TV keeps loosing connection from serviio
Asesinato
Post Mon Feb 27, 2012 7:30 pm
Hello.
My samsung tv keeps losing the connection to serviio, and stops the playback and then there goes some time before it can find the server again... Can anyone help me fix this please?
My OS is windows 7
Screen Dump of inSSIDer:
http://imageshack.us/f/88/14978041.jpg/
My networks is the one called : Du Hacker Den Aldrig
My router is a D-Link DIR 635
Dump of the log from serviio from today where is has happend ALOT of times :
2012-02-26 19:49:13,497 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-02-26 19:49:13,513 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-02-26 19:49:13,613 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-02-26 19:49:13,614 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-02-26 19:53:00,865 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file imcare-big.brother.2012.e18.danish.pdtv.xvid.avi [VideoDescription [type=FILM, names=[imcare big brother, lonely eps], year=2012, season=null, episode=null]]
2012-02-26 19:53:00,950 INFO [LibraryAdditionsCheckerThread] Added file 'imcare-big.brother.2012.e18.danish.pdtv.xvid.avi' (title: imcare-big.brother.2012.e18.danish.pdtv.xvid) to Library
2012-02-27 18:20:36,066 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-27 18:20:36,067 INFO [WebServer] WebServer shutting down
2012-02-27 18:20:36,070 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-27 18:20:36,097 INFO [EventDispatcher] Leaving EventDispatcher
2012-02-27 18:20:56,086 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-27 18:21:01,671 INFO [ServiioConsole] Leaving Serviio Console
2012-02-27 18:22:09,094 INFO [LibraryAdditionsCheckerThread] Added file 'the.walking.dead.s02e10.720p.hdtv.x264-2hd.mkv' (title: 18 Miles Out) to Library
2012-02-27 18:23:59,098 INFO [ServiioConsole] Starting Serviio Console
2012-02-27 18:24:00,159 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-02-27 18:24:01,634 INFO [Messages] Loaded console message bundle for locale: da
2012-02-27 18:24:01,651 INFO [UpdateChecker] Checking if a new version is available
2012-02-27 18:24:09,233 INFO [ServiioConsole] Leaving Serviio Console
2012-02-27 18:24:12,626 INFO [ServiioConsole] Starting Serviio Console
2012-02-27 18:24:12,919 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-02-27 18:24:13,662 INFO [Messages] Loaded console message bundle for locale: da
2012-02-27 18:24:13,679 INFO [UpdateChecker] Checking if a new version is available
2012-02-27 18:24:21,179 INFO [RendererSearchSender] Searching for Renderer devices
2012-02-27 18:24:21,179 INFO [WebServer] WebServer starting on port 8895
2012-02-27 18:24:21,180 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-27 18:24:21,181 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-27 18:24:21,181 INFO [EventDispatcher] Starting EventDispatcher
2012-02-27 18:24:21,408 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Realtek RTL8188SU Wireless LAN 802.11n USB 2.0 Network Adapter) and address 192.168.0.194, timeout = 0
Post Mon Feb 27, 2012 7:45 pm
Re: TV keeps loosing connection from serviio
Asesinato
Post Mon Feb 27, 2012 7:47 pm
Well i have been searcing and cant find Anything that helps mé
Post Mon Feb 27, 2012 7:48 pm
read line 4. ;)
Asesinato
Post Mon Feb 27, 2012 7:55 pm
??????? What dó u mean
Post Mon Feb 27, 2012 7:56 pm
To help us help you, provide detailed log and if the problem relates to a unplayable/missing video file also post its technical metadata.
Asesinato
Post Mon Feb 27, 2012 8:02 pm
Im very new at this, i thougt i had giving All the things you need? What more dó you need?
Post Mon Feb 27, 2012 8:06 pm
Please attach your serviio.log file. How is your network setup wired? Wifi? Ip addresses
Sent from my DROIDX using Tapatalk
You need to turn on detailed logging (see sig) and then post a new logo which will contain lots of DEBUG lines.
Asesinato
Post Mon Feb 27, 2012 8:11 pm
I feel realy stupid now... How do i turn on detailed logging, i cant find it anywhere in the console?
Post Mon Feb 27, 2012 8:12 pm
There is a link with instructions in my signature
Asesinato
Post Mon Feb 27, 2012 8:17 pm
Found it :)=
Asesinato
Post Mon Feb 27, 2012 8:24 pm
This is the log from my start of the service, i havent turnt on the tv, on this, should i try that and upload a new log???
Asesinato
Post Mon Feb 27, 2012 8:25 pm
Ups here is the file :))
serviio - Kopi.rar
(309.49 KiB) Downloaded 527 times
Post Mon Feb 27, 2012 9:25 pm
ok no errors in the logs, what router are you using? make/model.
Asesinato
Post Mon Feb 27, 2012 9:44 pm
D-link
Dir-635
Asesinato
Post Mon Feb 27, 2012 9:46 pm
I posted a link to a screendump of the wifi i my post if you Want to see
Post Mon Feb 27, 2012 10:51 pm
have u got the proper wifi adaptor for the TV from samsung ?
Asesinato
Post Tue Feb 28, 2012 6:49 am
Wifi adapter? I have a wire from my tv to the router and then wifi from my computer to the router
Asesinato
Post Tue Feb 28, 2012 11:59 am
Im thinking maybe its a problem with the wifi from my computer to the router? But i talked to my phone company and they says there is no problems?
