Smart Cache/Buffer
If you can't make it auto at least manual
will wrote:Serviio is buffering the content as it transcodes it into a temp file first
zip wrote:That is not the case for live streams, but for static online content yes.
The problem with buffer is that it should really be done on the renderer side (and some do it quite well, eg xbox). If the server waits for a buffer to fill in the play request from the TV will probably time out and fail.
zip wrote:As I said, the request will expire if we wait for a buffer to be filled
lazybones wrote:I wonder if Serviio couldn't send looped buffering video to the player to cover the periods of buffering to keep the player happy.
Pedja wrote:I do not care if duration would be messed up. I am using it to watch online streams, where duration is not important, and that is where buffering is most needed. I am pretty sure other feel the same way.
