ARD Mediathek (german) => solved and working
htb
Post Fri Jan 27, 2012 9:48 pm
I've try to implement a plugin for the ARD Mediathek RSS feeds (see attachment).
In principle it seems to work: I extract the thumbnails and the url.
Test Data:
- RSS feed: http://www.ardmediathek.de/ard/servlet/ ... id=9176820
- RSS item url: http://www.ardmediathek.de/ard/servlet/ ... Id=9364516 (web page with embedeed rtmp stream)
ARDMediathek.groovy
2011.02.04
(2.33 KiB) Downloaded 2896 times
NOTE:
Could be that some entries are duplicated and only one of them is working correctly. May RSS problem or has to be fixed later.
Post Sun Jan 29, 2012 4:47 pm
Re: ARD Mediathek (german)
You probably have to split the url into a set of librtmp parameters, like playpath etc
htb
Post Mon Feb 06, 2012 5:42 am
Re: ARD Mediathek (german) => solved and working
thanks zip!
goldstar78i
Post Fri Feb 17, 2012 3:27 pm
U. wie funktioniert das nun? Kannst du mir helfen?
Can you explain, how you did it?
htb
Post Sat Feb 18, 2012 2:18 pm
You have to add the plugin to your serviio installation.
On the ARD-Mediathek there are RSS feeds for series and shows available.
Add such a RSS_URL via the Serviio-Console to the "Online Source"
That's it.
ammaree
Post Sat Feb 18, 2012 4:55 pm
@htb
Thanks, got it working on the Gottschalk Live show.
My challenge is now to get the id=xxxxxxx values for other shows so I can create the entries under online sources. We live is South Africa and since I am not German speaking (doing it for my German partner and she has a technology fear) I cannot make sense of the ARD Medithek site to understand where to look.
Can you (or anyone else) help
Appreciated.
htb
Post Sat Feb 18, 2012 7:03 pm
I think not all shows/series has RSS support :|
You have to find out the main page of a show (e.g "Sturm der Liebe" => "http://www.ardmediathek.de/ard/servlet/content/3516914?documentId=5290") and there is as Button "Diese Sendung abonieren". The button has the RSS logo too.
Please try out and let me know if it is working.
bye
olli
Post Wed Apr 25, 2012 8:52 pm
ARD Mediathek (german): new version
Thanks htb for his great work :D
His plugin has been the occasion on that I've developed two plugins by myself. I've done just two fixes to ARD: Not every program on ARD Mediathek is published in three different qualities, so there has been an error when one of these had been retrieved. The other fix is related to the use of regular expressions.
ARDMediathek.groovy
new version: 25.04.2012
(2.49 KiB) Downloaded 1278 times
ard-mediathek
Post Wed Mar 20, 2013 4:35 pm
It seems like ARD changed the URL Scheme for the RSS feeds.
On line 13 in the ARDMediathek.groovy file, change the URL that it looks like this:
final VALID_FEED_URL  = 'http://www.ardmediathek.de/export/rss/id=.*'
I also uploaded a patched version which works with "Tagesschau Feed" on my installation.
Should work with other feeds as well.
I hope this is not a problem for the author. Let me know if it is, i will remove the file.
Greetings ...
fnordsen
ARDMediathek.groovy
Patched Version (URL scheme)
(2.48 KiB) Downloaded 1173 times
Smitty
Post Wed Dec 18, 2013 12:54 pm
I've seen, that the ARD changed the URL Scheme for the RSS feeds again (it's now: http://mediathek.daserste.de/export/rss?sendung=1933898). So you have to change line 13 in the ARDMediathek.groovy file now to
final VALID_FEED_URL  = 'http://mediathek.daserste.de/export/rss.*'
eifel_wolf
Post Tue Jan 07, 2014 10:41 pm
I've just tried to use this plugin, but it won't work. What I've done:
1. Download of latest release of the plugin and copied to folder "plugin" of program folder
2. Defined a new online entry in service console, used for example the link "http://www.ardmediathek.de/export/rss/id=602916" for RSS and named it "Tatort", type is "video".
If I now try to access to online video there is an entry "Tatort" available, but if I select it there appears an empty screen ...
I've tried several kinds of content from the mediathek, it's all the time the same ...
Is there anything wrong in my definition? Is anyone else able to get this content via serviio?
Regards
Mario
TheZero
Post Thu Jan 09, 2014 1:01 pm
Try the following insert:
http://www.ardmediathek.de/export/rss.*
Works fine for me.
eifel_wolf
Post Thu Jan 09, 2014 9:45 pm
I've just changed line 13 of the plugin to this value, but it takes no affect to my defined online entries. What is my fault?
regli
Post Tue May 13, 2014 7:11 pm
Finally got this to work.
Two lines in the plugin need changing:
       final VALID_FEED_URL  = 'http://mediathek.daserste.de/export/rss'
         ThumbnailUrl = "http://www.mediathek.daserste.de" + linkParts1[1]
Then change the on-line source to:
Voila, at least for now.
Koemi
Post Sun Jun 01, 2014 7:01 pm
Ist es möglich den ARD livestream hinzuzufügen? Hab den den Link hinzugefügt rtsp://daserste.edges.wowza.gl-systemha ... te_int_576
Funktioniert aber leider nicht, hab ihn als livestrema hinzugefügt. War der einzige den ich gefunden hab. Und noch 2 andere Größen.
It is possible to add The ARD livestream? I add this link rtsp://daserste.edges.wowza.gl-systemha ... te_int_576
But nothing happend. I just found this One and 2 Otter Sitzes.
keksnase
Post Thu Jun 12, 2014 5:26 pm
working livestream url:
http://daserste_live-lh.akamaihd.net/i/daserste_de@91204/master.m3u8
R2D2
Post Mon Feb 23, 2015 12:49 am
I installed the latest version of the ARD mediathek plugin, but I only get a blank site...
I'm new to this, so any help/hints would be appreciated.
Return to Available plugins
Users browsing this forum: No registered users and 83 guests
