3 Devices - 4 Filetypes - 9 variants - 8 Fails/27combos
Petrev
Post Sun Mar 04, 2012 4:37 pm
Hi
Using 0.6.2 and great to have TRP support now - thanks.
Sony Bravia HX703 (Bravia2010 Profile)
Sony BDP S370 (Sony BD Profile)
DigitalStream DPS1000 (Generic DLNA Profile)
I have done a matrix of my top4 Media Filetypes (2/3 variants in each)
MKV - 720p AVC + AC3 or DTS
MP4 - 720p AVC + AAC 5.1 or 2.0
TRP - 1440x1080 AVC + AAC 5.1
TRP - 720(or544)x576 MPEG + MPEG 2.0
TRP - 1440x1080 AVC + AC3
AVI - OK - XVID + AC3 or MP3
and find that there is always at least one good option for each type but some have a fail on one or two devices.
As there are profiles for the S370 and Bravia TV I would have hoped that there would be no fails and apart from SD Freeview (standard MPEG TS ?) the TV profile is excellent. The S370 actually has most problems.
I would hope that a bit of copy and paste in the config profiles.xml may work but am at a bit of a loss to spot which parts to cut/paste.
The DPS1000 seems a very capable media and DLNA player though presumably doesn't support DTS. It does support AAC.
I hope this matrix makes sense and I can of course post any extra info needed to help with trying to get all files working on all my devices !!!!!!
Life would not be so problematic if I were on my own and all devices were in the same room and in use by just me but . . . I have to try to get them working for 3 people/rooms you see.
Cheers
Pete
Petrev
Post Mon Mar 05, 2012 12:22 am
Re: 3 Devices - 4 Filetypes - 9 variants - 8 Fails/27combos
DigitalStream DPS-1000 IPTV Media Player
GetProtocolInfo
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,rtsp-rtp-udp:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,rtsp-rtp-udp:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,rtsp-rtp-udp:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,rtsp-rtp-udp:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO,rtsp-rtp-udp:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO,rtsp-rtp-udp:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO,http-get:*:image/png:DLNA.ORG_PN=PNG_TN,rtsp-rtp-udp:*:image/png:DLNA.ORG_PN=PNG_TN,http-get:*:image/png:DLNA.ORG_PN=PNG_SM_ICO,rtsp-rtp-udp:*:image/png:DLNA.ORG_PN=PNG_SM_ICO,http-get:*:image/png:DLNA.ORG_PN=PNG_LRG_ICO,rtsp-rtp-udp:*:image/png:DLNA.ORG_PN=PNG_LRG_ICO,http-get:*:image/png:DLNA.ORG_PN=PNG_LRG,rtsp-rtp-udp:*:image/png:DLNA.ORG_PN=PNG_LRG,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,rtsp-rtp-udp:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/L16:DLNA.ORG_PN=LPCM,rtsp-rtp-udp:*:audio/L16:DLNA.ORG_PN=LPCM,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,rtsp-rtp-udp:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,rtsp-rtp-udp:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO,rtsp-rtp-udp:*:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO,rtsp-rtp-udp:*:audio/mp4:DLNA.ORG_PN=AAC_ISO,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320,rtsp-rtp-udp:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320,http-get:*:audio/vnd.dolby.dd-raw:DLNA.ORG_PN=AC3,rtsp-rtp-udp:*:audio/vnd.dolby.dd-raw:DLNA.ORG_PN=AC3,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO,rtsp-rtp-udp:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320,rtsp-rtp-udp:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS,rtsp-rtp-udp:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320,rtsp-rtp-udp:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1,rtsp-rtp-udp:*:video/mpeg:DLNA.ORG_PN=MPEG1,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,rtsp-rtp-udp:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,rtsp-rtp-udp:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,rtsp-rtp-udp:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO,rtsp-rtp-udp:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,rtsp-rtp-udp:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO,rtsp-rtp-udp:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO,rtsp-rtp-udp:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,rtsp-rtp-udp:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,rtsp-rtp-udp:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA,rtsp-rtp-udp:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T,rtsp-rtp-udp:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,rtsp-rtp-udp:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,rtsp-rtp-udp:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO,rtsp-rtp-udp:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T,rtsp-rtp-udp:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO,rtsp-rtp-udp:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T,rtsp-rtp-udp:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T,rtsp-rtp-udp:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC,rtsp-rtp-udp:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC,rtsp-rtp-udp:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520,rtsp-rtp-udp:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE,rtsp-rtp-udp:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL,rtsp-rtp-udp:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO,rtsp-rtp-udp:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL,rtsp-rtp-udp:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO,rtsp-rtp-udp:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHM_BASE,rtsp-rtp-udp:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHM_BASE,http-get:*:image/gif:*,rtsp-rtp-udp:*:image/gif:*,http-get:*:audio/x-wav:*,rtsp-rtp-udp:*:audio/x-wav:*,http-get:*:audio/lpcm:*,rtsp-rtp-udp:*:audio/lpcm:*,http-get:*:audio/x-aac:*,rtsp-rtp-udp:*:audio/x-aac:*,http-get:*:audio/m4a:*,rtsp-rtp-udp:*:audio/m4a:*,http-get:*:application/ogg:*,rtsp-rtp-udp:*:application/ogg:*,http-get:*:video/avi:*,rtsp-rtp-udp:*:video/avi:*,http-get:*:video/mp1s:*,rtsp-rtp-udp:*:video/mp1s:*,http-get:*:video/mp2p:*,rtsp-rtp-udp:*:video/mp2p:*,http-get:*:video/mp2t:*,rtsp-rtp-udp:*:video/mp2t:*,http-get:*:video/mpeg2:*,rtsp-rtp-udp:*:video/mpeg2:*,http-get:*:video/dvd:*,rtsp-rtp-udp:*:video/dvd:*,http-get:*:video/quicktime:*,rtsp-rtp-udp:*:video/quicktime:*,http-get:*:video/mpeg4:*,rtsp-rtp-udp:*:video/mpeg4:*,http-get:*:video/mp4:*,rtsp-rtp-udp:*:video/mp4:*,http-get:*:video/m4t:*,rtsp-rtp-udp:*:video/m4t:*,http-get:*:audio/x-mpegurl:*,rtsp-rtp-udp:*:audio/x-mpegurl:*,http-get:*:audio/x-ms-wax:*,rtsp-rtp-udp:*:audio/x-ms-wax:*,http-get:*:audio/x-scpls:*,rtsp-rtp-udp:*:audio/x-scpls:*,http-get:*:application/t5:*,rtsp-rtp-udp:*:application/t5:*,http-get:*:video/x-matroska:*,rtsp-rtp-udp:*:video/x-matroska:*,http-get:*:video/youtube:*,rtsp-rtp-udp:*:video/youtube:*
Petrev
Post Mon Mar 05, 2012 12:53 am
MKV File
- DigitalStream DPS-1000 - Fails to Play - Buffering > Fail to File-List
Format                           : Matroska
File size                        : 4.37 GiB
Duration                         : 1h 33mn
Overall bit rate                 : 6 707 Kbps
Encoded date                     : UTC 2011-07-14 02:23:14
Writing application              : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58
Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Muxing mode                      : Container profile=Unknown@4.1
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 33mn
Bit rate                         : 5 203 Kbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.235
Stream size                      : 3.30 GiB (76%)
Writing library                  : x264 core 115 r2008 4c552d8
Encoding settings                : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=5203 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 1h 33mn
Bit rate                         : 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 24 bits
Stream size                      : 1 007 MiB (23%)
MP4 - File
- Sony BDP S370 - Bad Audio Mix - FX only from front channels - No dialogue
- Plays OK in 2.0 on Sony Bravia2010 and DPS-1000
Format                           : MPEG-4
Format profile                   : Base Media
Codec ID                         : isom
File size                        : 2.15 GiB
Duration                         : 1h 44mn
Overall bit rate                 : 2 964 Kbps
Encoded date                     : UTC 2010-11-12 13:21:17
Tagged date                      : UTC 2010-11-12 13:21:17
Writing application              : Yamb 2.1.0.0 [http://yamb.unite-video.com]
Format settings, ReFrames        : 4 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 1h 44mn
Bit rate mode                    : Variable
Bit rate                         : 2 525 Kbps
Maximum bit rate                 : 14.6 Mbps
Height                           : 534 pixels
Original height                  : 536 pixels
Display aspect ratio             : 2.35:1
Original display aspect ratio    : 2.35:1
Frame rate mode                  : Constant
Scan type                        : MBAFF
Bits/(Pixel*Frame)               : 0.154
Stream size                      : 1.83 GiB (85%)
Writing library                  : x264 core 108 r1766+332 1be361f
Encoding settings                : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / fade_compensate=0.10 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=3 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=tff / constrained_intra=0 / fgo=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2525 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=none
Encoded date                     : UTC 2010-11-13 11:44:59
Tagged date                      : UTC 2010-11-12 13:22:15
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format version                   : Version 4
Format profile                   : LC
Format settings, SBR             : No
Codec ID                         : 40
Duration                         : 1h 44mn
Bit rate                         : 445 Kbps
Maximum bit rate                 : 530 Kbps
Stream size                      : 331 MiB (15%)
Encoded date                     : UTC 2010-11-12 13:22:06
TRP File - FreeView HD
- DPS1000 - Won't Play - Function Unsupported
- BDP-S370 - Only 1440 Wide - Video Freezes and No Audio
- OK on Sony Bravia 2010
Complete name                    : H:\Test-V\BBC HD Preview_14 JAN_06-00-FOLDER-TS-TRP.trp\BBC HD Preview_14 JAN_06-00.trp
Format                           : MPEG-TS
File size                        : 303 MiB
Duration                         : 4mn 59s
Overall bit rate                 : 8 469 Kbps
Menu ID                          : 17472 (0x4440)
Format profile                   : High@L4.0
Format settings, GOP             : M=8, N=24
Duration                         : 4mn 59s
Width                            : 1 440 pixels
Height                           : 1 080 pixels
Frame rate                       : 25.000 fps
Audio #1
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 1
Emphasis                         : CCITT
Duration                         : 4mn 59s
Bit rate                         : 352 Kbps
Channel(s)                       : 1 channel
Sampling rate                    : 32.0 KHz
Video delay                      : -1s 32ms
Stream size                      : 12.6 MiB (4%)
Language                         : English
Audio #2
Format                           : AAC
Format profile                   : High efficiency AAC@L2
Duration                         : 4mn 59s
Video delay                      : -680ms
Language                         : English
Language, more info              : Visual impaired commentary
Text
Format                           : DVB Subtitles
Language                         : English
Menu
Duration                         : 4mn 59s
List                             : 101 (0x65) (AVC) / 102 (0x66) (MPEG Audio, English) / 105 (0x69) (DVB Subtitles, English) / 106 (0x6A) (AAC, English)
Language                         :  / English / English / English
TRP File - FreeView SD
Sony BDP S370 - Attempts tp Play - Filename appears - Waiting Spinner - No Audio/Video Types displayed - Fails "Cannot communicate with server".
Sony Bravia 2010 - - Attempts tp Play - Waiting Spinner - Filename appears -- No Audio/Video Types displayed - Fails Black Screen.
OK on DPS-1000
Complete name                    : H:\Test-V\University Challenge_30 JAN_20-00.trp\University Challenge_30 JAN_20-00.trp
Format                           : MPEG-TS
File size                        : 824 MiB
Duration                         : 29mn 50s
Overall bit rate                 : 3 862 Kbps
Menu ID                          : 4287 (0x10BF)
Format                           : MPEG Video
Format version                   : Version 2
Format profile                   : Main@Main
Format settings, BVOP            : Yes
Format settings, Matrix          : Default
Format settings, GOP             : M=3, N=24
Duration                         : 29mn 50s
Bit rate                         : 3 413 Kbps
Nominal bit rate                 : 15.0 Mbps
Width                            : 720 pixels
Height                           : 576 pixels
Standard                         : PAL
Scan type                        : Interlaced
Scan order                       : Top Field First
Bits/(Pixel*Frame)               : 0.329
Stream size                      : 728 MiB (88%)
Format                           : MPEG Audio
Format profile                   : Layer 2
Duration                         : 29mn 50s
Bit rate                         : 256 Kbps
Channel(s)                       : 2 channels
Video delay                      : -239ms
Stream size                      : 54.6 MiB (7%)
Language                         : English
Text
Language                         : English
Menu
Duration                         : 29mn 50s
List                             : 201 (0xC9) (MPEG Video) / 202 (0xCA) (MPEG Audio, English) / 205 (0xCD) (DVB Subtitles, English)
TS File - FreeSat HD
- BDP-S370 - No Audio
Complete name                    : H:\Test-V\40Daysand40Nights-ITVHD-TS.ts
Format                           : MPEG-TS
File size                        : 8.46 GiB
Duration                         : 1h 51mn
Overall bit rate                 : 10.8 Mbps
Menu ID                          : 10510 (0x290E)
Format profile                   : Main@L4.0
Duration                         : 1h 52mn
Bit rate                         : 10.0 Mbps
Bits/(Pixel*Frame)               : 0.258
Stream size                      : 7.84 GiB (93%)
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Duration                         : 1h 51mn
Bit rate                         : 256 Kbps
Channel positions                : Front: L R
Bit depth                        : 16 bits
Video delay                      : -152ms
Stream size                      : 205 MiB (2%)
Language                         : English
Petrev
Post Fri Mar 16, 2012 12:23 pm
So . . .
Standard filetypes on specifically supported devices (albeit SONY ! devices) and no one has any answers as to why they fail ?
Or what to change in profile config file ?
Pete
Post Fri Mar 16, 2012 1:11 pm
Could you enable detailed logging (see signature)?
Check for errors then post log here.
Petrev
Post Tue Mar 27, 2012 5:34 pm
Illico wrote:Could you enable detailed logging (see signature)?
Hi
Thanks for posting log method - I have had flu so sorry for the delay in posting back.
1st Log for FreeView-SD
Sony TV first
- List shows [MPEG2]
- Looks like playing but Info shows Playback at 0:00:00 / 0:29:50
- - Press STOP to move on.
BDP S370 next
- List shows [M2TS]
- Waiting Spinner appears and then Cannot connect to server - Spinner again and INFO shows 0:00:00 / 0:00:00
- - Press STOP
DPS1000 - Plays A-OK
FreeView-SD-serviio.log
(199.65 KiB) Downloaded 910 times
Petrev
Post Tue Mar 27, 2012 5:41 pm
2nd. Log for FreeView-HD
DPS1000 - Shows in list as Unsupported Format.
BDP S370 next
- List shows [M2TS]
- Plays at 1440 wide with black side bars
- No Sound
- Plays for 5 seconds then Video freezes
- - Press STOP
Sony TV
- List shows [AVC]
- Plays A-OK
FreeView-HD-serviio.log
(189.69 KiB) Downloaded 905 times
Petrev
Post Tue Mar 27, 2012 5:44 pm
3rd. Log for FreeSAT-HD
BDP S370 next
- List shows [M2TS]
- Plays Video OK
- No Sound
- - Press STOP
Sony TV
- List shows [AVC]
- Plays A-OK
FreeSAT-HD-serviio.log
(228.95 KiB) Downloaded 839 times
Petrev
Post Tue Mar 27, 2012 5:52 pm
4th. Log for MP4 File AVC + AAC5.1 (Edit:Corrected AAC not DTS)
BDP S370
- List shows [M2TS]
- Plays Video OK
- Audio FX noises only from front speakers
- Info shows as AAC5.1 Audio
- BDP is sending 5.1PCM to amp.
- - Press STOP
Sony TV
- List shows [AVC]
- Plays A-OK - - Stereo Audio Downmix
DPS1000
MP4-AVC-AAC5.1.log
(196.59 KiB) Downloaded 841 times
Petrev
Post Tue Mar 27, 2012 5:57 pm
5th. Log for MKV AVC + DTS5.1
DPS1000
Tries to Play - Buffering - - - Then Fails back to file list
BDP-S370
- Shows as [M2TS]
- Plays A-OK with DD2.0 Audio
Sony TV
- Shows as [AVC]
- Plays - A-OK with DD2.0 Audio
Thanks for any help . . .
MKV-AVC-DTS5.1.log
(197.36 KiB) Downloaded 854 times
Users browsing this forum: No registered users and 61 guests
