C Series wont play wtv after serviio update
dyerpunk
Post Wed Feb 08, 2012 6:47 pm
Hi, I recently download and installed the newest version of Serviio. Upon doing so .wtv files quit playing on my tv after the update. I had the same problem with the previous version, and had used the fix posted in the post linked here. http://forum.serviio.org/viewtopic.php?f=7&t=4535 This fix worked fine, and I had no problems whatsoever. I also applied this fix with the new version, and I'm still receiving "not supported file format" from the TV. Serviio does recognize my tv a C-series and assigns the profile automatically. Any Ideas? Thanks
Post Wed Feb 08, 2012 8:48 pm
Re: C Series wont play wtv after serviio update
change the wtv section from this:
        <Matches container="wtv" />
to
WTV doesnt like being put into TS container on version of ffmpeg (shipped with serviio ) not sure why but its easy enoguh to put in in a PS container as above and it then works.
dyerpunk
Post Wed Feb 08, 2012 9:25 pm
Thanks for the quick reply. I removed the "ts" and im still receiving the same message as before. I even tried the code that worked before and removed the "ts" also and that didnt work either. I also restarted the computer each time after making a change.
Post Wed Feb 08, 2012 9:26 pm
can you post ffmpeg -i readout of the wtv file. (howto in signiture)
dyerpunk
Post Wed Feb 08, 2012 11:06 pm
Here you go
C:\>cd \program files\serviio\lib
C:\Program Files\Serviio\lib>ffmpeg.exe -i "g:\recorded tv\1.wtv"
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
[mpeg2video @ 01a29a80] mpeg_decode_postinit() failure
Seems stream 2 codec frame rate differs from container frame rate: 59.94 (60000/
1001) -> 29.92 (359/12)
Input #0, wtv, from 'g:\recorded tv\1.wtv':
WM/MediaClassPrimaryID: db9830bd-3ab3-4fab-8a371a995f7ff74
WM/MediaClassSecondaryID: ba7f258a-62f7-47a9-b21f4651c42a000
Title : Cajun Pawn Stars
WM/SubTitle : Speed Demons
WM/SubTitleDescription: The guys have the opportunity to buy a rare World Wa
r II biplane; a strand of Abraham Lincoln's hair comes into the shop; a familiar
customer hopes to sell his super speedy Mako fishing boat.
genre : Series;Other
WM/OriginalReleaseTime: 0
WM/MediaCredits : ;;;
service_provider: HISTORY
service_name : History
WM/MediaNetworkAffiliation: Satellite
WM/MediaOriginalChannel: 40
WM/MediaOriginalChannelSubNumber: 0
WM/MediaOriginalBroadcastDateTime: 2012-02-06T06:00:00Z
WM/MediaOriginalRunTime: 20974441860
WM/MediaIsStereo: false
WM/MediaIsRepeat: false
WM/MediaIsLive : false
WM/MediaIsTape : false
WM/MediaIsDelay : false
WM/MediaIsSubtitled: false
WM/MediaIsMovie : false
WM/MediaIsPremiere: false
WM/MediaIsFinale: false
WM/MediaIsSAP : false
WM/MediaIsSport : false
WM/ParentalRating: TV-PG
WM/Provider : MediaCenterDefault
WM/VideoClosedCaptioning: true
WM/WMRVEncodeTime: 2012-02-03 06:59:02
WM/WMRVSeriesUID: !MCSeries!01509252
WM/WMRVServiceID: !MCService!28457181
WM/WMRVProgramID: !MCProgram!267834174
WM/WMRVRequestID: 0
WM/WMRVScheduleItemID: 0
WM/WMRVQuality : 3
WM/WMRVOriginalSoftPrePadding: 420
WM/WMRVOriginalSoftPostPadding: 180
WM/WMRVHardPrePadding: -300
WM/WMRVHardPostPadding: 0
WM/WMRVATSCContent: false
WM/WMRVDTVContent: false
WM/WMRVHDContent: false
Duration : 19184817308
WM/WMRVEndTime : 2012-02-03 07:31:01
WM/WMRVBitrate : 8.068400
WM/WMRVKeepUntil: -1
WM/WMRVActualSoftPrePadding: 417
WM/WMRVActualSoftPostPadding: 1
WM/WMRVContentProtected: false
WM/WMRVContentProtectedPercent: 0
WM/WMRVExpirationSpan: 9223372036854775807
WM/WMRVInBandRatingSystem: 255
WM/WMRVInBandRatingLevel: 255
WM/WMRVInBandRatingAttributes: 0
WM/WMRVWatched : false
WM/MediaThumbWidth: 352
WM/MediaThumbHeight: 234
WM/MediaThumbStride: 1056
WM/MediaThumbRet: 0
WM/MediaThumbRatingSystem: 255
WM/MediaThumbRatingLevel: 255
WM/MediaThumbRatingAttributes: 0
WM/MediaThumbAspectRatioX: 4
WM/MediaThumbAspectRatioY: 3
WM/MediaThumbTimeStamp: 4642242360600493254
WM/MediaThumbType: 3
Duration: 00:31:57.72, start: 3.335374, bitrate: 8071 kb/s
Stream #0:0[0x5]: Subtitle: dvb_teletext
Stream #0:1[0x6]: Audio: mp2 (P[0][0][0] / 0x0050), 48000 Hz, stereo, s16, 2
24 kb/s
Stream #0:2[0x7]: Video: mpeg2video (Main), yuv420p, 720x480 [SAR 8:9 DAR 4:
3], 7500 kb/s, 29.97 fps, 29.92 tbr, 10000k tbn, 59.94 tbc
Stream #0:3[0x0]: Attachment: mjpeg
title : TV Thumbnail
dyerpunk
Post Sat Feb 11, 2012 6:06 am
Anyone have any sugestions?
Post Tue Feb 14, 2012 1:21 pm
post detailed log of when you play the file.
Post Tue Feb 14, 2012 5:37 pm
is your issue, once i get home will look into what causing thsi, but i think its down to ffmpeg issue.
Post Wed Feb 15, 2012 9:30 am
zip wrote:post detailed log of when you play the file.
