Philips SLA5520 wifi music player not working with Serviio
kleptonite
Post Tue Feb 21, 2012 8:00 pm
I have searched the forum and I can't find any references to this device.
I have installed Serviio on a windows vista machine. It can see the SLA5520 and I have chosen the 'Philips' profile (I have tried several others).
The SLA5520 can also see the Serviio, however I can't get the SLA to show me any audio files via the Serviio entry.
I am hopeful that this won't be too difficult, since I also have a WDTVLiveHub, and the SLA plays perfectly with that.
I am attaching a log file (debug was switched on near the end, around the 20:30 point).
I am also attaching the output from DeviceSpy for the SLA5520 and the result of the DLNA product search.
SLA5520SinkOutput.txt
Sink Output from Device Spy
(369 Bytes) Downloaded 1120 times
SLA5520_DLNA_Certified_Product_Search.csv
DNLA search result
(281 Bytes) Downloaded 1060 times
Serviio log
(348.68 KiB) Downloaded 1079 times
Thank you
Post Tue Feb 21, 2012 8:19 pm
Re: Philips SLA5520 wifi music player not working with Servi
<Profile id="25" name="Philips SLA5520" extendsProfileId="1">
           <Matches container="flac" />
           <Matches container="ogg" />
           <Matches container="adts" />
        </Audio>
kleptonite
Post Tue Feb 21, 2012 11:35 pm
Thank you for such a prompt reply, Cerebus.
Howvever, I have patched the profiles.xml in config, stopped and restarted the server and restarted the console but I can't see the new profile in the drop down.
Also I can't locate any advice on what to do to update a profile - no doubt it exists, I just can't find it!
Post Wed Feb 22, 2012 12:48 am
restart pc running serviio
Post Wed Feb 22, 2012 8:19 am
kleptonite
Post Wed Feb 22, 2012 9:52 am
Thank you for that, Cerberus, it was too obvious for me to think of it!
So now I can select the new profile, but the overall situation hasn't changed - the two elements can see each other but they appear not to be communicating.
Is there anything else that can be tried? I have tried re-booting both the PC and the SLA but - no change.
Thank you
Post Wed Feb 22, 2012 1:00 pm
kleptonite wrote:Thank you for that, Cerberus, it was too obvious for me to think of it!
Thank you
have you got any other DLNA devices on your network ?
if you do do they work?
if you dont have a read of our fact pages to check you have correct ports open and that you have bound your servers ip in serviio console.
http://www.serviio.org/index.php?option ... icle&id=21
Return to Philips
