MKV stops, then can't FF and stuff [on C650]
BlackThorne
Post Sun Feb 19, 2012 12:01 am
well, i kinda got through with it.
but the thing is I start playing a movie, all is good, and in some point it just stopped and jumped to the next movie.
after resetting serviio, TV, router and what not- i start playing the file again and although before this "crash" i was able to FF and Rewind now it's not possible.
tried remuxing and all that sometimes it fixed it, sometimes it didn't. so it seems that all the problems i encountered were Serviio related.
it happened in a bunch of files and the symptoms occur again and in the same matter.
[I've seen another post but didn't find any answer in it.]
I installed ver 0.6.0.1 which for now actually works. and when i think about it most of the problems woke when i updated....
so really, i'm just trying to give you some info on fixing it.
the server you made is awesome and it made my TV watching experience far better then before, so keep up the good work guys, you're awesome.
E.
Post Sun Feb 19, 2012 12:03 am
Re: MKV stops, then can't FF and stuff [on C650]
unforntunately its ffmpeg bugs that are causing this and we are hoping they will sort them soon.
BlackThorne
Post Sun Feb 19, 2012 10:23 am
so, using the old ffmpeg with 0.6.2 should work as well?...
Post Sun Feb 19, 2012 1:32 pm
BlackThorne wrote:so, using the old ffmpeg with 0.6.2 should work as well?...
yes but ud loose all online stuff.
BlackThorne
Post Sun Feb 19, 2012 1:56 pm
Cool, since I don't really use 'em, it seems like the best solution.
Post Sun Feb 19, 2012 2:07 pm
BlackThorne wrote:Cool, since I don't really use 'em, it seems like the best solution.
:) ok cool will update everyone once i find a working ffmpeg :)
BlackThorne
Post Sat Oct 27, 2012 4:44 pm
Hello again.
this is an old topic, but the same problem still persists. even after updating everything and what not.
sometimes [not always] remuxing the movies with mkv_tools helps. but still- if taking the file to a storage device that plugs in directly to the TV, no problem playing.
this is the only downside of this amazing DLNA server. i have to solve this. please help.
