AVI file and subtitles in other file, should it work ?
razor
Post Sun Oct 24, 2010 11:29 am
Hi !
I'm using Serviio 0.4.2 and Samsung 46C650.
is it possible to play film thru Serviio and see subtitiles that are in separate .txt file ? (not integrated with mkv etc.).
maybe that's a problem with TV ? and Serviio can't do anything about this ?
Post Sun Oct 24, 2010 11:36 am
Re: AVI file and subtitles in other file, should it work ?
it must be a separate .srt file with the same file name as the movie (just different extension). Also you must select Sansung profile in the console.
razor
Post Sun Oct 24, 2010 11:44 am
thanks for fast reply ! :)
i have subtitles in separate file (i will try to convert them to .srt), C-series Samsung profile selected of course.
Return to General discussion
Users browsing this forum: Google [Bot] and 4 guests
