Viera TC-P50X3 & ms-dvr files
RobJV
Post Fri Mar 02, 2012 12:30 am
I have not been able to get ms-dvr files to work over the viera TC-P50X3. I understand that it may not be possible presently. Could this be something that is added in the future?
I use this profile presently:
<Profile id="24" name="Panasonic Viera 2011 Without AVI Support" extendsProfileId="1">
      <!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" >
         <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
         <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
           <!-- remux VORBIS/FLAC/LPCM in MKV/MP4 to AC3 -->
           <Video targetContainer="mpegts" targetACodec="ac3" >
              <Matches container="mp4" vCodec="h264" aCodec="lpcm"/>
              <Matches container="mp4" vCodec="h264" aCodec="aac"/>
           <!-- Remux MPEG-TS with no transcoding -->
              <Matches container="matroska" vCodec="mpeg2video"/>
           <!-- Remux WTV files to MPEG-PS with no transcoding-->
              <Matches container="wtv" />
           <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
              <Matches container="avi" />
              <Matches container="mp4" vCodec="mpeg4" />
              <Matches container="mpeg" vCodec="mpeg1video" />
              <Matches container="matroska" vCodec="mpeg4" />
              <Matches container="asf" />
              <Matches container="flv" />
              <Matches container="ogg" />
              <Matches container="3gp" />
           <!-- unsupported audio will be transcoded into lpcm audio -->
              <Matches container="flac" />
              <Matches container="adts" />
           </Audio>
Post Fri Mar 02, 2012 1:40 am
Re: Viera TC-P50X3 & ms-dvr files
viewtopic.php?f=13&t=5455&hilit=ms+dvr
no changes can be made to the profile till the files are supported but providing ffmpeg -i and mediainfo of the file is always helpful.
RobJV
Post Fri Mar 02, 2012 7:13 am
J:\recorded tv>ffmpeg -i "Curious George_WTVS_11_12_2010_03_58_03.dvr-ms" > test
.txt
ffmpeg version N-38292-ga4c22e3 Copyright (c) 2000-2012 the FFmpeg developers
  built on Feb 27 2012 14:50:39 with gcc 4.6.2
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
  libavutil      51. 41.100 / 51. 41.100
  libavcodec     54.  4.100 / 54.  4.100
  libavformat    54.  1.100 / 54.  1.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 62.101 /  2. 62.101
  libswresample   0.  7.100 /  0.  7.100
[mpeg2video @ 03A5A2C0] mpeg_decode_postinit() failure
    Last message repeated 14 times
[asf @ 023D94A0] max_analyze_duration 5000000 reached at 5004000
[asf @ 023D94A0] decoding for stream 1 failed
[asf @ 023D94A0] Could not find codec parameters (Unknown: none)
Input #0, asf, from 'Curious George_WTVS_11_12_2010_03_58_03.dvr-ms':
    DVR Index Granularity: 500
    WM/SubTitleDescription: William H. Macy narrates the adventures of Curious G
eorge.
    genre           : Educational,Kids
    WM/MediaCredits : Frank Welker;;;
    WM/OriginalReleaseTime: 0001-01-01T00:00:00Z
    service_provider: WTVS
    service_name    : WTVS (Detroit Public Broadcasting)
    WM/MediaNetworkAffiliation: PBS Affiliate
    WM/MediaOriginalChannel: 15
    WM/MediaOriginalBroadcastDateTime: 0001-01-01T00:00:00Z
    WM/WMRVServiceID: 28461409
    WM/WMRVProgramID: <SEID PrID="!6C67E5F2165DBFCDAB2C90FA4B3C65AB!" Start="201
0-12-11T12:00:00" Duration="PT30M" />
    WM/MediaOriginalRunTime: 82013081ID="!6C67E5F2165DBFCDAB2C90FA4B3C65AB!" ÷3
V«?
    WM/WMRVEncodeTime: 18446744ID="!6C67E5F2165DBFCDAB2C90FA4B3C65AB!" ÷3V«?
    WM/MediaIsStereo: 1
    WM/VideoClosedCaptioning: 1
    WM/MediaIsRepeat: 0
    WM/MediaIsLive  : 0
    WM/MediaIsTape  : 0
    WM/MediaIsDelay : 0
    WM/MediaIsSubtitled: 0
    WM/MediaIsMovie : 0
    WM/MediaIsPremiere: 0
    WM/MediaIsFinale: 0
    WM/MediaIsSAP   : 0
    WM/WMRVRequestID: 4363
    WM/WMRVScheduleItemID: 5516
    WM/WMRVQuality  : 3
    WM/WMRVOriginalSoftPrePadding: 1844
    WM/WMRVOriginalSoftPostPadding: 180
    WM/WMRVActualSoftPrePadding: 1844
    WM/WMRVHardPrePadding: 0
    WM/Provider     : Zap2it
    WM/ProviderCopyright: ┬® 2010 Microsoft Corporation. All Rights Reserved. Te
rms of Service: http://go.microsoft.com/fwlink/?LinkId=8430
    WM/WMRVEndTime  : 18446744`º=?áº=?`ó=?
    WM/WMRVExpirationDate: 18446744`º=?áº=?`ó=?
    WM/WMRVBitrate  : 12713103`º=?áº=?`ó=?
    WM/WMRVKeepUntil: 1844
    WM/WMRVHardPostPadding: 0
    WM/WMRVActualSoftPostPadding: 180
    WM/WMRVContentProtectedPercent: 0
    WM/WMRVInBandRatingSystem: 255
    WM/WMRVInBandRatingLevel: 255
    WM/WMRVInBandRatingAttributes: 0
    WM/WMRVWatched  : 0
    WM/WMRVATSCContent: 0
    WM/WMRVDTVContent: 1
    WM/WMRVHDContent: 0
    WM/WMRVContentProtected: 0
    WM/MediaThumbTimeStamp: 18446744
    WM/MediaThumbWidth: 360
    WM/MediaThumbHeight: 240
    WM/MediaThumbStride: 1080
    WM/MediaThumbRet: 0
    WM/MediaThumbType: 3
    WM/MediaThumbRatingSystem: 1
    WM/MediaThumbRatingLevel: 1
    WM/MediaThumbRatingAttributes: 0
    WM/MediaThumbAspectRatioX: 4
    WM/MediaThumbAspectRatioY: 3
    WMFSDKVersion   : 11.0.6001.7006
    WMFSDKNeeded    : 0.0.0.0000
    VBR Peak        : 8017
    IsVBR           : 1
    title           : Curious George
  Duration: 00:34:54.80, start: 3.624000, bitrate: 8497 kb/s
    Stream #0:0: Audio: mp2, 48000 Hz, 2 channels, s16, 384 kb/s
    Stream #0:1: Unknown: none
    Stream #0:2: Video: mpeg2video (Main) (DVR  / 0x20525644), yuv420p, 720x480
[SAR 8:9 DAR 4:3], 8250 kb/s, 33.40 fps, 29.97 tbr, 1k tbn, 59.94 tbc
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 22 guests
