New 2012 TV Scene Rules
Xmantium
Post Fri Feb 24, 2012 1:07 pm
This is an article from Wikipedia for anyone thinking why there's no new xvid videos for TV releases
[edit]x264 for television sources
February 20, 2012, the SD x264 TV Release Standards aims to bring quality control back to the SD releases. x264 has become the most advanced video codec and compared to Xvid it is able to provide higher quality and compression at greater SD resolutions. It also allows better control and transparency over encoding settings. With CRF it can be ensured that a diverse array of material will get the most appropriate bitrate and not arbitrary fixed file sizes. The video container must be MP4. This ruleset is also applicable for sport releases. Thirteen groups signed the document.
More information can be found here - http://scenenotice.org/details.php?id=2029
On this note I've noticed my Xbox 360, Serviio transcode these new files, but the Xbox 360 can play these natively using Twonky.
zip, can you look at this, Xbox profile needs to change as these files don't need transcoding on Xbox 360
They are in .mp4 container
Update: Checked PS3, cant be played natively. So users must use Serviio to play these files.
Post Fri Feb 24, 2012 2:04 pm
Re: New 2012 TV Scene Rules
you cant trust open wiki that blindly, let wait and see what files come down form encoder then we can work out if changes need to be made to all device profiles not just the xbox360. :)
Xmantium
Post Fri Feb 24, 2012 2:35 pm
ive checked, all the tv scene files released now are in x264 format
check out last nights Mentalist or Big Bang Theroy episode release, no more xvid
Post Fri Feb 24, 2012 3:34 pm
Xmantium wrote:ive checked, all the tv scene files released now are in x264 format
thats one uploader out of hundreds, out there. ;)
Post Mon Feb 27, 2012 1:08 pm
Xmantium wrote:zip, can you look at this, Xbox profile needs to change as these files don't need transcoding on Xbox 360
Can you post ffmpeg -i of such file?
NX3
Post Tue Feb 28, 2012 7:11 pm
Loads of Xvid's still around, could be a while before they disappear
Xmantium
Post Sun Mar 04, 2012 1:38 am
Sorry about the late reply, theres only one group at the moment releasing TV releases in xvid format, all other major scene groups have agreed x264, mp4 container format.
ffmpeg -i Harry.Hills.Tv.Burp.PDTV.x264.C4TV.mp4
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Harry.Hills.Tv.Burp.PDTV.x264.C4TV.mp4'
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 2012-03-02 20:23:35
  Duration: 00:23:12.00, start: 0.000000, bitrate: 904 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 704x396,
768 kb/s, 25 fps, 25 tbr, 25k tbn, 50 tbc
      handler_name    : Video
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 132
 kb/s
      creation_time   : 2012-03-02 20:23:36
      handler_name    : English
Post Sun Mar 04, 2012 1:45 am
sorry mate but thats rubbish, most uploaders are still using Xvid, very few use x264 and the ones that do offer both.
Xmantium
Post Sun Mar 04, 2012 1:56 am
For TV releases, this has changed towards x264. Movie releases still xvid
Check out the latest TV releases now, i only see 2HD & FQM doing Xvid.
ASAP BAJSKORV C4TV D2V DiVERGE FTP KYR LMAO LOL MOMENTUM SYS TLA YesTV moved to x264, others will follow
Regardless, thats not the main issue here, xbox 360 does play these files without transcoding on my slim xbox 360
Post Sun Mar 04, 2012 2:11 am
Thats rubbish as i know a few of those uploader and they still provide files in xvid, the fact that xbox360 plays mp4 with h264 and aac natively is not my issue my issue is the false information.
making them play natively wont be that hard, if i had copy of xbox profile i could do that in seconds.
Xmantium
Post Sun Mar 04, 2012 1:40 pm
Just trying to help other novice Serviio users who don't know how to edit their Xbox 360 profile since these files are becoming very common going forward.
I didn't make up the rules, most of the scene uploaders have come together to agree the new tv standards, this also happened many years ago when tv releases moved from VCD/SVCD to XviD.
Here's a few sites/forum so you can read on further:
http://sickbeard.com/forums/viewtopic.php?t=3917
http://forums.thetvdb.com/viewtopic.php?f=15&t=9107
http://www.nsaneforums.com/topic/119495 ... dump-xvid/
Post Sun Mar 04, 2012 6:22 pm
this file should not be transcoded, having looked at the xbox profile.... Are you sure it is?
Xmantium
Post Sun Mar 04, 2012 6:58 pm
I'll check it again, playing these files caused ffmpeg go to 100% cpu with serviio on my nas so assumed it's transcoding
UPDATE: Your right it direct streams! There was one or two x264 file that for some reason transcoded for my xbox 360, possible it was a different format or audio codec
I'll post the ffmpeg logs of any that do transcode
Evostance
Post Fri Mar 09, 2012 3:03 pm
All my shows are now coming down in .mp4's and i think its having to transcode them to play on the PS3 and our Sony TV which makes it completely unplayable.
Can't transcode them fast enough to "stream" it.
According to this: http://manuals.playstation.net/document ... types.html
The PS3 support H264, so it shouldn't be transcoding the file. Is that correct?
nfig
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Users\admin\Downloads\Alcatraz Season
1 Episode 10 Clarence Montgomery.mp4':
major_brand : isom
minor_version : 1
creation_time : 2012-03-05 23:07:23
Duration: 00:42:49.19, start: 0.000000, bitrate: 796 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 720x404,
666 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
creation_time : 2012-03-05 19:40:47
handler_name : GPAC ISO Video Handler
Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 125
kb/s
creation_time : 2012-03-05 23:07:27
handler_name : GPAC ISO Audio Handler
Post Fri Mar 09, 2012 8:36 pm
yep, this file will not be transcoded when using the PS3 profile, unless the file is level 4.2 and higher. You can check that by looking at mediainfo output.
Evostance
Post Fri Mar 09, 2012 11:39 pm
It was being transcoded alright. I added in the mp4 h.264 tag to the PS3 profile and it started playing with no issues. CPU usage on the server was down while playing unlike before :s
Xmantium
Post Sat Mar 10, 2012 10:13 am
Evostance wrote:our Sony TV which makes it completely unplayable.
What Sony TV are you using?
Ive got the 2010 model and no issues at all
Evostance
Post Sat Mar 10, 2012 4:36 pm
Erm, is it a KDL 40 something. It's one of those Sony LED 3D ones
nickveldrin
Post Tue Mar 20, 2012 5:59 pm
Darn, just when Microsoft fixes the 360 by adding the xvid codec into their new "Metro" dashboard so we won't need to have a Live connected unit, we have to switch to a new video format that requires you to be on Live to get a signed codec package.
If we want to force transcoding of x264 to a native format that the 360 can take without having it be connected to live, what would we need to add/change in the profile? Or how can it be handled to match the xvid input/ouput?
So for example, here is a video format that works fine for Serviio to the 360:
Once.Upon.a.Time.(2011).S01E14.Dreamy.SD.TV.avi
Complete name                            : Once.Upon.a.Time.(2011).S01E14.Dreamy.SD.TV.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 350 MiB
Duration                                 : 41mn 56s
Overall bit rate                         : 1 166 Kbps
Writing application                      : MEncoder SVN-r32669-4.3.2
Writing library                          : MPlayer
Format                                   : MPEG-4 Visual
Format profile                           : Advanced Simple@L5
Format settings, BVOP                    : 1
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Muxing mode                              : Packed bitstream
Codec ID                                 : XVID
Codec ID/Hint                            : XviD
Duration                                 : 41mn 56s
Bit rate                                 : 1 025 Kbps
Width                                    : 624 pixels
Height                                   : 352 pixels
Bits/(Pixel*Frame)                       : 0.195
Stream size                              : 307 MiB (88%)
Writing library                          : XviD 1.2.1 (UTC 2008-12-04)
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 3
Mode                                     : Joint stereo
Mode extension                           : MS Stereo
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Duration                                 : 41mn 56s
Bit rate                                 : 128 Kbps
Stream size                              : 38.4 MiB (11%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 24 ms (0.58 video frame)
Interleave, preload duration             : 533 ms
However, new episodes of shows are x264 and they're erroring.
Complete name                            : Once.Upon.a.Time.(2011).S01E15.Red.Handed.SD.TV.mp4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 289 MiB
Duration                                 : 43mn 5s
Overall bit rate                         : 938 Kbps
Encoded date                             : UTC 2012-03-10 19:22:50
Tagged date                              : UTC 2012-03-10 19:22:50
Format profile                           : High@L3.1
Format settings, ReFrames                : 8 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 43mn 5s
Bit rate                                 : 811 Kbps
Maximum bit rate                         : 3 994 Kbps
Width                                    : 720 pixels
Height                                   : 404 pixels
Bits/(Pixel*Frame)                       : 0.116
Stream size                              : 250 MiB (87%)
Writing library                          : x264 core 122 r2183 c522ad1
Encoding settings                        : cabac=1 / ref=8 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=20 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Encoded date                             : UTC 2012-03-11 17:36:01
Tagged date                              : UTC 2012-03-10 19:22:57
Matrix coefficients                      : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Codec ID                                 : 40
Duration                                 : 43mn 5s
Bit rate                                 : 122 Kbps
Maximum bit rate                         : 147 Kbps
Stream size                              : 37.6 MiB (13%)
Encoded date                             : UTC 2012-03-10 19:22:55
ffmpeg -i is below:
for the avi (xvid)
"c:\Program Files (x86)\Serviio\lib\ffmpeg.exe" -i Once.Upon.a.Time.(2011).S01E14.Dreamy.SD.TV.avi
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
[mpeg4 @ 01828e00] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'Once.Upon.a.Time.(2011).S01E14.Dreamy.SD.TV.avi':
    encoder         : MEncoder SVN-r32669-4.3.2
  Duration: 00:41:56.13, start: 0.000000, bitrate: 1165 kb/s
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 624x352 [SAR 1:1 DAR 39:22], 23.98 tbr, 23.98 tbn, 23.98 tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 128 kb/s
x264
"c:\Program Files (x86)\Serviio\lib\ffmpeg.exe" -i Once.Upon.a.Time.(2011).S01E15.Red.Handed.SD.TV.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Once.Upon.a.Time.(2011).S01E15.Red.Handed.SD.TV.mp4':
    major_brand     : isom
    minor_version   : 1
    creation_time   : 2012-03-10 19:22:50
  Duration: 00:43:05.53, start: 0.000000, bitrate: 937 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 720x404,811 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
      creation_time   : 2012-03-11 17:36:01
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 122 kb/s
      creation_time   : 2012-03-10 19:22:55
Post Wed Mar 21, 2012 1:03 pm
you'd have to add matcher for mpeg4@h264 to the transcoding config like
<Matches container="mpeg4" vCodec="h264" />
Users browsing this forum: Baidu [Spider] and 13 guests
