Still having problems with my BD-D5700
mirak51
Post Wed Feb 15, 2012 12:48 am
:x I used the Samsung profile but still same issue it keeps buffering not as often as before but not gone.
If I convert the VOB files to MKV I have no problems at all it streams without any problems. In that respect the notion of having network problems is out of the question. Is there any profile more direct for my Blue Ray player that transcode and play VOB file format? because I still get the CODEC not supported.
:evil:
I know that my BR player does not support VOB format but does support MKV.
Also how do I play the movies that shows the Play / Setup/ etc on the tv. If I press Play on the remote control it does not work I have to go to the next file in order to get the movie play.
Anyway my main issue is to get the VOB to play without any issues. :evil:
Thank you very much for your help.
Mario
Post Wed Feb 15, 2012 8:07 am
Re: Still having problems with my BD-D5700
ok i have already answered all of these question for you before but will do so again.
mirak51 wrote::x I used the Samsung profile but still same issue it keeps buffering not as often as before but not gone.
This is a samsung firmware bug and not serviio, samsung have partially fixed it but as you say not perfect.
:evil:
No the C/D series profile is ONLY profile for that device
Again this is down to a firmware bug that is out of the control of serviio.
Mario
No thats not an issue and you answered this your self above manually convert to MKV and they work
mirak51
Post Wed Feb 15, 2012 5:56 pm
Re: (CLOSED) Still having problems with my BD-D5700
Well thank you for the answer, I will wait until Samsung fix the bug. and yes it was answer before to use the profile already provided by Serviio. I just thought it may have been another issue since I had read in these forum some post that for some people it works without any porblems.
But thank you very much for time and help.
