Samsung TV UN46D6000 Format Unsupported Error
drunkwithpower
Post Sun Feb 26, 2012 10:21 pm
All-
I am having some very big issues with Serviio and my Samsung UN46D6000 TV. For some reason a ton of my DVD rips (MKV format using MakeMKV) will not play - I get the format unsupported error. These are all straight DVD copies and I am not quite sure why my TV won't play them through Serviio. The profile I am using is the Samsung C/D Series.
For testing purposes I copied a couple of the DVD rips to a USB flash drive and they played perfectly on the TV. Anyone got any ideas?
Post Sun Feb 26, 2012 10:24 pm
Re: Samsung TV UN46D6000 Format Unsupported Error
drunkwithpower wrote:All-
USB test is pointless as DLNA and USB work on completely different system and can not be compared.
please provide ffmpeg -i and mediainfo reports on the file that wont play.
also check this out: viewtopic.php?f=5&t=5189&hilit=makemkv
drunkwithpower
Post Sun Feb 26, 2012 11:14 pm
Thansk for the info - I will take a look. I was only metioning the USB part to show the file format was something the TV could handle. Most of my video library won't play right now so I guess I'll just pick a file to supply the info you requested.
drunkwithpower
Post Sun Feb 26, 2012 11:31 pm
I went ahead and download the latest 32-bit ffmpeg build for Windows and copied it into the proper directory for Serviio. It looks like this might have fixed my issue. Several files I couldn't play before I can play now. Excellent! I will keep testing.
Oh, and I am now also able to play a couple of bluray rips I could never play on the TV before. This seems to be the fix I needed.
Thanks Cerberus!
Last edited by drunkwithpower on Sun Feb 26, 2012 11:33 pm, edited 1 time in total.
yer that why i stated that cause if it plays on USB does not mean the same file is supported via DLNA and vise versa.
drunkwithpower wrote:I went ahead and download the latest 32-bit ffmpeg build for Windows and copied it into the proper directory for Serviio. It looks like this might have fixed my issue. Several files I couldn't play before I can play now. Excellent! I will keep testing.
Thanks Cerberus!
no problems thats what im here for :) if you have any more troubles or question dont hesiate to give me a shout, and a PM with a link to a thread if i have missed a question, you need me to look at. :)
kurtnelson
Post Mon Feb 27, 2012 12:19 pm
Hi, i got the same problem would like to know where to put the new ffmpeg. In the serviio/lib folder or needs it to be in another place?
Post Mon Feb 27, 2012 1:05 pm
kurtnelson wrote:Hi, i got the same problem would like to know where to put the new ffmpeg. In the serviio/lib folder or needs it to be in another place?
yes, there, overwrite the old one (but make a backup copy first).
kurtnelson
Post Mon Feb 27, 2012 2:24 pm
Thanks a lot its working now.
Nice software and nice support!
Sincerely BonzenPaule
drunkwithpower
Post Mon Feb 27, 2012 4:47 pm
As a follow-up, the filename I downloaded was ffmpeg-git-b6ff81d-win32-static, and I overwrote the current version of ffmpeg in the following directory:
Program Files\Serviio\Lib\
lok
Post Thu Mar 01, 2012 9:50 pm
Serviio was working great up to somedays ago. Now I keep getting same error here. TV Model: UN40D6400.
Tried the workaround above and it works right after restarting Serviio service, but I receive the same error again after watching the first mkv file. It'll get back to work after restarting Serviio service again.
Anyone faced (and solved) this problem?
Regards
Post Thu Mar 01, 2012 10:51 pm
lok wrote:Serviio was working great up to somedays ago. Now I keep getting same error here. TV Model: UN40D6400.
Regards
It has been fixed, i would guess u have other issues aswell but without your serviio log file i wont be able to advise more.
lok
Post Mon Mar 05, 2012 10:52 pm
Regards
Here it is (attached)
(119.11 KiB) Downloaded 478 times
lok
Post Mon Mar 05, 2012 11:34 pm
Regards
Problem Solved.
For some reason after setting up a static IP for my TV's wireless adapter Serviio would mess up IPs: instead of showing TV's IP (192.168.11.9) it was showing routers IP (192.168.11.1).
I just removed static IP and things were back to normal.
extensa31
Post Wed May 23, 2012 10:25 pm
hello everyone,
got the same tv model, and I have the same problem with MKV files.
The only difference is that I'm on Mac Os x, so can't really try using the ffmpeg version that you gave the link for. I used SVN to obtain the latest version from ffmpeg, and compiled it myself. I tried then substituting as you suggest, but nothing has changed, and still can't reproduce them.
was the version you linked a specially modified one? I' using 26402
Thanks a lot for the support you're providing, and let me know if you need more info!
extensa31
Post Wed May 23, 2012 10:47 pm
oh, and as I know you're going to ask me for the ffmpeg -i, here you have it:
MacBook-Pro-de-Constantino:Peliculas y series constantino$ ffmpeg -i Fringe.S04E22.720p.HDTV.X264-DIMENSION.mkv
FFmpeg version SVN-r26402, Copyright (c) 2000-2011 the FFmpeg developers
built on May 23 2012 23:11:22 with llvm_gcc 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.1.00)
configuration: --enable-libmp3lame --enable-shared --disable-mmx --arch=x86_64
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 1 / 0.16. 1
libavformat 52.93. 0 / 52.93. 0
libavfilter 1.74. 0 / 1.74. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 0x7f926080b000] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 24.00 (24/1)
Input #0, matroska,webm, from 'Fringe.S04E22.720p.HDTV.X264-DIMENSION.mkv':
Duration: 00:42:32.88, start: 0.000000, bitrate: 384 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 fps, 24 tbr, 1k tbn, 47.95 tbc
Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 384 kb/s
and here the log:
2012-05-23 23:16:52,322 INFO [Device] Created UPnP Device with UUID: 07f90c8c-4545-38b0-b145-074673426582, bound address: 192.168.1.129
2012-05-23 23:16:52,417 INFO [PluginCompilerThread] Looking for plugins at /Applications/Serviio/Serviio.app/Contents/Resources/Java/plugins
2012-05-23 23:16:52,418 INFO [PluginCompilerThread] Started looking for plugins
2012-05-23 23:16:52,772 WARN [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2012-05-23 23:16:52,805 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-23 23:16:52,966 INFO [WebServer] WebServer starting on port 8895
2012-05-23 23:16:53,018 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-23 23:16:53,019 INFO [EventDispatcher] Starting EventDispatcher
2012-05-23 23:16:53,019 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-23 23:16:53,087 INFO [RendererSearchSender] Searching for Renderer devices
2012-05-23 23:16:53,087 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-05-23 23:16:53,100 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.1.129, timeout = 0
2012-05-23 23:17:16,136 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-05-23 23:17:16,491 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: es
2012-05-23 23:17:19,174 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-05-23 23:17:19,179 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-23 23:17:19,205 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
Post Wed May 23, 2012 11:09 pm
that still looks like an old FFmpeg, they don't use SVN for a long time now. The bundled one should be ok for you. Just make sure you're using the correct Profile.
extensa31
Post Wed May 23, 2012 11:37 pm
the bundled one didn't work...
on the last log there was a problem where libsmtrp was not activated. I recompiled ffmpeg with it, and got the warning gone (attaching the new log), but it still does not work.
ONly thing I can think off, is reinstalling the app, using the ffmpeg bundled, and sending you the logs, see if that can help. :(
new log:
2012-05-24 01:31:31,748 INFO [WebServer] Socket buffer set to 65535 bytes
2012-05-24 01:31:31,749 INFO [Device] Created UPnP Device with UUID: 07f90c8c-4545-38b0-b145-074673426582, bound address: 192.168.1.129
2012-05-24 01:31:31,852 INFO [PluginCompilerThread] Looking for plugins at /Applications/Serviio/Serviio.app/Contents/Resources/Java/plugins
2012-05-24 01:31:31,852 INFO [PluginCompilerThread] Started looking for plugins
2012-05-24 01:31:32,272 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-24 01:31:32,458 INFO [WebServer] WebServer starting on port 8895
2012-05-24 01:31:32,473 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-24 01:31:32,473 INFO [EventDispatcher] Starting EventDispatcher
2012-05-24 01:31:32,473 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-24 01:31:32,506 INFO [RendererSearchSender] Searching for Renderer devices
2012-05-24 01:31:32,506 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-05-24 01:31:32,507 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.1.129, timeout = 0
2012-05-24 01:31:58,574 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-05-24 01:31:58,580 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-24 01:31:58,603 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-05-24 01:32:01,884 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-05-24 01:32:02,521 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: es
Post Sun May 27, 2012 8:31 pm
extensa31
Post Sun Jun 03, 2012 10:24 pm
Hey Petr!
I jsut came after a while to check if there has been any news on this topic, and Just realised you answer a couple days later. Not at my home now, but I'll post everything as soon as I'm back. thanks for answering!
Users browsing this forum: Google [Bot] and 31 guests
