patters
Post Tue Feb 21, 2012 12:30 am
Re: PACKAGE: Serviio 0.6.1 for Synolgy NAS (ARM & Intel)
ammadeus wrote:Im new in SSH, but with Google's help I managed to read the profiles.xlm file.
However, when I try editing (adding your code), or replacing the original file with edited copy,
I get PERMISSION DENIED message. Also, while I'm in the profiles.xlm file at the bottom of the Terminal (Mac user)
i see it say READ-ONLY.
I am not sure if you can help here. It seems to me it's NAS thing, not Serviio's.
Sorry, missed this one. You need to log into the SSH session as the user "root", using the same password you set for the admin account. Then you have permission to do everything (be careful though - a mistyped command could really mess things up!)
MrHanky
Post Tue Feb 21, 2012 2:03 am
Re: PACKAGE: Serviio 0.6.2 for Synolgy NAS (ARM & Intel)
patters wrote:The MKV may have header compression enabled:
viewtopic.php?f=6&t=1132
Thanks for the tip - I ran mkvmerge and remuxed the mkv file with no header compression - the new file has the same problems as the previous one.
Any other suggestions?
Donniedarko
Post Fri Mar 16, 2012 6:47 pm
Hey Folks
I installed Serviio on my NAS and it worked. I later restarted the NAS and found that Serviio had been stopped and when I try to run it it nothing happens. Serviio doesnt start (the run button is there still). Not sure what the problem is.
The status on Java is also stopped (no run button though). But that was the case also when it worked before the restart of NAS.
Also when I start serviio it says "Cannot connect to Serviio server, it does not seem to be running." but the status of the "program" is running in package center. Edit: okay started to work when I run Media Server. Thought it would not matter if I stopped it. But first issue remains though.
patters
Post Sun Mar 18, 2012 12:19 pm
Sounds like something is broken - log in using SSH, then look at the Serviio log for clues:
cat /volume1/@appstore/Serviio/log/serviio.log | more
qwerty1982
Post Fri Mar 30, 2012 2:04 pm
complete noob here, can any one help me please?
im having issues trying to get serviio on my synology ds212j, can you help?
I have folloed your guide and have down loaded the java, placed it in a shared public folder but when i go to install the java it says it can not find it, the address line it says it is trying to find is exact as it is on the nas. what have i done wrong?
nico1375
Post Wed Apr 25, 2012 11:29 am
I installed your package on my DS1511+.
I can launch it but it doesn't detect my PS3 unless I add it manually in the renderers list. And the PS3 doesn't detect serviio on the NAS either.
Serviio user has RW rights on the /volume1/video folder.
Are there other specific priviledges to grant?
I have opened (deactivated) my firewall.
I also have installed serviio on my macbook and it works fine, immédiately detected by my PS3.
Another thing that confuses me is that in the list of the renderers appears my squeezebox boom with IP : 10.0.0.17 ... which is not Squuezebox's IP but NAS IP (2nd LAN, since this model has 2 network interfaces).
I tried to bind it with one IP or the other, no result. It just puts in Red font :
Cannot connect to Serviio server, it does not seem to be running. Exiting...
Rest error to "status" : Internal Server Error (500)
Any idea?
Precisions : When using the terminal to start servio-wrapper.sh, here's the output
DS1511> sh serviio-wrapper.sh
Apr 25, 2012 3:20:15 PM org.restlet.ext.net.HttpClientHelper start
INFO: Starting the HTTP client
Apr 25, 2012 3:20:15 PM org.restlet.engine.http.connector.HttpServerHelper start
INFO: Starting the internal HTTP server on port 8123
Exception in thread "main" java.lang.RuntimeException: java.net.BindException: Address already in use
at org.serviio.restui.RestletProxy.runServer(Unknown Source)
at org.serviio.restui.RestletProxy.checkForRunningInstances(Unknown Source)
at org.serviio.restui.RestletProxy.main(Unknown Source)
at org.serviio.restui.ServiioWrapper.main(Unknown Source)
Caused by: java.net.BindException: Address already in use
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:383)
at java.net.ServerSocket.bind(ServerSocket.java:328)
at java.net.ServerSocket.bind(ServerSocket.java:286)
at org.restlet.engine.http.connector.BaseServerHelper.createServerSocket(BaseServerHelper.java:118)
at org.restlet.engine.http.connector.BaseServerHelper.start(BaseServerHelper.java:251)
at org.restlet.engine.http.connector.HttpServerHelper.start(HttpServerHelper.java:69)
at org.restlet.Server.start(Server.java:585)
at org.restlet.Component.startServers(Component.java:601)
at org.restlet.Component.start(Component.java:528)
... 4 more
patters
Post Fri Apr 27, 2012 11:24 pm
'Address already in use' in that error probably means that Serviio was already running, and you tried to launch a second process. Very occasionally this happens when it doesn't shut down properly. You can see it by running the commands ps or top (Ctrl-C to exit). You can kill a stuck Serviio process by taking its process id from the ps output, then kill -9 [id].
kbundy
Post Wed May 02, 2012 9:42 am
Hi
Just installed the package after many attempts onto my DS1812+ and I'm really impressed.
However I have found one problem with the audio streams. If i have a file that has Stereo and DD5.1 it send both of these streams to my Samsung UE55ES8000 as stereo tracks..?? I have tried with transcoding off and on but it makes no difference, and if i do have transcoding on I make sure that the audio setting it on "Keep original"
Any ideas..??
kbundy
Post Wed May 02, 2012 10:06 am
kbundy wrote:Hi
Any ideas..??
Ok, solved my own problem I had the profile set on Samsung C/D series and my TV is a ES series. I have changed it to Generic and 5.1 passes through OK.
Alaska99
Post Tue May 15, 2012 2:09 am
Hello
I just installed serviio on my DS1512+ and when I click on serviio icon to start control pannel I got a white window with "5af" write on the upper left corner. (see print screen attached)
Someone can help me please?
thank you
Synology DS1512+ with DSM 6.0 beta 3gig ram | Blueray Sony BDP-S390 firmware M11.R.0422 | Blueray Sony BDP-BX58 | PS3 with latest firmware | Router Asus RT-AC68U Merlin firmware | Samsung TV UN65HU9000
rgill90
Post Tue Jul 03, 2012 12:56 pm
Hi
Been using this package for a while now and love it. Since I've moved out of my parents I have come across the 'power saving' problem - as I'm now paying the electricity bill I'm anxious to get it sorted! I've done as suggested here though and all is OK (manual updates, etc)
But I've just been sitting here at work eating my lunch and had an idea - Can i set a cron job - a command line string set to run at x time on the NAS in order to force a scan to tidy up stuff I've removed or index stuff I've added? That way I can 'automate' a forced update. I'd set it to run, say at maybe midnight everyday then force the NAS to shutdown once it's done or something.
Come to think of it I guess I could force an update and do a process listing to see what command it fires off and create a crontab on the NAS....?
patters
Post Sat Jul 07, 2012 11:02 am
Yes that's certainly possible. Serviio has a REST API - there are specs published here. So you can replicate anything that the Console application does (such as a Force Refresh). The easiest way would be to use the curl command. It's not on the NAS by default, but you can get it from ipkg if you bootstrap your syno.
Nowhereman17
Post Wed Jul 11, 2012 7:05 pm
First let me say thanks to those that have developed and supported Serviio.
I have had an issue with using plugins properly on my DS411 and getting updated data through RSS/Weblink.
Serviio installed correctly, I can run the server and access the Serviio program and see Serviio from my PS3. I have added the plugin pack from WildRushSykes http://forum.serviio.org/viewtopic.php?f=20&t=3820 to my public folder and given full R/W access to the Serviio user.
When I attempted to add a few RSS feeds only a couple show up on the PS3 (CNN & Gametrailers) where others like Comedycentral didn't show at all (I assume since I am from Canada and cannot access them?).
So when I access the videos -> Online section I see entries for CNN & Gametrailers but nothing in the folders - cannot get any to download. I've tried restarting/refreshing etc but to no avail.
I'm sure I'm missing something simple but for 2 days of trying and reviewing the forums for possible solutions I have not been able to find a solution.
Any ideas?
(Note: I've not tested being able to access any other video content already stored on my NAS, I was just keen to check out the RSS feed feature. I've also enabled Web Station & User Home. My default guest account is disabled but I don't expect that is a cause).
Nowhereman17
Post Thu Jul 12, 2012 2:23 pm
I did test last night and I can play movies etc from the server to my PS3. So it seems the only issue I cannot resolve is to get RSS feeds to update videos. Any help would be appreciated, I'm a bit psyched by this feature and keen to try it out.
Thanks!
Alaska99
Post Thu Jul 12, 2012 8:30 pm
Someone try the new DSM 4.1 beta ? All folder with french character like "é" are not indexed and not displayed....
patters
Post Fri Jul 13, 2012 12:50 pm
Thanks for reporting that. I'll take a look.
patters
Post Fri Jul 13, 2012 1:09 pm
I forgot - you always need to stop Serviio, and reinstall my Java package if you've done a DSM upgrade. The Java package installs the Linux locale support which is missing in DSM (essential for UTF-8 character support in Java).
Alaska99
Post Fri Jul 13, 2012 9:05 pm
You're right!! Reinstall java and now all work fine!
Thank you so much!!
:D
patters
Post Tue Jul 24, 2012 11:22 am
Re: PACKAGE: Serviio 1.0 for Synolgy NAS (ARM & Intel)
Package updated to Serviio 1.0! Details in first post.
xs2inattar
Post Tue Jul 24, 2012 8:40 pm
Just installed 1.0 on synology.
while using serviio console from a windows machine, i am getting the following error in the log.
2012-07-24 16:38:32,641 DEBUG [ServiioConsole] Initializing Serviio Console
2012-07-24 16:38:32,664 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2012-07-24 16:38:32,666 INFO  [ServiioConsole] Starting Serviio Console
2012-07-24 16:38:32,759 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2012-07-24 16:38:32,803 INFO  [ServiioConsole] Connecting to Serviio REST on 192.168.1.11:23423
2012-07-24 16:38:32,962 INFO  [restlet] Starting the HTTP client
2012-07-24 16:38:33,473 INFO  [restlet] Stopping the HTTP client
2012-07-24 16:38:33,473 DEBUG [ServiioConsole] Retrieving preferred console language
2012-07-24 16:38:33,478 INFO  [restlet] Starting the HTTP client
2012-07-24 16:38:33,748 ERROR [ServiioConsole] Unexpected REST error: Internal Server Error (500) - checkForUpdates : checkForUpdates : checkForUpdates : checkForUpdates
---- Debugging information ----
message             : checkForUpdates : checkForUpdates
cause-exception     : com.thoughtworks.xstream.mapper.CannotResolveClassException
cause-message       : checkForUpdates : checkForUpdates
class               : org.serviio.ui.representation.ConsoleSettingsRepresentation
required-type       : org.serviio.ui.representation.ConsoleSettingsRepresentation
path                : /consoleSettings/checkForUpdates
2012-07-24 16:38:33,749 INFO  [restlet] Stopping the HTTP client
2012-07-24 16:38:33,749 DEBUG [ServiioConsole] Setting console locale to be: en
2012-07-24 16:38:33,759 INFO  [Messages] Loaded console message bundle for locale: en
2012-07-24 16:38:33,764 INFO  [restlet] Starting the HTTP client
2012-07-24 16:38:34,076 ERROR [ServiioConsole] Unexpected REST error: Internal Server Error (500) - edition : edition : edition : edition
message             : edition : edition
cause-message       : edition : edition
class               : org.serviio.ui.representation.ApplicationRepresentation
required-type       : org.serviio.ui.representation.ApplicationRepresentation
path                : /application/edition
2012-07-24 16:38:34,077 INFO  [restlet] Stopping the HTTP client
2012-07-24 16:38:34,078 ERROR [ServiioConsole] Unexpected exception occured: null
   at org.serviio.console.ServiioConsole.main(ServiioConsole.java:110)
   at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
   at com.exe4j.runtime.WinLauncher.main(Unknown Source)
2012-07-24 16:38:34,086 INFO  [ServiioConsole] Leaving Serviio Console
Users browsing this forum: Baidu [Spider] and 18 guests
