Disable On-line transcoding
gobater
Post Thu Feb 16, 2012 9:57 pm
I have disabled in transcoding in the "Serviio Console" however it is still performing transcoding for the On-line Sources (Profile: Samsung C-D series)
Has anyone else experienced this issue?
Best Regards,
Post Thu Feb 16, 2012 10:00 pm
Re: Disable On-line transcoding
Currently all online sources are transcoded
Post Thu Feb 16, 2012 10:22 pm
All online is transcoded, if it's not already in a streamable format (ie mpeg/mpegts/mp3). The transcode setting has no effect on Online streaming.
kappclark
Post Thu Feb 16, 2012 11:42 pm
zip wrote:All online is transcoded, if it's not already in a streamable format (ie mpeg/mpegts/mp3). The transcode setting has no effect on Online streaming.
Thank you for explaining this...
so would this mean that viewing HD sources online would require more horsepower from the CPU ?
Post Fri Feb 17, 2012 5:24 pm
Not really, it the resources can be just remuxed. Depends on the source and the profile you're using.
CaBrA
Post Tue Jun 23, 2015 11:50 am
Can I disable transcoding in online files? I just want serviio to be a media server without this extra function. Thanks.
Post Tue Jun 23, 2015 12:51 pm
No. It will not transcode if it is in a streamable format (ie mpeg/mpegts/mp3) otherwise they MUST be transcoded to mpegts.
CaBrA
Post Tue Jun 23, 2015 1:28 pm
jhb50 wrote:No. It will not transcode if it is in a streamable format (ie mpeg/mpegts/mp3) otherwise they MUST be transcoded to mpegts.
Nevermind, I found a solution: If I don´t want serviio to transcode videos I just use File Explorer to direct open a movie through Network (smb). If I prefer transcoder I open movie through bubblepnp + serviio. So, serviio gives me a plus feature.
