782846CDED3)
Complete name                            : E:\Media\Eigene Videos\Filme\movie6-rmx.mkv
File size                                : 17.1 GiB
Duration                                 : 1h 30mn
 Overall bit rate                         : 27.1 Mbps
Encoded date                             : UTC 2011-10-18 09:24:30
Writing application                      : mkvmerge v4.4.0 ('Die Wiederkehr') gebaut am Oct 31 2010 21:52:48
 Duration                                 : 1h 30mn
Bit rate                                 : 25.3 Mbps
Maximum bit rate                         : 34.2 Mbps
Bits/(Pixel*Frame)                       : 0.509
 Stream size                              : 16.0 GiB (93%)
Audio #1
 Duration                                 : 1h 30mn
Bit rate                                 : 640 Kbps
 Stream size                              : 414 MiB (2%)
Language                                 : German
Audio #2
Duration                                 : 1h 30mn
Bit rate                                 : 640 Kbps
Text #1
Format                                   : VobSub
Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
 Language                                 : German
Text #2
Format                                   : VobSub
 Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
Title                                    : Kommentar
 Language                                 : German
Menu
00:00:00.000                             : :Chapter 01
 00:03:54.275                             : :Chapter 02
00:10:35.343                             : :Chapter 03
00:16:09.385                             : :Chapter 04
00:21:15.774                             : :Chapter 05
 00:29:56.628                             : :Chapter 06
00:36:53.878                             : :Chapter 07
00:41:14.180                             : :Chapter 08
00:49:44.815                             : :Chapter 09
 00:54:06.826                             : :Chapter 10
00:58:54.781                             : :Chapter 11
01:05:09.238                             : :Chapter 12
01:11:43.799                             : :Chapter 13
 01:15:31.902                             : :Chapter 14
01:21:15.871                             : :Chapter 15
Why is it, or what might be the cause?
Post Sun Feb 12, 2012 9:34 am
1) Not sure that MKV with VC-1video codec are supported.
2) Some muxer library are not supported, don't know exactly with but some mkvmerge version are good and some other not.
3) Muxing with header stripping is not supported.
Its very difficult to know what mkv version is supported, too many parameters.
eclp
Post Sun Feb 12, 2012 3:27 pm
Thanks, Illico.
I fear that the VC-1 codec causes the actual problem.
The film plays if I convert VC-1 to AVC.
Post Sun Feb 12, 2012 3:43 pm
eclp wrote:Thanks, Illico.
i havent seem a device yet that support VC-1 codec.
eclp
Post Sun Feb 12, 2012 4:15 pm
Ok.
I convert one of the above mkv videos with tsMuxeR GUI 1.10.6 to m2ts file, the movie plays perfectly.
My Sony renderer (Remote control, Info button) shows while playing the VC-1 codec even.
Why VC-1 not in one mkv-container?
Post Sun Feb 12, 2012 5:09 pm
VC-1 video codec is supported under MPEGTS container.
Users browsing this forum: Google [Bot] and 6 guests
