Philips 42PFL7606K video thumbnails
mike9677
Post Fri Feb 24, 2012 7:16 am
hello there,
is it possible to use the information from .nfo files or to see a folder.jpg on the TV ??
mike
Post Fri Feb 24, 2012 8:11 am
Re: Philips 42PFL7606K video thumbnails
mike9677
Post Fri Feb 24, 2012 8:32 am
hello...
i have read this and named a .jpg to "movie.jpg".
Or does this mean, the .jpg musst be named for example "Avatar.jpg" ??
mike
a Movie folder, on my PC, looks like this:
Post Fri Feb 24, 2012 8:48 am
{media_file_name}.jpg ==> 300.jpg for 300.mkv
mike9677
Post Fri Feb 24, 2012 9:24 am
OK... thank you very much. I will trie it later at home.
Mayby another question (sorry for off topic): all the .mkv's are not possible to skip/fast forward like the .avi files are.
how can i fix this problem ??
mike
Post Fri Feb 24, 2012 1:26 pm
mike9677 wrote:OK... thank you very much. I will trie it later at home.
mike
nope device wont skip on transcoded files and mkv have to be transcoded as they are not natively supported by the device.
mike9677
Post Fri Feb 24, 2012 2:11 pm
as you can see ... mkv is supported !
exctract from my manual
Post Fri Feb 24, 2012 2:13 pm
ok let see if the manual is correct.
remove this line from the philips profile
Post Fri Feb 24, 2012 3:51 pm
mike9677 wrote:as you can see ... mkv is supported !
only with 24fps ?!
mike9677
Post Fri Feb 24, 2012 4:01 pm
What does that mean ??
Post Fri Feb 24, 2012 4:02 pm
mike did u try what i asked ?
mike9677
Post Fri Feb 24, 2012 5:17 pm
Yes i tried it, but no success !! I just started serviio (Server and Console) New or do i have to start the PC new ??
And BTW. The tv doesnt show the thumbnails
Post Fri Feb 24, 2012 5:29 pm
you need to restart both serviio server and console ( generially its easy to just restart pc after making the change).
i didnt expect it to work, it was to show you that even though it says in the manual that they are supported that actually they are not, so theres nothing we can do, but transcode them like we had.
mike9677
Post Fri Feb 24, 2012 5:42 pm
But how can it be transcoded so that i can fast foreward and Things like that ?
Post Fri Feb 24, 2012 6:01 pm
mike9677 wrote:But how can it be transcoded so that i can fast foreward and Things like that ?
it cant, as i already told u device doesnt support that for transcoded files.
Return to Philips
