Prevent DB flush for disconnected drive
au.voyager
Post Fri Mar 02, 2012 7:55 pm
An option to prevent database flush if a particular drive is disconnected would be awesome. (as opposed to detecting changes if a file is deleted from storage)
Issue detail: Just moved to the UK and have no dedicated Media PC with permanent storage. We have 1 external (USB) HD for media and 2 laptops and a DLNA/internet enabled TV connected via a switch. We frequently use differing combinations of external media drive connected to laptop connected to hub and when switching external media drive between laptops, Serviio database needs time to refresh/rebuild as it's detected the storage drive was not there for some time and has flushed all media records of that drive.
Thanks for listening,
Bren.
Post Fri Mar 02, 2012 8:02 pm
Re: Prevent DB flush for disconnected drive
http://wiki.serviio.org/doku.php?id=ser ... _explained
see wiki above untick the GREEN and ORANGE box, the make sure that when you add new files that you retick the ORANGE box ,click save and click force refresh, then untick ORANGE box again.
au.voyager
Post Fri Mar 02, 2012 11:49 pm
Thanks for the workaround Cerberus, now, just to explain it to my partner :)
B.
Post Fri Mar 02, 2012 11:51 pm
au.voyager wrote:Thanks for the workaround Cerberus, now, just to explain it to my partner :)
B.
ha that your problem mate :P
Return to Feature requests
