Servioo Console - Library screen not showing on remote PC
mbailey
Post Sun Feb 19, 2012 5:22 pm
I am using logmein to connect from one Windows 7 machine to another Windows 7 machine.
I can't work out why, but when I view the serviio console screen and I select the Library tab, the screen does not refresh and it doesn't show me the screen correctly. If I select any of the other tabs they all load perfectly ok when accessing remotely.
Is there something special about the library tab?
mbailey
Post Sun Feb 19, 2012 5:33 pm
Re: Servioo Console - Library screen not showing on remote P
I just uninstalled Serviio and installed again and now it is working fine. Very strange...
Post Sun Feb 19, 2012 5:57 pm
check your running latest version of java 1.6.0 update 30/31
motherfo
Post Thu Feb 23, 2012 3:02 am
viewtopic.php?f=5&t=2175&view=previous <---- previously reported.
Killing console task via task manager and then re-opening makes it work.
I also have WHS 2011
I've attached an image of the java versions I have installed.
the 32 bit and the 64 bit version
Java installed
Post Thu Feb 23, 2012 4:46 am
Look at this thread. http://forum.serviio.org/viewtopic.php?f=5&t=20&p=117&hilit=logmein%E2%80%A6#p120
logmein has caused problems in the past.
motherfo
Post Fri Mar 02, 2012 6:40 pm
I'm using RDP, I didn't see logmein mentioned in that thread.
0.6.2 runs as a service for WHS 2011 I believe by default.
In the thread I linked, killing the console and re-opening usually fixes the bug.
djmattc
Post Thu Jan 17, 2013 5:28 pm
I am having the same issue and it surprises me that this issue was reported nearly a year ago and it still hasn't been addressed. This is not a LogMeIn or RDP issue. Every type of remote control software I've found has this issue with Serviio but no issues with any other software. The only issue I have is that I need to access the Library tab but that is the only tab which will not display! I can provide screenshots if required. I have a feeling that this issue may be because there isn't a physical display on the server that I am running Serviio on. There is a physical connection present (VGA and HDMI) but nothing connected. I've had to uninstall Serviio and use something else until this is fixed.
Post Thu Jan 17, 2013 5:38 pm
djmattc wrote:I am having the same issue and it surprises me that this issue was reported nearly a year ago and it still hasn't been addressed. This is not a LogMeIn or RDP issue. Every type of remote control software I've found has this issue with Serviio but no issues with any other software. The only issue I have is that I need to access the Library tab but that is the only tab which will not display! I can provide screenshots if required. I have a feeling that this issue may be because there isn't a physical display on the server that I am running Serviio on. There is a physical connection present (VGA and HDMI) but nothing connected. I've had to uninstall Serviio and use something else until this is fixed.
What os is the remote machine running/java version? Screenshot might help along with a log.
In terms of alternative solutions (which I personally think are nicer to use compared to using RDP), you can install the console on your main pc and point it to the remote pc http://www.serviio.org/component/conten ... e?id=21#q2 Alternatively there are WebUIs that can be installed on the remote machine allowing you to control the server using your web browser, as well as an App for Android and two apps to choose from for Windows Phone.
ttca
Post Sun May 11, 2014 10:04 am
I still also have this issue - when using RealVNC Remote desktop.
The problem is existent even in the newest version of serviio 1.4.1.2.
It happens only in the library tab - all other tabs are refreshed when selecting them.
When starting console, everything is fine. Then I minimize the console.
After some time (20-30minutes - not before) if console is opened, library tab is not displayed correctly. Instead you still see previously choosen tab. If I move over the tab with the mouse, some contents is refreshed and get visible (e.g. status button, etc).
Again, whole console application works fine with exception of the library tab!
After restarting serviio console, everything works fine - for the next 1/2 hour.
Users browsing this forum: Baidu [Spider], Google [Bot] and 26 guests
