nfo files?
Hooded
Post Fri Feb 24, 2012 6:10 pm
nfo files?
OK maybe I'm blind.
Where are the nfo files that Serviio is supposed to be able to read for metadata?
I installed XBMC no problems. Went with the stable version. Spent the best part of a day figuring out the options and getting it configured to a work the way I want it.
I have now done a complete search on computer that it is installed on for *.nfo files. The computer has 0 nfo files on it.
Exporting the library doen't output a nfo file either. It out puts xml files.
Is there a tutorial or a guide to get Serviio working with XBMC any place?
Post Fri Feb 24, 2012 6:42 pm
Re: nfo files?
there currently is no guide but i will do you one shortly :)
EDIT: looks like we dont need one as XMBC have kindly done one on there own wiki.
http://wiki.xbmc.org/index.php?title=Im ... rt_library
Hooded
Post Sat Feb 25, 2012 3:28 pm
Re: nfo files?
Thanks again Cerberus
Looks like a whole lot more messing around to get it just the way I want it LOL
Post Sat Feb 25, 2012 6:03 pm
Re: nfo files?
Hooded wrote:Thanks again Cerberus
thats why i use the online source method and this app, so much easier/faster.
http://wiki.serviio.org/doku.php?id=therenamer
Return to General discussion
