Thu Feb 23, 2012 1:43 pm by Xmantium
The table view should be the default view when a user accesses the site, after a user clicks program name then the full information should show
I used RoboForm to automatically fill out the 4oD data when it was the same, just copied and pasted the data i needed. Managed to add most popular 4oD shows.
Moltra can you delete the none plugins data you and i added before, i will add these back again with the correct plugin
Also it will be cool with the tables have more info, even better same icons appear next to URL stating its Video Source, web resource ect
done a mickup attatched
- Attachments
- mockup.jpg (19.54 KiB) Viewed 61588 times
Console using
ServiiDroid for Android,
ServiiMetro and
ServiiWP for Windows Phone and
WebUI for iOS
