Ps3 unsupported mp4 video
mkkyah
Post Mon Feb 27, 2012 11:04 am
I have my camera videos under pictures in mixed formats, because of different phones, cameras etc. My renderer is PS3, serviio is on Qnap NAS.
Some of the mp4 files are working well but some of them are listed as "unsupported data". I have tried adding <Matches container="mp4" vCodec="mpeg4" /> line under my <!-- all other unplayable files just transcode to mpeg2 --> list. That helped to see and play the files, but all my mp4 files started to be transcoded and that is slow on qnap. Is there a way to list and play this files without transcoding and without forcing other already working files to transcode?
Here is NOT working file properties, which comes from a phone:
Complete name : ...09052011032.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 33.7 MiB
Duration : 2mn 14s
Overall bit rate : 2 100 Kbps
Encoded date : UTC 2011-05-09 16:05:11
Tagged date : UTC 2011-05-09 16:05:11
Format : MPEG-4 Visual
Format profile : Simple@L4a
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : 20
Duration : 2mn 14s
Bit rate mode : Variable
Bit rate : 2 001 Kbps
Nominal bit rate : 1 800 Kbps
Maximum bit rate : 2 000 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 14.030 fps
Minimum frame rate : 3.717 fps
Maximum frame rate : 30.426 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.464
Stream size : 32.1 MiB (95%)
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2mn 14s
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 48.0 KHz
Stream size : 1.54 MiB (5%)
Encoded date : UTC 2011-05-09 16:05:12
Tagged date : UTC 2011-05-09 16:05:12
Here is a file properties which is working:
Complete name : ....021.MP4
Format : MPEG-4
Format profile : Sony PSP
Codec ID : MSNV
File size : 60.2 MiB
Duration : 56s 557ms
Overall bit rate : 8 934 Kbps
Encoded date : UTC 2011-02-27 12:31:07
Tagged date : UTC 2011-02-27 12:32:04
Format profile : Advanced Coding Efficiency@L4
Codec ID : 20
Bit rate : 9 000 Kbps
Maximum bit rate : 14.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.326
Stream size : 59.8 MiB (99%)
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 56s 533ms
Bit rate : 64.0 Kbps
Sampling rate : 24.0 KHz
Stream size : 442 KiB (1%)
Post Mon Feb 27, 2012 7:32 pm
Re: Ps3 unsupported mp4 video
mkkyah wrote:Is there a way to list and play this files without transcoding and without forcing other already working files to transcode?
No, you could only distinguish files with "matches" parameters: http://www.serviio.org/index.php?option ... icle&id=24
About your mp4 sample,seems good, I only notice to be a mp4 video with variable frame rate. Don't know if PS3 supports that...
mkkyah
Post Thu Mar 01, 2012 8:47 pm
Can I send you a sample video to try?
I see that "working video" file has also variable bitrate.
Post Sun Mar 04, 2012 7:37 pm
mkkyah wrote: Can I send you a sample video to try?
Don't have a PS3 device.
