Hulu (US only)
Daviio
Post Fri Feb 10, 2012 1:30 pm
Re: Hulu (US only)
This plugin works great. I am having one issue though, I am only able to see about 25 episodes via serviio. I get a full listing when I use google reader. Is this just a limitation of the plugin or am I doing something wrong. I am able to get up to 50 listings with You Tube Feeds.
Post Fri Feb 10, 2012 1:31 pm
Re: Hulu (US only)
check the detailed log, it might skip some.
mkkyah
Post Sat Feb 18, 2012 12:37 am
Re: Hulu (US only)
Zip, thanks for serviio and Hulu plugin. My experiences are mostly very positive and hopeful for near future.
I experience random stops while streaming Hulu, it stucks with pause sign, but you have to cancel and start again from beginning, its very annoying. I'm not sure, maybe coincidence, but one other episode had no problems but The Voice S2E3 pauses randomly every 5-10-15 minutes. I had to switch to Tversity and watch the episode. For information: I use VPN while watching Hulu, connection may have temporary problems.
I had no problem with Tversity this time, but their last version handles such errors very good, it starts where you have left if something happens. Never been a fan of Tversity, so I hope I can uninstall it soon.
Here is the last part of the log:
2012-02-18 02:13:21,781 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://46.105.109.122/edge swfUrl=http://static.ilive.to/jwplayer/player.swf pageURL=http://www.ilive.to/ playpath=7f14kif8m902om7 swfVfy=0 live=1. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:273)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:255)
... 2 more
2012-02-18 02:13:35,815 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://46.105.109.122/edge swfUrl=http://static.ilive.to/jwplayer/player.swf pageURL=http://www.ilive.to/ playpath=p9p6783e22878ys swfVfy=0 live=1. It might not play.
... 2 more
2012-02-18 02:16:59,603 WARN [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 141! This is a possible error.
iMacUser
Post Sun Feb 19, 2012 5:12 am
Re: Hulu (US only)
Hi folks, i'm new to the forum so help is needed. i have used the serviio for over a year now but only using it to send shared media to my Sony Google TV NSX-GT1. Yesterday i upgraded to 0.6.2 and added the plug-in for Hulu which i am on a 7 day trial. Here is my problem.... i have been able to add the RSS link in my library and see the Hulu folder on my TV but when i click one of the files to play it my TV says the file is corrupted or the file is unknown. I'm pretty sure the configuration in Serviio is correct i am wondering why the Google TV can't play the files. Does this sound like a transcoding issue?? any suggestions are welcomed at this juncture!
insane822
Post Mon Feb 20, 2012 11:03 pm
Re: Hulu (US only)
Greetings! :D
I get errors with this feed. Is Hulu at fault here?
http://www.hulu.com/feed/show/6979/episodes
2012-02-20 16:51:37,510 DEBUG [FeedParser] Parsing feed 'http://www.hulu.com/feed/show/6979/episodes'
2012-02-20 16:51:37,728 DEBUG [FeedParser] Found matching url extractor (Hulu (US only)) for resource http://www.hulu.com/feed/show/6979/episodes
2012-02-20 16:51:37,728 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e14 - The Poor Kid
2012-02-20 16:51:38,975 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e14 - The Poor Kid: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:51:38,975 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e13 - A History Channel Thanksgiving
2012-02-20 16:51:39,679 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-02-20 16:51:39,951 DEBUG [FeedItemUrlExtractor] Hulu (US only): Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=rtmpe://cp39466.edgefcs.net/ondemand?auth=daEaWcgd.aUcIaOcmccbdbWd0bCdzbicgbE-bpqS6s-c0-4pLEtCt0Exm&aifp=sll02152008&slist=hulu12/336/60005336;.international=false&hgt=OZU7Pvs7j27-nhteNno7wiiF3NucgDd63CIY6pZVS94HfselGJs9IwESJ5Jo_m9OTPoT0uy8e2U1TfKPV3B5g-iL37X5rGoXfW4Z2T-qX6cGBL2un4Kzu1puWAElkYkl1naMIrGlz8i83SyT0JigrJF3mfb9kB3ZXo3f-6G6nLevDNBZ26jAU4GlKVwo1VoFQZHSnuJ7t4gAhQ8XFTWcAGroVn4PqUs4OwPmPVHpLA0QFWWkpvzUTJMfhipxhiaa&hgt_ver=331370278 app=ondemand?auth=daEaWcgd.aUcIaOcmccbdbWd0bCdzbicgbE-bpqS6s-c0-4pLEtCt0Exm&aifp=sll02152008&slist=hulu12/336/60005336;.international=false&hgt=OZU7Pvs7j27-nhteNno7wiiF3NucgDd63CIY6pZVS94HfselGJs9IwESJ5Jo_m9OTPoT0uy8e2U1TfKPV3B5g-iL37X5rGoXfW4Z2T-qX6cGBL2un4Kzu1puWAElkYkl1naMIrGlz8i83SyT0JigrJF3mfb9kB3ZXo3f-6G6nLevDNBZ26jAU4GlKVwo1VoFQZHSnuJ7t4gAhQ8XFTWcAGroVn4PqUs4OwPmPVHpLA0QFWWkpvzUTJMfhipxhiaa&hgt_ver=331370278 playpath=mp4:hulu12/336/60005336/agave50230503_6682154_H264_1000.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1, live=false, expiresImmediately=true, cacheKey=hulu_60005336_HIGH]
2012-02-20 16:51:39,951 DEBUG [FeedParser] Added feed item 1: 'South Park - s15 | e13 - A History Channel Thanksgiving' (rtmpe://cp39466.edgefcs.net/ondemand?auth=daEaWcgd.aUcIaOcmccbdbWd0bCdzbicgbE-bpqS6s-c0-4pLEtCt0Exm&aifp=sll02152008&slist=hulu12/336/60005336;.international=false&hgt=OZU7Pvs7j27-nhteNno7wiiF3NucgDd63CIY6pZVS94HfselGJs9IwESJ5Jo_m9OTPoT0uy8e2U1TfKPV3B5g-iL37X5rGoXfW4Z2T-qX6cGBL2un4Kzu1puWAElkYkl1naMIrGlz8i83SyT0JigrJF3mfb9kB3ZXo3f-6G6nLevDNBZ26jAU4GlKVwo1VoFQZHSnuJ7t4gAhQ8XFTWcAGroVn4PqUs4OwPmPVHpLA0QFWWkpvzUTJMfhipxhiaa&hgt_ver=331370278 app=ondemand?auth=daEaWcgd.aUcIaOcmccbdbWd0bCdzbicgbE-bpqS6s-c0-4pLEtCt0Exm&aifp=sll02152008&slist=hulu12/336/60005336;.international=false&hgt=OZU7Pvs7j27-nhteNno7wiiF3NucgDd63CIY6pZVS94HfselGJs9IwESJ5Jo_m9OTPoT0uy8e2U1TfKPV3B5g-iL37X5rGoXfW4Z2T-qX6cGBL2un4Kzu1puWAElkYkl1naMIrGlz8i83SyT0JigrJF3mfb9kB3ZXo3f-6G6nLevDNBZ26jAU4GlKVwo1VoFQZHSnuJ7t4gAhQ8XFTWcAGroVn4PqUs4OwPmPVHpLA0QFWWkpvzUTJMfhipxhiaa&hgt_ver=331370278 playpath=mp4:hulu12/336/60005336/agave50230503_6682154_H264_1000.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1)
2012-02-20 16:51:39,952 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e12 - One Percent
2012-02-20 16:51:40,810 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e12 - One Percent: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:51:40,810 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e11 - Broadway Bro Down
2012-02-20 16:51:43,084 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e11 - Broadway Bro Down: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:51:43,084 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e10 - Bass to Mouth
2012-02-20 16:51:43,889 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e10 - Bass to Mouth: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:51:43,889 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e9 - The Last of the Meheecans
2012-02-20 16:51:45,964 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e9 - The Last of the Meheecans: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:51:45,964 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e8 - Ass Burgers
2012-02-20 16:51:48,591 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e8 - Ass Burgers: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:51:48,591 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e7 - You're Getting Old
2012-02-20 16:51:50,900 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e7 - You're Getting Old: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:51:50,900 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e6 - City Sushi
2012-02-20 16:51:53,286 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e6 - City Sushi: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:51:53,287 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e5 - Crack Baby Athletic Association
2012-02-20 16:51:55,869 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e5 - Crack Baby Athletic Association: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:51:55,869 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e4 - T.M.I.
2012-02-20 16:51:58,016 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e4 - T.M.I.: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:51:58,016 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e3 - Royal Pudding
2012-02-20 16:52:00,916 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e3 - Royal Pudding: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:52:00,916 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e2 - Funnybot
2012-02-20 16:52:03,277 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e2 - Funnybot: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:52:03,277 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s15 | e1 - HumancentiPad
2012-02-20 16:52:04,182 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s15 | e1 - HumancentiPad: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:52:04,182 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s14 | e14 - Creme Fraiche
2012-02-20 16:52:06,309 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s14 | e14 - Creme Fraiche: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:52:06,309 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s14 | e13 - Coon vs. Coon & Friends
2012-02-20 16:52:08,593 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s14 | e13 - Coon vs. Coon & Friends: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:52:08,594 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s14 | e12 - Mysterion Rises
2012-02-20 16:52:10,798 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s14 | e12 - Mysterion Rises: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:52:10,798 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s14 | e11 - Coon 2: Hindsight
2012-02-20 16:52:11,750 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s14 | e11 - Coon 2: Hindsight: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:52:11,750 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s14 | e10 - Insheeption
2012-02-20 16:52:14,174 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s14 | e10 - Insheeption: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2012-02-20 16:52:14,174 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: South Park - s14 | e9 - It's A Jersey Thing
2012-02-20 16:52:16,204 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item South Park - s14 | e9 - It's A Jersey Thing: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
Post Tue Feb 21, 2012 5:33 pm
Re: Hulu (US only)
Are you in the US? They might have changed something otherwise or the episodes are not available.
kappclark
Post Sun Feb 26, 2012 12:31 pm
Re: Hulu (US only)
iMacUser wrote:Hi folks, i'm new to the forum so help is needed. i have used the serviio for over a year now but only using it to send shared media to my Sony Google TV NSX-GT1. Yesterday i upgraded to 0.6.2 and added the plug-in for Hulu which i am on a 7 day trial.
I was unaware the Hulu requires a subscription - I know Hulu PLUS has this requirement ...
I have been gettion Hulu delivered to the TV with no subscription...
LLoyd
Post Tue Mar 27, 2012 10:35 pm
Re: Hulu (US only)
Hi guys,
I am using Serviio 0.6.2 and I am trying to setup Hulu feeds. My renderer is a Playstation 3.
I've already installed the Hulu plug-in. Serviio.log confirms the following:
2012-03-27 12:37:18,237 INFO  [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy)
I've added the following Hulu feed to the Serviio console and clicked the "Save" button:
http://www.hulu.com/feed/show/58/episodes
Serviio.log displays the following error:
2012-03-27 14:47:36,353 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEcgdsdLcidrdsdCdOahatdsbcaYa_bich-bpCJv3-c0-2qNEyEv1HAu&aifp=sll02152008&slist=hulu14/513/40057513;.international=false&hgt=OZU7Pvs7j27-nhteNno7whOZgmjSVL_XLAnLzqwiAfGIuqC5RZ0eWcwg2bZDPoL3-q8QBKJ1CloySndpewU6QPkdIMRG2LthAjmpnbacDtUflP37nJxvkS-hMRxMpb4pq92gEwTUZbRDpAidsfYxu_PZ0GQ5wikZLgmh9dooNQRfa7weZhkMQi5BFX0oovOLw_Wva_o3GAr9sWRxhDYu9cbMmbIt-6aaE5v2xR7qDWai9nYv5z6T6yyKPvtuWp5M&hgt_ver=331370278 app=ondemand?auth=daEcgdsdLcidrdsdCdOahatdsbcaYa_bich-bpCJv3-c0-2qNEyEv1HAu&aifp=sll02152008&slist=hulu14/513/40057513;.international=false&hgt=OZU7Pvs7j27-nhteNno7whOZgmjSVL_XLAnLzqwiAfGIuqC5RZ0eWcwg2bZDPoL3-q8QBKJ1CloySndpewU6QPkdIMRG2LthAjmpnbacDtUflP37nJxvkS-hMRxMpb4pq92gEwTUZbRDpAidsfYxu_PZ0GQ5wikZLgmh9dooNQRfa7weZhkMQi5BFX0oovOLw_Wva_o3GAr9sWRxhDYu9cbMmbIt-6aaE5v2xR7qDWai9nYv5z6T6yyKPvtuWp5M&hgt_ver=331370278 playpath=mp4:hulu14/513/40057513/agave50223331_6497989_H264_650.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
ffmpeg displays the following two errors:
ffmpeg -i http://www.hulu.com/feed/show/2103/episodes
ffmpeg version N-38830-gf8353d5 Copyright (c) 2000-2012 the FFmpeg developers
  built on Mar 16 2012 14:44:32 with gcc 4.2.1 20070719  [FreeBSD]
  configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --enable-librtmp
  libavutil      51. 42.100 / 51. 42.100
  libavcodec     54. 10.100 / 54. 10.100
  libavformat    54.  2.100 / 54.  2.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 64.101 /  2. 64.101
  libswresample   0.  7.100 /  0.  7.100
http://www.hulu.com/feed/show/2103/episodes: Invalid data found when processing input
ffmpeg -i "rtmpe://cp39466.edgefcs.net/ondemand?auth=daEb.aWaSd1cBdNdNa5axbXaDdcbTcWbMa7-bpCJvZ-c0-YnNBvFq0HAv&aifp=sll02152008&slist=hulu6/530/60050530;.international=false&hgt=OZU7Pvs7j27-nhteNno7wun_CYsmW75EoLIC3VMcnBUdhklFCe1m8TPTkBhy2_7h0phruTKtVyA4wwOPth7aFDg3P4d3ydlGPSwmVHaDWiYep6d9-h5lGqjv-QKlPljac_El1FyutTY_2Sj6yUdP4gqXsPOLVQuVxagUFNbLZbyA2CkYqI27Mj1n8lAGQgEkEZvmo3y7PZ_cHHXEIRjyvgqAi0I8RhNRpI1ApFvD462W03GmwvBQgvvo-ufK6TPI&hgt_ver=331370278 app=ondemand?auth=daEb.aWaSd1cBdNdNa5axbXaDdcbTcWbMa7-bpCJvZ-c0-YnNBvFq0HAv&aifp=sll02152008&slist=hulu6/530/60050530;.international=false&hgt=OZU7Pvs7j27-nhteNno7wun_CYsmW75EoLIC3VMcnBUdhklFCe1m8TPTkBhy2_7h0phruTKtVyA4wwOPth7aFDg3P4d3ydlGPSwmVHaDWiYep6d9-h5lGqjv-QKlPljac_El1FyutTY_2Sj6yUdP4gqXsPOLVQuVxagUFNbLZbyA2CkYqI27Mj1n8lAGQgEkEZvmo3y7PZ_cHHXEIRjyvgqAi0I8RhNRpI1ApFvD462W03GmwvBQgvvo-ufK6TPI&hgt_ver=331370278 playpath=mp4:hulu6/530/60050530/agave50274683_9697413_H264_650.mp4"
Assertion failed: (digestLen == 32), function HMACsha256, file handshake.h, line 275.
Abort
Do I need to recompile one of my libraries? What are the steps I need to take to resolve this handshake error? I am running Serviio on a FreeBSD platform. Everything is working fine (other than these Hulu feeds). My "RTMPDump" version = 2.4.
Post Wed Mar 28, 2012 3:41 pm
Re: Hulu (US only)
might be old librtmp. Otherwise ask at their mailing list.
bananaco
Post Fri Apr 06, 2012 12:11 am
Re: Hulu (US only)
I too am getting the same error. I've updated rtmpdump to 2.4. I and recompiled ffmpeg. I don't know how to check if librtmp is the right version. My log is below:
2012-04-05 19:43:58,198 INFO [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy)
2012-04-05 19:43:58,265 INFO [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy)
2012-04-05 19:43:58,405 INFO [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy)
2012-04-05 19:44:23,520 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-04-05 19:44:31,839 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEaJb5aNcQa6bsb9dPbQd6c4b4bcdldXbF-bpFI5E-c0-1oMBAEpYIyu&aifp=sll02152008&slist=hulu5/579/60055579;.international=false&hgt=OZU7Pvs7j27-nhteNno7wreKBYxScEP4VtGZVmvDu_kDr4QAdK6bGtSkLxxGzmzS3OeBMyc0H2IXvmCoZUYXvzDUCwj55HYu08wJJo7S5PT59zC4ZIyLE1dJlpnBFQ9OAPiWto-x-Yc_uMrVnSoqmXXftPv7LGx1utTXIiurKGUAMbJy9AxaiagmUBWOGk-xQ5_wEnf0ArRcG3yJb-oYuxu3XzfX926GsVEBCLSXm8RjhdAHJos45MQ1sRuWbPJb&hgt_ver=331370278 playpath=mp4:hulu5/579/60055579/agave50279567_9826300_H264_650.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
... 2 more
2012-04-05 19:44:34,596 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEcld8bCb5cxdma_cmazdRd2btbNb8dCcM-bpFI5H-c0-XqFCzDu0DAo&aifp=sll02152008&slist=hulu10/709/60052709;.international=false&hgt=OZU7Pvs7j27-nhteNno7wvjvTXkyVPjX-DPxk6bFq_frulwgHp0_qJGsvQZORGSkWU8NQUGkUDCMlJHUjcAAGPSxD3s2jzdHgp29PB0mGq4Nbyts0der0asqYNPs4HK6PDGRnlqtA_CrzJclk_BGWveghS_vGCobDqHDunsB2o9I9tn_8PudN8rg7Vt-Nej3ks-PtE7kefqHQh87MpHahcd8wvFc7_lHhzD0RmvlT9e6ZVt3e_ltE8cNkmjppYsp&hgt_ver=331370278 playpath=mp4:hulu10/709/60052709/agave50276836_9783792_H264_650.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
... 2 more
Post Fri Apr 06, 2012 2:06 am
Re: Hulu (US only)
run the following in a console and post the results here.
ffmpeg -i "rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEaJb5aNcQa6bsb9dPbQd6c4b4bcdldXbF-bpFI5E-c0-1oMBAEpYIyu&aifp=sll02152008&slist=hulu5/579/60055579;.international=false&hgt=OZU7Pvs7j27-nhteNno7wreKBYxScEP4VtGZVmvDu_kDr4QAdK6bGtSkLxxGzmzS3OeBMyc0H2IXvmCoZUYXvzDUCwj55HYu08wJJo7S5PT59zC4ZIyLE1dJlpnBFQ9OAPiWto-x-Yc_uMrVnSoqmXXftPv7LGx1utTXIiurKGUAMbJy9AxaiagmUBWOGk-xQ5_wEnf0ArRcG3yJb-oYuxu3XzfX926GsVEBCLSXm8RjhdAHJos45MQ1sRuWbPJb&hgt_ver=331370278 playpath=mp4:hulu5/579/60055579/agave50279567_9826300_H264_650.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1"
bananaco
Post Fri Apr 06, 2012 10:14 pm
Re: Hulu (US only)
@moltra:
Thanks for your assistance attempt but I actually resolved the issue. In my case no matter how many times I downloaded and reinstalled rtmpdump 2.4 my mythbuntu box kept attaching 2.3 to my ./configure and make of ffmpeg. So I went into synaptic package manager and removed all 2.3 (rtmpdump and librtmp). I then went back and did a ./configure on ffmpeg and make and checkinstall. Restarted and it works now! Thanks for your support anyways...glad to know there are tons of smart people to help us newbies. And thanks to Zip and all the crew who wrote this kick-butt software!!
thinlizzy
Post Tue Apr 10, 2012 3:48 am
Re: Hulu (US only)
I am a windows user. WIll you provide an updated compiled version with these changes?
Post Tue Apr 10, 2012 4:29 am
Re: Hulu (US only)
thinlizzy wrote:I am a windows user. WIll you provide an updated compiled version with these changes?
If you have the current version of serviio you should already have these changes. Ubuntu (mythbuntu) has a problem in the setup files, that ffmpeg is compiled from.
What is the problem you are having thinlizzy?
thinlizzy
Post Tue Apr 10, 2012 5:27 am
Re: Hulu (US only)
I have a Samsung ES6500.
I added the hulu plugin on Serviio and I put the South Park RSS URL on the online sources. Two episodes appeared, but they hadn't played.
Post Tue Apr 10, 2012 5:36 am
Re: Hulu (US only)
enable detailed logging (see signature) and then look in the log after trying to play them and see if there is any errors. or attach the serviio.log file here so we can review it.
lewisj
Post Tue Apr 10, 2012 12:57 pm
Re: Hulu (US only)
Do you mean the South Park hulu feed?
thinlizzy
Post Wed Apr 11, 2012 2:19 am
Re: Hulu (US only)
I added the hulu plugin on Serviio and I put the South Park RSS URL on the online sources. Two episodes appeared, but they hadn't played.[/quote]
yes!
thinlizzy
Post Wed Apr 11, 2012 2:25 am
Re: Hulu (US only)
moltra wrote:enable detailed logging (see signature) and then look in the log after trying to play them and see if there is any errors. or attach the serviio.log file here so we can review it.
The log file was a good hint. My configuration was wrong and it was failing to transcode:
2012-04-10 19:22:20,111 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Cannot create transcoding folder: I:\TEMP\Serviio
java.io.IOException: Cannot create transcoding folder: I:\TEMP\Serviio
Is it normal transcoding hulu sources? Is there a way to avoid it?
Thanks!
Post Wed Apr 11, 2012 2:33 am
Re: Hulu (US only)
all online sources are transcoded by default
Return to Available plugins
Users browsing this forum: Google [Bot] and 5 guests
