4OD starts playback and then drops out
Post Fri Mar 02, 2012 9:46 pm
Re: 4OD starts playback and then drops out
I checked the logs and it was using the correct player. I'll have another try at some point soon.
Xmantium
Post Sat Mar 03, 2012 10:28 pm
Hi will, can you do a favor, I'm positive this fix works :geek:
Try to put this URL in your browser to see its valid - http://www.channel4.com/static/programm ... 1.21.2.swf
Make sure it's the exact same version number on your 4oD plugin
Try to add any 4oD program to your Serviio rather than using existing ones.
Post Sun Mar 04, 2012 9:22 am
Those are the steps I took in the first place, which I confirmed by checking the log. I'll have another go today. It apears ffmpeg is starting correctly, but after a min it returns with an error.
Post Sun Mar 04, 2012 5:50 pm
what if you run ffmpeg manually? it might be verification kicking in.
patters
Post Sun Mar 11, 2012 11:48 am
I had this problem too. I noticed it with the series Fresh Meat, which is the only one I have tried so far. Some episodes were fine, others not. And it was consistent, even days later.
Xmantium
Post Sun Mar 11, 2012 1:51 pm
@Patters - zip updated the 4od plugin few days ago with the new 4od swf player build, are you using the new version?
I've had no dropout problems since the change
Previous
Return to Plugin requests
