Problems with Samsung 6300C connecting to Serviio
link12
Post Sun Mar 04, 2012 3:59 am
I'm having mixed results with Serviio and my Samsung 6300c model TV. When I installed Serviio for the first time everything worked. I have since rebooted my machine and my TV will not see the DLNA Serviio server. In the Serviio console I can see my TV however. After a reboot I notice that there is a red circle next to my "discovered" TV. The circle will not change from red to green unless I remove it from the list and do a refresh. Even then I cannot see Serviio from my TV. I know it works because I watched a couple of movies through it already. My Windows 7 desktop has Media Sharing turned on which works fine with my TV. I'm stuck, any ideas/thoughts?
Post Sun Mar 04, 2012 4:16 am
Re: Problems with Samsung 6300C connecting to Serviio
Can you post your serviio.log file so we can see what is going on.
link12
Post Sun Mar 04, 2012 4:21 am
Here's the bottom portion of the log. Let me know if you want more. The 192.168.1.254 is my TV IP Address and the 192.168.1.10 is my Serviio Windows machine.
2012-03-03 23:10:09,939 INFO [RendererManager] Stored a new renderer: uuid='53ae8392-73c4-4db5-8bff-4cff031b5b60', name = 'Samsung TV', ipAddress='192.168.1.254', profile = '7'
2012-03-03 23:10:09,939 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-03 23:10:09,939 INFO [WebServer] WebServer shutting down
2012-03-03 23:10:09,939 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-03 23:10:09,940 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-03 23:10:11,298 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-03-03 23:10:11,298 INFO [WebServer] WebServer starting on port 8895
2012-03-03 23:10:11,298 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-03 23:10:11,298 INFO [EventDispatcher] Starting EventDispatcher
2012-03-03 23:10:11,298 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-03 23:10:11,298 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-03 23:10:11,349 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom BCM5716C NetXtreme II GigE (NDIS VBD Client)) and address 192.168.1.10, timeout = 0
2012-03-03 23:10:13,323 INFO [RendererManager] Stored a new renderer: uuid='8d6d6a4f-e88d-7923-3641-ebc035ec4c1e', name = 'Samsung DTV DMR', ipAddress='192.168.1.254', profile = '7'
2012-03-03 23:10:13,526 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-03-03 23:10:13,526 INFO [WebServer] WebServer shutting down
2012-03-03 23:10:13,526 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-03 23:10:13,526 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-03 23:10:16,225 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-03 23:10:16,240 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-03 23:10:16,240 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-03 23:10:16,240 INFO [WebServer] WebServer starting on port 8895
2012-03-03 23:10:16,240 INFO [EventDispatcher] Starting EventDispatcher
2012-03-03 23:10:16,256 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom BCM5716C NetXtreme II GigE (NDIS VBD Client)) and address 192.168.1.10, timeout = 0
2012-03-03 23:10:19,316 INFO [RendererManager] Stored a new renderer: uuid='5c28c5e2-f975-43cb-91d2-666d1dc68f35', name = 'Unrecognized device', ipAddress='192.168.1.213', profile = '1'
2012-03-03 23:10:25,057 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-03 23:12:20,572 INFO [WebServer] WebServer shutting down
2012-03-03 23:12:20,572 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-03 23:12:20,573 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-03 23:12:20,573 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-03 23:12:21,978 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-03-03 23:12:23,475 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-03 23:12:23,491 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-03 23:12:23,491 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-03 23:12:23,491 INFO [WebServer] WebServer starting on port 8895
2012-03-03 23:12:23,491 INFO [EventDispatcher] Starting EventDispatcher
2012-03-03 23:12:23,506 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom BCM5716C NetXtreme II GigE (NDIS VBD Client)) and address 192.168.1.10, timeout = 0
Post Sun Mar 04, 2012 4:29 am
please attach it to a post so we can see all of it.
link12
Post Sun Mar 04, 2012 5:04 am
Here's my log. I also uninstalled Serviio and reinstalled. As soon as that happened my TV saw the server without problem. I then added a directory to the library and was able to stream video. I then rebooted my Serviio Windows machine and my TV was listed with a "red" circle next to it and my TV no longer see's the Serviio server. All this is in the log.
(13.35 KiB) Downloaded 709 times
Post Sun Mar 04, 2012 5:29 am
Can you follow the steps in this thread? http://forum.serviio.org/viewtopic.php?f=3&t=3923#p26629 and post the results in that post. This will help Zip get serviio to be better at autobinding.
After you so the steps in that post, do the following to get serviio to work.
In the serviio console place 192.168.1.10 in the bound IP box on the profile selection tab.
link12
Post Sun Mar 04, 2012 2:32 pm
See attachment. Once I had my to the bound section, it appears to be working. I'm not sure I ran the listnic.class correctly. The screenshot should tell you. Thanks for the help.
Post Fri Mar 09, 2012 8:42 pm
just type
java ListNic
without the .class
