[Solved] Serviio Not Working After JAVA Update
ahsanur
Post Mon Mar 05, 2012 3:40 am
please help. today morning when i on my computer there was a java update. i installed it and then when it said to restart. i restarted my computer and now serviio is saying. error java not found. (picture uploaded. in attachments). I uploaded LOGS too. :) Thanks so much for helping me. I really appreciate it. Love you guys for creating a wonderful DLNA program!
These are the LOGS. :)
(400.53 KiB) Downloaded 802 times
Error java not found. This is the error i am having.
Post Mon Mar 05, 2012 7:25 pm
Re: Serviio Not Working After JAVA Update
did you install 32 or 64 bit Java version?
ahsanur
Post Mon Mar 05, 2012 8:24 pm
im not sure but i think 32
Post Tue Mar 06, 2012 12:34 pm
you could try to add EXE4J_JAVA_HOME environment variable as suggested (google for how to do it in windows) and point it to the Java installation folder, then restart the PC
ahsanur
Post Wed Mar 07, 2012 3:52 am
i got it to work by first uninstalling java and then reinstalling. thanks so much... :)
sriramna
Post Fri Apr 06, 2012 1:06 pm
Re: [Solved] Serviio Not Working After JAVA Update
Java was automatically updated today morning (Windows 7 Home Basic 32-bit) and I have the exact same problem. I have created the system environment variable EXE4_JAVA_HOME and set the value to C:\Progra~1\Java\jre6\bin but no soap.
ahsanur
Post Fri Apr 06, 2012 8:36 pm
first uninstall java and then reinstall java and serviio
sriramna
Post Sat Apr 07, 2012 1:29 pm
What did work was to download Java(TM) 7 Update 3 which fixed it. But I have both Java 6 Update 31 and this one in my Control Panel list now.
ahsanur
Post Sat Apr 07, 2012 1:41 pm
thats ok. it should be like that. i have it like that too
