Library reset/blank on reboot/unmount
Is there anything I can do to make sure Serviio doesn't reset/erase the entire library even though the hard drives specified in the path, aren't mounted?
Zaitzev wrote:So the solution, or rather circumvention, is to disable library updates? I guess I could do that, but when there are files added almost daily I have to remember to re-enable it, let it update, and then disable it again? Sounds a bit counter-productive.
I'm on Ubuntu 11.10
Users browsing this forum: No registered users and 262 guests
