DirecTv
gmann001
Post Tue Jan 31, 2012 3:16 am
DirecTv
Not sure if this a Serviio transcoding issue or something with the DirecTv DVR that I have. Anyway, I thought I'd try watching a video on my DirecTv DVR that was served up through Serviio (using the settings that come with Serviio).
The picture is "stretched" to fill in the screen instead of leaving the black bars along the top/bottom of the screen. If I watch the same video through PS3 or XBOX, the video aspect ratio is left alone. Just the DirecTv seems to do the stretching which makes the movies seem unbearable at times.
Is this a transcoding issue? Or just a "feature" of DirecTv's dvr? I went throuh all the settings onthe DirecTv menu and was not able to fix the issue that way. Thoughts?
Post Tue Jan 31, 2012 8:39 am
Re: DirecTv
its probably due to the source DAR (Display Aspect Ratio) value not supported by your device, or bladly transcoded by ffmpeg.
Could you provide information about your source file ( ffmpeg -i "filepath")or(MediaInfo result in text format:
http://wiki.serviio.org/doku.php?id=file_np
voodooo
Post Tue Jan 31, 2012 1:27 pm
Re: DirecTv
I think is something with the profile cause it happens with my tv to.
Post Tue Jan 31, 2012 3:10 pm
Re: DirecTv
voodooo wrote:I think is something with the profile cause it happens with my tv to.
Nothing to do with the profile.
1) its probably due to ffmpeg option used to transcode
or
2) DAR source weird
gmann001
Post Wed Feb 01, 2012 1:33 am
Re: DirecTv
Illico wrote:its probably due to the source DAR (Display Aspect Ratio) value not supported by your device, or bladly transcoded by ffmpeg.
Here is what FFMPEG shows...
FFmpeg version SVN-r24233, Copyright (c) 2000-2010 the FFmpeg developers
  built on Jul 14 2010 04:11:44 with gcc 4.4.2
  configuration: --enable-gpl --enable-version3 --enable-libgsm --enable-pthreads --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libmp3lame --enable-libopenjpeg --enable-libschroedinger --enable-libopencore_amrwb --enable-libopencore_amrnb --enable-libvpx --arch=x86 --enable-runtime-cpudetect --enable-libxvid --enable-libx264 --extra-libs='-lx264 -lpthread' --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --target-os=mingw32 --enable-avisynth --cross-prefix=i686-mingw32- --cc='ccache i686-mingw32-gcc' --enable-memalign-hack
  libavutil     50.22. 0 / 50.22. 0
  libavcodec    52.83. 0 / 52.83. 0
  libavformat   52.73. 0 / 52.73. 0
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.22. 0 /  1.22. 0
  libswscale     0.11. 0 /  0.11. 0
[mpeg4 @ 02ee8330] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'M:\Movies\M\My Movie\Movie1.[2011].avi':
    ISFT            : Lavf52.78.4
  Duration: 01:32:44.05, start: 0.000000, bitrate: 2000 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 720x300 [PAR 1:1 DAR 12:5], 23.98 tbr, 23.98 tbn, 23.98 tbc
    Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
Post Wed Feb 01, 2012 8:24 am
Re: DirecTv
gmann001 wrote:Here is what FFMPEG shows...
2) DAR source weird
For me this is the source problem:
But, during transcoding, with a proper ffmpeg option, that could be resolved.
Could you please enable serviio detailed logging and found the ffmpeg command line used to transcode this file?
gmann001
Post Fri Feb 10, 2012 12:42 pm
Re: DirecTv
Illico wrote:Could you please enable serviio detailed logging and found the ffmpeg command line used to transcode this file?
Not sure if this is what you are looking for...
2012-02-10 06:30:56,599 DEBUG [WebServer] Incoming connection from /192.168.1.149:41961
2012-02-10 06:30:56,606 DEBUG [ResourceTransportRequestHandler] GET /resource/42467/MEDIA_ITEM/MPEG_PS_PAL$0 HTTP/1.1, headers = [Host: 192.168.1.101,Date: Fri, Feb 10 06:31:33 2012,Accept: */*,User-Agent: DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1,Connection: close]]
2012-02-10 06:30:56,607 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.149
2012-02-10 06:30:56,607 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-10 06:30:56,607 DEBUG [ResourceTransportRequestHandler] Request for resource 42467 and type 'MEDIA_ITEM' received
2012-02-10 06:30:56,607 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42467 (local)
2012-02-10 06:30:56,607 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 42467)
2012-02-10 06:30:56,608 DEBUG [VideoDAOImpl] Reading a Video (id = 42467)
2012-02-10 06:30:56,608 DEBUG [VideoDeliveryEngine] Delivering item '42467' for client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-10 06:30:56,608 DEBUG [VideoDeliveryEngine] Delivering file 'Movie1.[2011].avi' using transcoding
2012-02-10 06:30:56,609 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-10 06:30:56,731 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-02-10 06:30:56,733 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Movie1.[2011].avi: MPEG_PS_PAL
2012-02-10 06:30:56,733 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Movie1.[2011].avi: MPEG_PS_NTSC
2012-02-10 06:30:56,734 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 42467) as read
2012-02-10 06:30:56,746 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-02-10 06:30:56,750 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-02-10 06:30:56,750 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-02-10 06:30:56,750 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-10 06:30:56,750 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Fri, 10 Feb 2012 12:30:56 GMT,Server: Windows Vista, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1-SNAPSHOT,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-02-10 06:30:58,248 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-02-10 06:30:58,866 DEBUG [WebServer] Incoming connection from /192.168.1.149:41962
2012-02-10 06:30:58,867 DEBUG [ResourceTransportRequestHandler] GET /resource/42467/MEDIA_ITEM/MPEG_PS_PAL$0 HTTP/1.1, headers = [Host: 192.168.1.101,Date: Fri, Feb 10 06:31:36 2012,Accept: */*,User-Agent: DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1,Connection: close]]
2012-02-10 06:30:58,868 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.149
2012-02-10 06:30:58,868 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-10 06:30:58,868 DEBUG [ResourceTransportRequestHandler] Request for resource 42467 and type 'MEDIA_ITEM' received
2012-02-10 06:30:58,868 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42467 (local)
2012-02-10 06:30:58,868 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 42467)
2012-02-10 06:30:58,869 DEBUG [VideoDAOImpl] Reading a Video (id = 42467)
2012-02-10 06:30:58,869 DEBUG [VideoDeliveryEngine] Delivering item '42467' for client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-10 06:30:58,870 DEBUG [VideoDeliveryEngine] Delivering file 'Movie1.[2011].avi' using transcoding
2012-02-10 06:30:58,870 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-10 06:30:58,872 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-02-10 06:30:58,872 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Movie1.[2011].avi: MPEG_PS_PAL
2012-02-10 06:30:58,872 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Movie1.[2011].avi: MPEG_PS_NTSC
2012-02-10 06:30:58,872 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 42467) as read
2012-02-10 06:30:58,873 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-02-10 06:30:58,873 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-02-10 06:30:58,873 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-02-10 06:30:58,873 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-10 06:30:58,873 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Fri, 10 Feb 2012 12:30:58 GMT,Server: Windows Vista, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1-SNAPSHOT,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-02-10 06:31:02,269 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Post Fri Feb 10, 2012 12:50 pm
Re: DirecTv
gmann001 wrote:Not sure if this is what you are looking for...
No
I would like the ffmpeg command line used when transcoding job starting...
gmann001
Post Sat Feb 11, 2012 11:00 pm
Re: DirecTv
2012-02-11 16:33:34,839 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 4583 (from=0, count=24)
2012-02-11 16:33:34,864 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2012-02-11 16:33:34,871 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 42467)
2012-02-11 16:33:34,881 DEBUG [MediaItemDAOImpl] Getting file of media item 42467
2012-02-11 16:33:34,906 DEBUG [VideoDAOImpl] Reading a Video (id = 42467)
2012-02-11 16:33:34,917 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 42467 and profile DirecTV HD-DVR
2012-02-11 16:33:34,921 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The Movie.[2011].avi: MPEG_PS_PAL
2012-02-11 16:33:34,922 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The Movie.[2011].avi: MPEG_PS_NTSC
2012-02-11 16:33:34,923 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 89445)
2012-02-11 16:33:34,966 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 4583
2012-02-11 16:33:34,966 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-02-11 16:33:34,972 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-02-11 16:33:37,522 DEBUG [WebServer] Incoming connection from /192.168.1.149:36166
2012-02-11 16:33:37,523 DEBUG [ResourceTransportRequestHandler] GET /resource/42467/MEDIA_ITEM/MPEG_PS_PAL$0 HTTP/1.1, headers = [Host: 192.168.1.101,Date: Sat, Feb 11 16:34:25 2012,Accept: */*,User-Agent: DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1,Connection: close]]
2012-02-11 16:33:37,523 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.149
2012-02-11 16:33:37,525 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-11 16:33:37,527 DEBUG [ResourceTransportRequestHandler] Request for resource 42467 and type 'MEDIA_ITEM' received
2012-02-11 16:33:37,527 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42467 (local)
2012-02-11 16:33:37,527 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 42467)
2012-02-11 16:33:37,527 DEBUG [VideoDAOImpl] Reading a Video (id = 42467)
2012-02-11 16:33:37,528 DEBUG [VideoDeliveryEngine] Delivering item '42467' for client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-11 16:33:37,528 DEBUG [VideoDeliveryEngine] Delivering file 'The Movie.[2011].avi' using transcoding
2012-02-11 16:33:37,528 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-11 16:33:37,530 DEBUG [MediaItemDAOImpl] Getting file of media item 42467
2012-02-11 16:33:37,531 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: M:\Movies\M\The Movie (2011)\The Movie.[2011].avi
2012-02-11 16:33:37,532 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i M:\Movies\M\The Movie (2011)\The Movie.[2011].avi -y -threads 1 -async 1 -vcodec mpeg2video -b 8192k -maxrate 8192k -bufsize 5097k -r 24000/1001 -g 15 -copyts -acodec mp2 -ab 128k -ac 2 -map 0:0 -map 0:1 -sn -f vob C:\Windows\TEMP\Serviio\transcoding-temp-42467-MPEG2PS.stf
2012-02-11 16:33:45,033 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-42467-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-42467-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:130)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
2012-02-11 16:33:53,915 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-02-11 16:33:56,685 DEBUG [WebServer] Incoming connection from /192.168.1.149:36169
2012-02-11 16:33:56,693 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.149:
2012-02-11 16:33:56,693 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.149
2012-02-11 16:33:56,889 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 6) with parameters: objectID = V_F#FOL_R1, browseFlag = BrowseDirectChildren, filter = *, startIndex = 24, count = 24, sortCriteria =
2012-02-11 16:33:56,889 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-02-11 16:33:56,903 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-02-11 16:34:03,794 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8139/810x Family Fast Ethernet NIC) and address 192.168.1.101, timeout = 0
2012-02-11 16:34:03,794 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 29e0c7b2-e2bf-3f96-91e2-08c360085651
2012-02-11 16:34:05,601 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:04
2012-02-11 16:34:05,841 DEBUG [WebServer] Incoming connection from /192.168.1.149:36172
2012-02-11 16:34:05,841 DEBUG [ResourceTransportRequestHandler] GET /resource/42467/MEDIA_ITEM/MPEG_PS_PAL$0 HTTP/1.1, headers = [Host: 192.168.1.101,Date: Sat, Feb 11 16:34:53 2012,Accept: */*,User-Agent: DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1,Connection: close]]
2012-02-11 16:34:05,841 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.149
2012-02-11 16:34:05,842 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-11 16:34:05,842 DEBUG [ResourceTransportRequestHandler] Request for resource 42467 and type 'MEDIA_ITEM' received
2012-02-11 16:34:05,842 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42467 (local)
2012-02-11 16:34:05,842 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 42467)
2012-02-11 16:34:05,842 DEBUG [VideoDAOImpl] Reading a Video (id = 42467)
2012-02-11 16:34:05,843 DEBUG [VideoDeliveryEngine] Delivering item '42467' for client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-11 16:34:05,843 DEBUG [VideoDeliveryEngine] Delivering file 'The Movie.[2011].avi' using transcoding
2012-02-11 16:34:05,843 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-11 16:34:06,062 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-02-11 16:34:06,105 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The Movie.[2011].avi: MPEG_PS_PAL
2012-02-11 16:34:06,105 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The Movie.[2011].avi: MPEG_PS_NTSC
2012-02-11 16:34:06,105 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 42467) as read
2012-02-11 16:34:06,154 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-02-11 16:34:06,158 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-02-11 16:34:06,158 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-02-11 16:34:06,158 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-11 16:34:06,158 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Sat, 11 Feb 2012 22:34:06 GMT,Server: Windows Vista, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1-SNAPSHOT,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-02-11 16:34:07,935 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-02-11 16:34:09,161 DEBUG [WebServer] Incoming connection from /192.168.1.149:36173
2012-02-11 16:34:09,172 DEBUG [ResourceTransportRequestHandler] GET /resource/42467/MEDIA_ITEM/MPEG_PS_PAL$0 HTTP/1.1, headers = [Host: 192.168.1.101,Date: Sat, Feb 11 16:34:57 2012,Accept: */*,User-Agent: DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1,Connection: close]]
2012-02-11 16:34:09,173 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.149
2012-02-11 16:34:09,173 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-11 16:34:09,174 DEBUG [ResourceTransportRequestHandler] Request for resource 42467 and type 'MEDIA_ITEM' received
2012-02-11 16:34:09,174 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42467 (local)
2012-02-11 16:34:09,174 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 42467)
2012-02-11 16:34:09,175 DEBUG [VideoDAOImpl] Reading a Video (id = 42467)
2012-02-11 16:34:09,176 DEBUG [VideoDeliveryEngine] Delivering item '42467' for client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-11 16:34:09,176 DEBUG [VideoDeliveryEngine] Delivering file 'The Movie.[2011].avi' using transcoding
2012-02-11 16:34:09,176 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.149, Profile=DirecTV HD-DVR'
2012-02-11 16:34:09,202 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-02-11 16:34:09,217 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The Movie.[2011].avi: MPEG_PS_PAL
2012-02-11 16:34:09,217 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The Movie.[2011].avi: MPEG_PS_NTSC
2012-02-11 16:34:09,217 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 42467) as read
2012-02-11 16:34:09,219 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
Is this what you are looking for?
chaddc
Post Wed Feb 15, 2012 4:22 am
Re: DirecTv
I am having issues with my two directv dvr24s. They show the video fine, but will not play the audio. I am running the latest version (0.6.2). I have read all of the posts I can find about this, and have tried adjusting the audio codec and bitrates in the directv section of the profile.
Does anyone have any other suggestions?
Here is a copy of my directv profile. I have tried mp2, lmpc and aac.
<Profile id="6" name="DirecTV HD-DVR" extendsProfileId="1">
<Detection>
<HttpHeaders>
<User-Agent>.*DIRECTV.*</User-Agent>
</HttpHeaders>
<UPnPSearch>
<FriendlyName>^DIRECTV.*$</FriendlyName>
</UPnPSearch>
</Detection>
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp2" maxVBitrate="8600" forceStereo="true">
<Matches container="mp4" />
<Matches container="asf" />
<Matches container="avi" />
<Matches container="ogg" />
<Matches container="flv" />
<Matches container="3gp" />
Post Wed Feb 15, 2012 9:17 am
Re: DirecTv
Could you provide information about these video files ?
chaddc
Post Wed Feb 15, 2012 6:07 pm
Re: DirecTv
I have tried different source video files. The main ones I am concerned with are straight DVD rips in 1 GB VOB format. Nothing special. (BTW, these are copies of movies I own)
Post Wed Feb 15, 2012 6:18 pm
Re: DirecTv
are they actualy VOB files or have u converted them to MKV? as there is no rules to transcode VOb files in the directv profile ( and tbh i dont think there is one at all ) as they are supported natively by the device.
Users browsing this forum: Baidu [Spider] and 10 guests
